查看: 2376|回復: 1
pcf8591 AD轉(zhuǎn)換
ID:225076 發(fā)表于 2017-11-25 14:17 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h
#include<pcf8591.h>
#define uint  unsigned int
sbit     SCL=P1^7;
sbit     SDA=P1^2;
void Delay_4us(void)
volatile uchar i=0;
i++,i++,i++,i++,i++,i++,i++,i++;
void I2c_Start(void)
SDA=1;
Delay_4us();
SCL=1;
Delay_4us();
SDA=0;
Delay_4us();
SCL=0;
Delay_4us();
void I2c_Stop(void)
SCL=0;
Delay_4us();
SDA=0;
Delay_4us();
SCL=1;
Delay_4us();
SDA=1;
Delay_4us();
unsigned char Rcv_Byte(void)
unsigned char i,rbyte=0;
for(i=8;i;i--)
  SCL=1;
  Delay_4us();
  rbyte=rbyte<<1;
  rbyte=rbyte|(SDA);
  SCL=0;
return rbyte;
unsigned char i;
for(i=8;i;i--)
  SDA=(bit)(dat&0x80);
  Delay_4us();
  SCL=1;
  Delay_4us();
  SCL=0;
  Delay_4us();
  dat=dat<<1;
void I2c_Ack(bit a)
SDA=a;
Delay_4us();
SCL=1;
Delay_4us();
SCL=0;
Delay_4us();
SDA=1;
Delay_4us();
}bit Test_Ack(void)
bit ack;
SDA=1;
Delay_4us();
SCL=1;
Delay_4us();
ack=SDA;
Delay_4us();
SCL=0;
return ack;
bit DAC(unsigned char addr,unsigned char Val)
   I2c_Start();
   Send_Byte(0x90|(addr<<1
   if(Test_Ack())return(0);
   Send_Byte(0x40);
   Send_Byte(Val);
   I2c_Stop();
unsigned char ADC(unsigned char addr,unsigned char channel)
unsigned char dat=0;
   EA=0;
   I2c_Start();
   Send_Byte(0x90|(addr<<1)|0);
   Send_Byte(channel);
   I2c_Stop();
    Delay_4us();
   I2c_Start();
   Send_Byte(0x90|(addr<<1)|1);
   dat=Rcv_Byte();
   I2c_Ack(1);
   I2c_Stop();
   EA=1;
   return(dat);
ID:1 發(fā)表于 2017-11-25 20:28 | 只看該作者
缺少頭文件
