查看: 5693|回復(fù): 3
戰(zhàn)艦V3通過(guò)ESP8266獲得網(wǎng)絡(luò)天氣
ID:137406 發(fā)表于 2017-11-27 16:57 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
之前用8266和機(jī)智云成功通信了, 但是一直不知道8266是怎么設(shè)置聯(lián)網(wǎng),因?yàn)檫@個(gè)是下載的機(jī)智云的固件。后來(lái)就尋思著做了這個(gè)網(wǎng)絡(luò)天氣的。網(wǎng)上幾乎沒(méi)有人用STM32做天氣的,基本上都是用arduino或者直接用esp8266+oled。
一、
硬件:戰(zhàn)艦V3 + ESP8266 + 2.8寸屏
軟件:1、esp8266的配置
         2、連接天氣的服務(wù)器,get API數(shù)據(jù)
         3、cjson的移植與解析
         4、UTF8轉(zhuǎn)GBK轉(zhuǎn)碼,這個(gè)網(wǎng)上很少例程
         5、圖標(biāo)的取模
   首先配置esp8266為透?jìng)髂J?/font>
01
02
03
04
05
06
07
08
09
10
11
12
13
14
15
16
17
18
19
20
while(atk_8266_send_cmd("AT","OK",20))//¼ì2éWIFIÄ£¿éêÇ·ñÔúÏß
                atk_8266_quit_trans();//íË3öí¸′«
                atk_8266_send_cmd("AT+CIPMODE=0","OK",200);  //1رÕí¸′«Ä£ê½
                Show_Str(40,55,200,16,"Î′¼ì2aμ½Ä£¿é!!!",16,0);
                delay_ms(800);
                LCD_Fill(40,55,200,55+16,WHITE);
                Show_Str(40,55,200,16,"3¢êÔᬽóÄ£¿é...",16,0);
        while(atk_8266_send_cmd("ATE0","OK",20));//1رջØÏÔ
        atk_8266_send_cmd("AT+CWMODE=1","OK",50);                //éèÖÃWIFI STAÄ£ê½
        atk_8266_send_cmd("AT+RST","OK",20);                //DHCP·tÎñÆ÷1رÕ(½öAPÄ£ê½óDD§)
        delay_ms(1000);         //Ñóê±3Sμè′yÖØÆô3é1|
        delay_ms(1000);
        delay_ms(1000);
        delay_ms(1000);
        //éèÖÃᬽóμ½μÄWIFIíøÂçÃû3Æ/¼óÃü·½ê½/ÃüÂë,Õa¼¸¸ö2ÎêyDèòa¸ù¾YÄú×Ô¼oμÄ·óéÆ÷éèÖýøDDDT¸Ä!!
        atk_8266_send_cmd("AT+CIPMUX=0","OK",20);   //0£oμ¥ᬽó£¬1£o¶àᬽó
        sprintf((char*)p,"AT+CWJAP=\"%s\",\"%s\"",wifista_ssid,wifista_password);//éèÖÃÎTÏß2Îêy:ssid,ÃüÂë
        while(atk_8266_send_cmd(p,"WIFI GOT IP",300));                                        //ᬽóÄ¿±ê·óéÆ÷,2¢Çò»ñμÃIP
然后連接天氣服務(wù)器,get API
01
02
03
04
05
06
07
08
09
10
11
12
13
14
15
16
17
sprintf((char*)p,"AT+CIPSTART=\"TCP\",\"%s\",%s",WEATHER_SERVERIP,WEATHER_PORTNUM);    //ÅäÖÃÄ¿±êTCP·tÎñÆ÷
        res = atk_8266_send_cmd(p,"OK",200);//ᬽóμ½Ä¿±êTCP·tÎñÆ÷
        if(res==1)
                myfree(SRAMIN,p);
                return 1;
        delay_ms(300);
        atk_8266_send_cmd("AT+CIPMODE=1","OK",100);      //′«êäÄ£ê½Îa£oí¸′«
        atk_8266_get_wanip(ipbuf);//»ñè¡WAN IP
        sprintf((char*)p,"IPμØÖ·:%s ¶Ë¿ú:%s",ipbuf,(u8*)WEATHER_PORTNUM);
//        Show_Str(30,65,200,12,p,12,0);                                //ÏÔê¾IPμØÖ·oí¶Ë¿ú
        USART3_RX_STA=0;
        atk_8266_send_cmd("AT+CIPSEND","OK",100);         //¿aê¼í¸′«
        printf("start trans...\r\n");
        u3_printf("GET [color=rgb(0, 130, 0) !important][url=https://api.seniverse.com/]https://api.seniverse.com[/url]);
然后再解析這個(gè)API返回的數(shù)據(jù),并予以顯示。
二、
1.目前免費(fèi)的API有很多,我比較喜歡“心知天氣”( https://www.seniverse.com/ )和 “和風(fēng)天氣”(http://www.heweather.com/  )。
  大家可以到這兩個(gè)網(wǎng)站去注冊(cè),選擇你們喜歡的天氣API。心知天氣的免費(fèi)API返回的數(shù)據(jù)表少,功能較少。而和風(fēng)天氣的免費(fèi)API則返回的比較詳細(xì)。
  我這里選擇心知天氣,然后大家可以去看看心知天氣的文檔,里面有詳細(xì)的數(shù)據(jù)結(jié)構(gòu)(cjson數(shù)據(jù))。
2.移植和解析cjson。
  這個(gè)東西很簡(jiǎn)單,我也是第一次移植,不過(guò)看了一篇教程就會(huì)了。推薦大家看下這兩篇文章就可以了。
  http://blog.csdn.net/xukai871105/article/details/32346797    這個(gè)講cjson的格式講的蠻好的
  http://blog.csdn.net/lintax/article/details/50993958     這個(gè)講cjson的使用
  https://sourceforge.net/projects/cjson/          這個(gè)網(wǎng)站是下載cjson的
  移植cjson,注意兩點(diǎn),一個(gè)是cjson占用堆比較大,大約3K,這個(gè)坑我就遇到了,使用默認(rèn)的堆大小不能運(yùn)行,于是我把堆改成了4K。
  第二點(diǎn)就是 要為 cjson 配置malloc ,打開cjson.c,修改下面幾處。修改成原子的mymalloc,由于原子的mymalloc有個(gè)選擇SRAMIN的參數(shù),所以我又封裝了下,弄了個(gè)my_malloc。
3.連接天氣服務(wù)器,然后get 天氣的api。
   這里卡了好半天,一開始用網(wǎng)口調(diào)試助手連上了服務(wù)器,然后get那個(gè)API鏈接的時(shí)候,一直不成功,原來(lái)是要在這個(gè)鏈接后面加兩個(gè)回車,這個(gè)得感謝壇友  svwydh
4.解析天氣數(shù)據(jù)
  用cjson庫(kù)來(lái)解析天氣數(shù)據(jù),這里有個(gè)問(wèn)題就是獲得的天氣數(shù)據(jù)的格式都是  utf8 的,無(wú)法直接顯示在屏上,需要轉(zhuǎn)碼成GBK的,而原子哥的漢字例程就是gbk的。
  utf8轉(zhuǎn)gbk這個(gè)網(wǎng)上也比較少,問(wèn)了很多網(wǎng)友,有人說(shuō)用查表法,于是又去找,僥幸找到了一個(gè)類似的,然后修改了下,居然可以用。
5.圖標(biāo)的制作
  首先自己去選一套漂亮的天氣圖標(biāo),我剛才推薦的那兩個(gè)網(wǎng)站里已經(jīng)為大家準(zhǔn)備了圖標(biāo),可自行下載。
  然后用戰(zhàn)艦光盤里那個(gè)Image2lcd的軟件,選擇輸出灰度為單色,這樣取模以后的數(shù)據(jù)最小。打開你的天氣圖標(biāo),然后點(diǎn)保存,就可以保存為一個(gè)數(shù)組的c文件,將這個(gè)
  數(shù)組添加到你的工程里去。
大體上的難點(diǎn)和知識(shí)點(diǎn)就是上面這些。
上幾張效果圖。一張彩色的,一張白色的,大家覺(jué)得哪個(gè)好看點(diǎn)。
接下來(lái)傳個(gè)演示視頻由于視頻不能播放,先放個(gè)鏈接:http://v.youku.com/v_show/id_XMz ... qq-pf-to=pcqq.group
如果大家感興趣,將會(huì)上傳源碼。
@svwydh 感謝
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "lcd.h"
  6. #include "key.h"
  7. #include "malloc.h"
  8. #include "sdio_sdcard.h"
  9. #include "w25qxx.h"
  10. #include "ff.h"
  11. #include "exfuns.h"
  12. #include "text.h"
  13. #include "touch.h"
  14. #include "usart3.h"
  15. #include "wifista.h"
  16. #include "weather.h"
  17. #include "cJSON.h"
  18. #include "picture.h"
  19. #include "rtc.h"
  20. //static void create_complex(void);
  21. void show_weather(void);
  22. void show_time(void);
  23. int main(void)
  24. {
  25.         u8 key,fontok=0;
  26.         u16 t=0;
  27.         u8 min;
  28.         u8 hour;
  29.         u8 constate=0;        //連接狀態(tài)
  30.         delay_init();                     //延時(shí)函數(shù)初始化
  31.   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置中斷優(yōu)先級(jí)分組為組2:2位搶占優(yōu)先級(jí),2位響應(yīng)優(yōu)先級(jí)
  32.         uart_init(115200);                 //串口初始化為115200
  33.
  34.         LED_Init();                                          //初始化與LED連接的硬件接口
  35.         KEY_Init();                                        //初始化按鍵
  36.         LCD_Init();                                           //初始化LCD
  37.         RTC_Init();
  38.         W25QXX_Init();                                //初始化W25Q128
  39.         tp_dev.init();                                //初始化觸摸屏
  40.         usart3_init(115200);                //初始化串口3
  41.         my_mem_init(SRAMIN);                //初始化內(nèi)部?jī)?nèi)存池
  42.         exfuns_init();                                //為fatfs相關(guān)變量申請(qǐng)內(nèi)存
  43.         f_mount(fs[0],"0:",1);                 //掛載SD卡
  44.         f_mount(fs[1],"1:",1);                 //掛載FLASH.
  45.         key=KEY_Scan(0);
  46.         if(key==KEY0_PRES&&((tp_dev.touchtype&0X80)==0))//強(qiáng)制校準(zhǔn)
  47.         {
  48.                 LCD_Clear(WHITE);                //清屏0
  49.                 TP_Adjust();                          //屏幕校準(zhǔn)
  50.                 TP_Save_Adjdata();
  51.                 LCD_Clear(WHITE);                //清屏
  52.         }
  53.         fontok=font_init();                        //檢查字庫(kù)是否OK
  54.         if(fontok||key==KEY1_PRES)        //需要更新字庫(kù)
  55.         {
  56.                 LCD_Clear(WHITE);                //清屏
  57.                 POINT_COLOR=WHITE;                //設(shè)置字體為紅色
  58.                 LCD_ShowString(60,50,200,16,16,"ALIENTEK STM32");
  59.                 while(SD_Init())                //檢測(cè)SD卡
  60.                 {
  61.                         LCD_ShowString(60,70,200,16,16,"SD Card Failed!");
  62.                         delay_ms(200);
  63.                         LCD_Fill(60,70,200+60,70+16,WHITE);
  64.                         delay_ms(200);
  65.                 }
  66.                 LCD_ShowString(60,70,200,16,16,"SD Card OK");
  67.                 LCD_ShowString(60,90,200,16,16,"Font Updating...");
  68.                 key=update_font(20,110,16,"0:");//從SD卡更新
  69.                 while(key)//更新失敗
  70.                 {
  71.                         LCD_ShowString(60,110,200,16,16,"Font Update Failed!");
  72.                         delay_ms(200);
  73.                         LCD_Fill(20,110,200+20,110+16,WHITE);
  74.                         delay_ms(200);
  75.                 }
  76.                 LCD_ShowString(60,110,200,16,16,"Font Update Success!");
  77.                 delay_ms(1500);
  78.                 LCD_Clear(WHITE);//清屏
  79.         }
  80.
  81. //        create_complex();
  82.         delay_ms(200);
  83.         LED0 = 0;
  84.         show_weather();
  85.         atk_8266_wifista_config();
  86.         printf("wifi init ok!");
  87.         POINT_COLOR = WHITE;
  88.         delay_ms(1000);
  89.         get_current_weather();
  90.         delay_ms(200);
  91.         get_3days_weather();
  92.         min = calendar.min;
  93.         hour = calendar.hour;
  94.         while(1)
  95.         {
  96.                 key = KEY_Scan(0);
  97.                 if(key==KEY0_PRES)
  98.                 {
  99.                         get_current_weather();
  100.                 }
  101.                 else if(key==KEY1_PRES)
  102.                 {
  103.                         get_3days_weather();
  104.                 }
  105.                 else if(key==KEY2_PRES)
  106.                 {
  107.                         get_beijing_time();
  108.                 }
  109.                 delay_ms(10);
  110.                 t++;
  111.                 if(t==1000)
  112.                 {
  113.                         constate=atk_8266_consta_check();//得到連接狀態(tài)
  114.                         t=0;
  115.                 }
  116.                 else if((t%100)==0)
  117.                 {
  118.                         LED1 = !LED1;
  119.                         show_time();
  120.                 }
  121.
  122.                 if(min!=calendar.min)
  123.                 {
  124.                         get_current_weather();
  125.                         min = calendar.min;
  126.                 }
  127.                 if(hour!=calendar.hour)
  128.                 {
  129.                         get_3days_weather();
  130.                         hour = calendar.hour;
  131.                 }
  132.                 atk_8266_at_response(1);
  133.         }
  134. }
  135. //void create_complex(void) {
  136. //        cJSON *root, *rows, *row;
  137. //        char *out;
  138. //        int i = 0;
  139. //
  140. //        char *title[3] = { "樹莓派學(xué)習(xí)筆記-索引博文",
  141. //        "樹莓派學(xué)習(xí)筆記-GPIO功能學(xué)習(xí)",
  142. //        "物聯(lián)網(wǎng)學(xué)習(xí)筆記-索引博文"};
  143. //        char *url[3] = { "http://blog.csdn.net/xukai871105/article/details/23115627",
  144. //        "http://blog.csdn.net/xukai871105/article/details/12684617",
  145. //        "http://blog.csdn.net/xukai871105/article/details/23366187"};
  146. //
  147. //        root = cJSON_CreateObject(); // 創(chuàng)建根
  148. //        cJSON_AddNumberToObject(root, "total", 3);
  149. //
  150. //        // 在object加入array
  151. //        cJSON_AddItemToObject(root, "rows", rows = cJSON_CreateArray());
  152. //
  153. //        for(i = 0; i < 3; i++) {
  154. //        // 在array加入object
  155. //        cJSON_AddItemToArray(rows, row = cJSON_CreateObject());
  156. //        cJSON_AddItemToObject(row, "title", cJSON_CreateString(title[i]));
  157. //        cJSON_AddItemToObject(row, "url", cJSON_CreateString(url[i]));
  158. //        }
  159. //
  160. //        // 打印并釋放
  161. //        out = cJSON_Print(root); cJSON_Delete(root); printf("%s\n",out); my_free(out);
  162. //}
  163. void show_weather(void)
  164. {
  165.         u8 res;
  166.         file = mymalloc(SRAMIN,sizeof(FIL));
  167.         res=f_open(file,(const TCHAR*)APP_ASCII_5427,FA_READ);//打開文件
  168.         if(res==FR_OK)
  169.         {
  170.                 asc2_5427 = mymalloc(SRAMIN,file->fsize);
  171.                 if(asc2_5427 != NULL)
  172.                 {
  173.                         res = f_read(file,asc2_5427,file->fsize,&br);
  174.                 }
  175.                 f_close(file);
  176.         }
  177.         LCD_Clear(BLACK);
  178.         POINT_COLOR = WHITE;
  179.         BACK_COLOR = BLACK;
  180.         Show_Str(0,0,lcddev.width,lcddev.height,"中國(guó)",16,0);
  181.         LCD_ShowString(160,0,lcddev.width,lcddev.height,16,"0000-00-00");
  182.         LCD_ShowString(255,0,lcddev.width,lcddev.height,16,"00:00:00");
  183. //        POINT_COLOR = RED;
  184.         LCD_Draw_Picture(30,5,130,105,(u8 *)gImage_sunny);
  185.         gui_show_num(140,22,2,WHITE,54,0,0x80);
  186. //        POINT_COLOR = WHITE;
  187.         Show_Str(200,25,lcddev.width,lcddev.height,"°",24,0);
  188. //        POINT_COLOR = GBLUE;
  189.         Show_Str(220,25,lcddev.width,lcddev.height,"晴天",16,0);
  190.         Show_Str(220,45,lcddev.width,lcddev.height,"北風(fēng)",16,0);
  191.         Show_Str(220,65,lcddev.width,lcddev.height,"0級(jí)",16,0);
  192.         Show_Str(220,85,lcddev.width,lcddev.height,"風(fēng)速  0Km/h",16,0);
  193. //        POINT_COLOR = WHITE;
  194.         LCD_DrawLine(0,105,lcddev.width,105);
  195.         LCD_DrawLine(105,130,105,220);
  196.         LCD_DrawLine(215,130,215,220);
  197.         LCD_Draw_Picture(0,140,100,240,(u8 *)gImage_sunny);
  198.         LCD_Draw_Picture(110,140,210,240,(u8 *)gImage_sunny);
  199.         LCD_Draw_Picture(220,140,320,240,(u8 *)gImage_sunny);
  200. //        POINT_COLOR = YELLOW;
  201.         Show_Str(30,117,lcddev.width,lcddev.height,"今天",12,0);
  202.         LCD_ShowString(30,130,lcddev.width,lcddev.height,12,"00/00");
  203. //        POINT_COLOR = GREEN;
  204.         Show_Str(140,117,lcddev.width,lcddev.height,"明天",12,0);
  205.         LCD_ShowString(140,130,lcddev.width,lcddev.height,12,"00/00");
  206. //        POINT_COLOR = MAGENTA;
  207.         Show_Str(250,117,lcddev.width,lcddev.height,"后天",12,0);
  208.         LCD_ShowString(250,130,lcddev.width,lcddev.height,12,"00/00");
  209.
  210.         myfree(SRAMIN,file);
  211.         myfree(SRAMIN,asc2_5427);
  212. }
  213. void show_time(void)
  214. {
  215.         LCD_ShowNum(160,0,calendar.w_year,4,16);
  216.         LCD_ShowxNum(200,0,calendar.w_month,2,16,0x80);
  217.         LCD_ShowxNum(224,0,calendar.w_date,2,16,0x80);
  218.         LCD_ShowxNum(255,0,calendar.hour,2,16,0x80);
  219.         LCD_ShowxNum(279,0,calendar.min,2,16,0x80);
  220.         LCD_ShowxNum(303,0,calendar.sec,2,16,0x80);
  221. }
以下是源碼,喜歡的可自行下載。 ESP8266獲取網(wǎng)絡(luò)天氣適配戰(zhàn)艦V3.zip
收藏收藏3 分享淘帖 頂 踩
ID:184978 發(fā)表于 2022-4-16 13:04 | 只看該作者
為什么下載不了呢?
ID:192650 發(fā)表于 2019-8-22 08:51 | 只看該作者
qq23230233 發(fā)表于 2018-11-12 19:04
我想用51單片機(jī)實(shí)現(xiàn)顯示天氣功能,不知道怎么實(shí)現(xiàn)第三步,就這個(gè)天氣服務(wù)器怎么連接,假設(shè)我用python語(yǔ)言自 ...
使用WiFi模塊連接你服務(wù)器獲取數(shù)據(jù)
ID:339500 發(fā)表于 2018-11-12 19:04 | 只看該作者
我想用51單片機(jī)實(shí)現(xiàn)顯示天氣功能,不知道怎么實(shí)現(xiàn)第三步,就這個(gè)天氣服務(wù)器怎么連接,假設(shè)我用python語(yǔ)言自己寫了一個(gè)服務(wù)器,我已經(jīng)把天氣信息寫在服務(wù)器里該怎么連接怎么把數(shù)據(jù)弄給51單片機(jī)是個(gè)問(wèn)題
