查看: 4368|回復(fù): 0
DS1302在數(shù)碼管顯示時(shí),分,秒, 為什么顯示錯(cuò)誤,時(shí)間不走
ID:244748 發(fā)表于 2017-11-27 17:27 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
# include <reg52.h>
# define uchar unsigned char
# define uint unsigned int
sbit        P_HC595_SER   = P2^7;        //pin 14        SER                data input
sbit        P_HC595_RCLK  = P2^5;        //pin 12        RCLk        store (latch) clock
sbit        P_HC595_SRCLK = P2^6;        //pin 11        SRCLK        Shift data clock
sbit rst = P1^0;
sbit io = P1^1;
sbit sclk  = P1^2;
//uchar disp[8];
uchar code t_display[]={
//         0    1    2    3    4    5    6    7    8    9  //
        0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F, 0x40};        // 斷選
uchar code wei[] = {0xfe, 0xfd, 0xfb, 0xf7, 0xef, 0xdf, 0xbf, 0x7f};    //  位選
void Send_595(uchar dat);
void init();
void write_byte(uchar date);
uchar read_byte();
void write_ds1302(uchar add, uchar date);
uchar read_ds1302(uchar add);
void set_ds1302();
void display();
void write_sfm(uchar, uchar);
void delay(uint z);
uchar shi1,shi2,fen1,fen2,miao1,miao2, miao, shi, fen;
        init();
        set_ds1302();
                display();
                //delay(5);
        uint         i;
        for(i=0; i<8; i++)
                if(dat & 0x80)        P_HC595_SER = 1;
                else                        P_HC595_SER = 0;
                P_HC595_SRCLK = 0;
                P_HC595_SRCLK = 1;
                dat = dat << 1;
/***** 數(shù)碼管初始化 ***/
void init()
        Send_595(0x00);
        Send_595(0x00);
        P_HC595_RCLK = 0;
        P_HC595_RCLK = 1;
        rst = 0;
      sclk = 0;
/***** DS1302  寫一個(gè)字節(jié)*****/
        uchar i, temp;
        temp = date;
        for(i=0; i<8; i++)
                if((temp&0x01) == 1)
                        io = 1;
                        io =0;
                sclk = 0;
                sclk = 1;
                temp >>= 1;
/***** DS1302 讀一個(gè)字節(jié)******/
uchar read_byte()
        uchar i, temp;
        for(i=0; i<8; i++)
                temp >>= 1;
                if(io == 1)
                        temp |= 0x01;
                sclk = 1;
                sclk =0;
        return temp;
/****** 特定位置寫 ****/
        rst = 0;
        sclk = 0;
        rst =1;
        write_byte(add);
        write_byte(date);
        sclk = 1;
        rst = 0;
/**** 特定位置讀 ***/
        uchar date;
        rst = 0;
        sclk =0;
        rst = 1;
        write_byte(add);
        date = read_byte();
        sclk = 1;
        rst = 0;
        return date;
/***** DS1302 初始化 **** */
void set_ds1302()
        write_ds1302(0x8e, 0x00);
        write_ds1302(0x80, 0x55);
        write_ds1302(0x82, 0x55);
        write_ds1302(0x84, 0x11);
        write_ds1302(0x8e, 0x80);
/*****  在數(shù)碼管顯示 ***** /
void display()
        uchar d;
        d = read_ds1302(0x81);
        miao =  d;
        write_sfm(6, miao);
        Send_595(wei[2]);
        Send_595(0x40);
        P_HC595_RCLK = 0;
        P_HC595_RCLK = 1;
        delay(2);
        d = read_ds1302(0x83);
        fen = d;
        write_sfm(3, fen);
        Send_595(wei[5]);
        Send_595(0x40);
        P_HC595_RCLK = 0;
        P_HC595_RCLK = 1;
        delay(2);
        d = read_ds1302(0x85);
        shi = d;
        write_sfm(0, shi);
void delay(uint z)
        uint x, y;
        for(x=z; x>0; x--)
          for(y=110; y>0; y--);
/******* 時(shí)分秒 分離個(gè),十位 ***/
void write_sfm(uchar add, uchar date)
        uchar shi, ge;
        shi = date/10;
        ge = date%10;
        Send_595(wei[add]);
        Send_595(t_display[shi]);
        P_HC595_RCLK = 0;
        P_HC595_RCLK = 1;
        delay(2);
        Send_595(wei[add+1]);
        Send_595(t_display[ge]);
        P_HC595_RCLK = 0;
        P_HC595_RCLK = 1;
        delay(2);
顯示的結(jié)果
顯示的結(jié)果
JW-51開發(fā)板.pdf
99.63 KB, 下載次數(shù): 4
