查看: 2372|回復: 0
超聲波測距并在1602上顯示
ID:236125 發(fā)表于 2017-11-26 20:43 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
sbit lcdrs=P3^5;
sbit lcdrw=P3^6;
sbit lcden=P3^4;
sbit TRIG = P1^0;
sbit ECHO  =P1^1;
void Timer0_Init(void);
void Timer1_Init(void);
unsigned int Get_Distance(void);
void delayms();
void write_com();
void write_data();
void lcd1602init();
bit flag;
uint dValue;
unsigned int cnt;
static uchar flag1;
static uchar AUTO_flag;
uchar code lcdline1[]="Welcome To Use!" ;
uchar code lcdline2[]="  Table Lamp  " ;
void delayms(uint z)
        uint x,y;
        for(x=z;x>0;x--)
        for(y=110;y>0;y--);
void write_com(uchar com)
        lcdrs=0;
        lcdrw=0;
        lcden=0;
        P0=com;
        delayms(5);
        lcden=1;
        delayms(5);
        lcden=0;
void write_data(uchar dat)
        lcdrs=1;
        lcdrw=0;
        P0=dat;
        delayms(5);
        lcden=1;
        delayms(5);
        lcden=0;
void lcd1602init()
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
void main(void)
        uint i;
//        cNum=0;
        lcd1602init();
        delayms(1000);
        Timer0_Init();
        Timer1_Init();
        write_com(0x80);
        for(i=0;i<15;i++)
                write_data(lcdline1[i]);
                delayms(100);
        write_com(0x80+0x40);
        for(i=0;i<14;i++)
                write_data(lcdline2[i]);
                delayms(100);
        delayms(100);
                dValue=Get_Distance();
                lcd1602init();
                write_com(0x80);
                write_data(0x30+dValue/100);
                write_data(0x30+dValue%100/10);
                write_data(0x30+dValue%10);
                delayms(100);
/***********開啟定時器1并初始化***************/
        TMOD= 0x11;
        TH1=TL1=0;
        EA =1;
        TR1=0;
void Timer1_ISR() interrupt 3
        flag=1;
/***********開啟定時器0并初始化***************/
        TMOD =0x01;
        TH0=(65536-100)/256;
        TL0=(65536-100)%256;
        EA =1;
        TR0=1;
        ET0=1;
void Timer0_ISR()interrupt 1
        TR0=0;
        cnt++;
        if(cnt==20)
                cnt=0;
         TR0=1;
        unsigned int distance;
        uint t=100;
        TRIG=1;
        while(t--);
        TRIG=0;
        while(!ECHO);
        TR1=1;
        while(ECHO);
        TR1=0;
        distance=TH1*256+TL1;
        distance=distance*0.017;
        TH1=0;
        TL1=0;
        delayms(20);
        return distance;
