查看: 2007|回復(fù): 0
紅外控制led燈
ID:252587 發(fā)表于 2017-11-23 10:54 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
源碼如下:
#include <IRremote.h>
int LED1 = 10;//循環(huán)控制燈的接口
int LED = 12;//兩個按鍵控制燈的接口
int RECV_PIN = 11;
volatile boolean  cont = HIGH;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup() {
  // put your setup code here, to run once:
  pinMode(LED,OUTPUT);
  Serial.begin(9600);
  irrecv.enableIRIn();
void loop() {
  // put your main code here, to run repeatedly:
  if(irrecv.decode(&results))
    Serial.println(results.value,HEX);//,HEX為轉(zhuǎn)化成16進(jìn)制輸出
    irrecv.resume();
    switch(results.value)
      case 0xFFA857:
      digitalWrite(LED,HIGH);
      break;
      case 0xFF629D:
      digitalWrite(LED,LOW);
      break;
    if(results.value == 0xFFE21D)
      cont = !cont;
  digitalWrite(LED1,cont);
