沒有下載到實(shí)際小車中,不知道哪兒有錯誤,請幫我指出一下謝謝#include<reg51.h>
unsigned char dj1=0;
unsigned char dj2=0;
sbit IN3=P0^1; //右輪
sbit IN4=P0^2;
sbit ENB=P0^0; //使能端A
sbit IN1=P1^1; //左輪
sbit IN2=P1^2;
sbit ENA=P1^0; //使能端B
sbit left_ir=P3^2;//避障
sbit right_ir=P3^3;
int a,i,t;
//正轉(zhuǎn)
void zhengzhuan()
IN1=0;
IN2=1;
IN4=0;
IN3=1;
dj1=10;
dj2=10;
void houtui()//后退
IN1=1;
IN2=0;
IN4=1;
IN3=0;
dj1=9;
dj2=9;
void stop()//停止
IN1=0;
IN2=0;
IN4=0;
IN3=0;
dj1=0;
dj2=0;
void left()//左轉(zhuǎn)
IN1=0;
IN2=0;
IN4=0;
IN3=1;
dj1=9;
dj2=26;
void right()//右轉(zhuǎn)
IN1=0;
IN2=1;
IN4=0;
IN3=0;
dj1=28;
dj2=9;
void bizhang()//避障
if(left_ir==0&&right_ir==0)
houtui();
else if(left_ir==0&&right_ir==1)
right();
else if(left_ir==1&&right_ir==0)
left();
zhengzhuan();
void init()//初始化
IP=0x20;
TMOD=0x20;//設(shè)置定時器T1為工作方式2
TH1=0xfd;
TL1=0xfd;//T1定時器裝初值
TR1=1;//啟動定時器T1
REN=1;//允許串口接收
SM0=0;
SM1=1;//設(shè)置串口工作方式1
EA=1;//開總中斷
ES=1;//開串口中斷
void init_T0()
IP=0x10;
TMOD=0x22;
TH0=(65536-250)/256;
TL0=(65536-250)%256;
TR0=1;
ET0=1;
init_T0();
init();
bizhang();
if(a==0x14||a==0x15||a==0x54||a==0x55||a==0x64||a==0x65)//如果是就前進(jìn)
zhengzhuan();
if(a==0x16||a==0x17||a==0x56||a==0x57||a==0x66||a==0x67)//如果是就后退
houtui();
if(a==0x18||a==0x19||a==0x58||a==0x59||a==0x68||a==0x69)//如果是就停止
stop();
if(a==0x1a||a==0x1b||a==0x5a||a==0x5b||a==0x6a||a==0x6b)//如果是就左轉(zhuǎn)
left();
if(a==0x1c||a==0x1d||a==0x5c||a==0x5d||a==0x6c||a==0x6d)//如果是就右轉(zhuǎn)
right();
void T1_time() interrupt 4
RI=0;
a=SBUF;
void timer0() interrupt 1 //定時器0中斷
t++;
if(t<dj1)
ENA=1;
ENA=0;
if(t<dj2)
ENB=1;
ENB=0;
if(t>=50)
t=0;
