查看: 2034|回復(fù): 0
溫度濕度監(jiān)測(cè)
ID:253260 發(fā)表于 2017-11-24 22:48 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include"lcd.h"
void Read_Busy()           //忙檢測(cè)函數(shù),判斷bit7是0,允許執(zhí)行;1禁止
    unsigned char sta;      //
    LCD1602_DB = 0xff;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do
        LCD1602_EN = 1;
        sta = LCD1602_DB;
        LCD1602_EN = 0;    //使能,用完就拉低,釋放總線
    }while(sta & 0x80);
void Lcd1602_Write_Cmd(unsigned char cmd)     //寫命令
    Read_Busy();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_EN = 1;
    LCD1602_EN = 0;
void Lcd1602_Write_Data(unsigned char dat)   //寫數(shù)據(jù)
      Read_Busy();
      LCD1602_RS = 1;
      LCD1602_RW = 0;
      LCD1602_DB = dat;
      LCD1602_EN = 1;
      LCD1602_EN = 0;
void LcdSetCursor(unsigned char x,unsigned char y)  //坐標(biāo)顯示
    unsigned char addr;
    if(y == 0)
        addr = 0x00 + x;
        addr = 0x40 + x;
    Lcd1602_Write_Cmd(addr|0x80);
//按指定位置顯示一個(gè)字符
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
        Y &= 0x1;
        X &= 0xF; //限制X不能大于15,Y不能大于1
        if (Y) X |= 0x40; //當(dāng)要顯示第二行時(shí)地址碼+0x40;
        X |= 0x80; //算出指令碼
        Lcd1602_Write_Cmd(X); //發(fā)命令字
        Lcd1602_Write_Data(DData); //發(fā)數(shù)據(jù)
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str)     //顯示字符串
    LcdSetCursor(x,y);      //當(dāng)前字符的坐標(biāo)
    while(*str != '\0')
        Lcd1602_Write_Data(*str++);
void InitLcd1602()              //1602初始化
    Lcd1602_Write_Cmd(0x38);    //打開(kāi),5*8,8位數(shù)據(jù)
    Lcd1602_Write_Cmd(0x0c);
    Lcd1602_Write_Cmd(0x06);
    Lcd1602_Write_Cmd(0x01);    //清屏
