用51單片機(jī)實(shí)現(xiàn)的2路LM35模擬測(cè)溫,3路DS18B20數(shù)字測(cè)溫開關(guān)切換顯示的時(shí)哪路溫度,花了我很多時(shí)間.
- #include <REGX51.H>
- #include "1602.H"
- #include "DS18B20.h"
- extern unsigned char ReadAdc0832(unsigned char channel);
- extern void DelayMs(unsigned char t);
- unsigned int Temp[5];//5路溫度值溫度放大10倍
- int DS18B20DATA[3];//DS18B20讀到的16位數(shù)據(jù)
- code unsigned char DecimalNum[16]={0,1,1,2,3,3,4,4,5,6,6,7,8,8,9,9};//DS18B20小數(shù)部分對(duì)應(yīng)的數(shù)
- unsigned char code DuanMa[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- sbit LED=P3^1;
- sbit BEEP=P3^2;
- sbit LE=P3^0;
- sbit Key=P1^0;
- unsigned char CurID;
- // 顯示段碼值01234567
- unsigned char LCDbuf[16];
- void LM35Read(void)
- Temp[0]=ReadAdc0832(0)*10;
- DelayMs(10);
- Temp[1]=ReadAdc0832(1)*10;
- DelayMs(10);
- void DS18B20Read()
- gettemp(DS18B20DATA);
- Temp[2]=(DS18B20DATA[0]>>4)*10+DecimalNum[DS18B20DATA[0]&0x0f];
- Temp[3]=(DS18B20DATA[1]>>4)*10+DecimalNum[DS18B20DATA[1]&0x0f];
- Temp[4]=(DS18B20DATA[2]>>4)*10+DecimalNum[DS18B20DATA[2]&0x0f];//環(huán)境溫度
- //格式化數(shù)據(jù)
- void ForamtData(int Data,unsigned char *Str)
- unsigned char t;
- t=Data/10;
- if(t>99)
- *Str++='1';
- *Str++=(t%100)/10+0x30;
- *Str++=(t%10)+0x30;
- *Str++='.';
- *Str++=Data%10+0x30;
- if((t>9)&&(t<100))
- *Str++=' ';
- *Str++=t/10+0x30;
- *Str++='.';
- if((t<10)&&(t>0))
- *Str++=' ';
- *Str++=' ';
- *Str++='.';
- if(t==0)
- *Str++=' ';
- *Str++=' ';
- *Str++=' ';
- *Str++='.';
- *Str=0;
- //報(bào)警
- void Warning(void)
- unsigned char flag;//,//i;
- static unsigned int a,b;
- flag=0;
- a=Temp[4]+50;
- b=Temp[4]-50;
- //for(i=0;i<5;i++)
- flag=(Temp[CurID]>(a));
- flag=(Temp[CurID]<b)||flag;
- BEEP=!flag;
- LED=!flag;
- void main(void)
- LE=1;
- // _ASM
- // mov,r0,#1;
- P0=DuanMa[CurID+1];
- LE=0;
- LCD_Init();
- LCD_Write_String(0,0,"Envir: C");
- LCD_Write_String(5,1,"C ");
- LED=0;
- CurID=3;
- while(1)
- LM35Read();
- DS18B20Read();
- LE=1;
- LE=0;
所有資料51hei提供下載(仿真+源碼):
多路溫度采集器.zip
(110.58 KB, 下載次數(shù): 193)
2017-11-27 16:38 上傳
點(diǎn)擊文件名下載附件
