#include <reg52.h>
sbit lcdrs=P3^5;
sbit lcdrw=P3^6;
sbit lcden=P3^4;
sbit TRIG = P1^0;
sbit ECHO =P1^1;
void Timer1_Init();
unsigned int Get_Distance();
void delayms();
void write_com();
void write_data();
void lcd1602init();
bit flag;
uint dValue,tmp;
uchar code lcdline1[]="Welcome To Use!" ;
uchar code lcdline2[]="Table Lam is" ;
void delayms(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write_com(uchar com)
lcdrs=0;
lcdrw=0;
lcden=0;
P0=com;
delayms(5);
lcden=1;
delayms(5);
lcden=0;
void write_data(uchar dat)
lcdrs=1;
lcdrw=0;
P0=dat;
delayms(5);
lcden=1;
delayms(5);
lcden=0;
void lcd1602init()
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
void writeString(uchar * str, uchar length)
uchar i;
for(i = 0; i < length; i++)
write_data(str[i]);
void display()
unsigned char count;
unsigned char datas[] = {0, 0, 0};
unsigned int tmp = Get_Distance();
datas[0] = tmp/100 ;
datas[1] = tmp%100/10;
datas[2] = tmp%10;
write_com(0x80+0x40+12);
for(count = 0; count < 3; count++)
write_data('0'+datas[count]); //寫入能識別的字符 ’0‘+數(shù)值
void main(void)
lcd1602init();
Timer1_Init();
write_com(0x80);
writeString(lcdline1,15);
delayms(1000);
write_com(0x80+0x40);
writeString(lcdline2,12);
delayms(1000);
display();
delayms(100);
/***********開啟定時器1并初始化***************/
void Timer1_Init(void)
TMOD= 0x10;
TH1=0;
TL1=0;
EA =1;
TR1=0;
void Timer1_ISR() interrupt 3
flag=1;
unsigned int distance;
uint t=100;
TRIG=1;
while(t--);
TRIG=0;
while(!ECHO);
flag=0;
TR1=1;
while(ECHO);
TR1=0;
distance=TH1*256+TL1;
distance=distance*0.017;
TH1=0;
TL1=0;
delayms(100);
return distance;
