我現(xiàn)在有原理圖,實(shí)物已經(jīng)按照原理圖接線,程序現(xiàn)在有問題,望各位大神指教
#include "reg52.H"
#include <STC89c52.h>
#include <L1602.h>
#include <2402.h>
//聲明常量
#define ALCH 80 //醉駕標(biāo)準(zhǔn)80mg/L
//K_MG_MV和K_ZERO為傳感器校準(zhǔn)系數(shù),要根據(jù)每個(gè)MQ-3模塊校準(zhǔn)
#define K_MG_MV 160/66 //傳感器靈敏度系數(shù),每毫克/L對(duì)應(yīng)的10毫伏數(shù)
#define K_ZERO 15 //傳感器零點(diǎn)漂移,約130mV
//定義按鍵
sbit Key_Up = P3^6;
sbit Key_Down = P3^7;
//定義LED報(bào)警燈
sbit Led_Warn1 = P2^0;
sbit Led_Warn2 = P2^1;
sbit Led_Warn3 = P2^2;
//定義乙醇傳感器TTL電平輸出引腳
sbit DOUT = P1^4;
//定義標(biāo)識(shí)
volatile bit FlagStartAL = 0; //開始轉(zhuǎn)換標(biāo)志
volatile bit FlagKeyPress = 0; //有鍵彈起標(biāo)志
//全局變量定義
uchar Threshold; //酒精濃度上限報(bào)警值
uint ALCounter; //酒精轉(zhuǎn)換計(jì)時(shí)器
long ALValue; //酒精測(cè)量值
float ALtemp; //計(jì)算臨時(shí)變量
uint keyvalue, keyUp, keyDown; //鍵值
char * pSave; //EEPROM存盤用指針
//函數(shù)聲明
void Data_Init();
void Timer0_Init();
void Port_Init();
void ADC_Init();
uchar GetADVal();
void KeyProcess(uint );
//數(shù)據(jù)初始化
void Data_Init()
ALCounter = 0;
ALValue = 0;
Led_Warn1 = 1;
Led_Warn2 = 2;
Led_Warn3 = 3;
keyvalue = 0;
keyUp = 1;
keyDown = 1;
//定時(shí)器0初始化,中斷時(shí)間約2毫秒
//計(jì)算:晶振11.0592MHz,定時(shí)器時(shí)鐘11059200/12=921600,每毫秒922個(gè)脈沖
// 16位定時(shí)器初值65536-1844=63692=0xf8cc
void Timer0_Init()
ET0 = 1; //允許定時(shí)器0中斷
TMOD = 1; //定時(shí)器工作方式選擇
TL0 = 0xcc; //
TH0 = 0xf8; //定時(shí)器賦予初值,大約為2毫秒中斷1次
TR0 = 1; //啟動(dòng)定時(shí)器
//定時(shí)器0中斷
void Timer0_ISR (void) interrupt 1 using 0
TL0 = 0xcc;
//每1秒鐘啟動(dòng)一次AD轉(zhuǎn)換
ALCounter ++;
if (ALCounter >= 500)
FlagStartAL = 1;
ALCounter = 0;
//存入設(shè)定值
void Save_Setting()
pSave = (char *)&Threshold; //地址低位對(duì)應(yīng)低8位,高位對(duì)應(yīng)高8位
wrteeprom(0, *pSave); //存醉酒閾值低8位
DELAY(300);
pSave ++;
wrteeprom(1, *pSave); //存醉酒閾值高8位
DELAY(300);
//載入設(shè)定值
void Load_Setting()
*pSave++ = rdeeprom(0);
*pSave = rdeeprom(1);
if ((Threshold>=255)||(Threshold<0)) Threshold = 80;
//按鍵處理程序,參數(shù)為鍵值,1為Up鍵,2為Down鍵
void KeyProcess(uint num)
switch (num)
case 1:
if (Threshold<255) Threshold++;
break;
case 2:
if (Threshold>1) Threshold--;
break;
default:
break;
L1602_int(2,9,Threshold);
Save_Setting();
uint i,j;
EA = 0;
Data_Init(); //數(shù)據(jù)初始化
Timer0_Init(); //定時(shí)器0初始化
Port_Init(); //端口初始化
ADC_Init(); //ADC初始化
EA = 1;
L1602_init();
L1602_string(1,1,"Welcome to ALCT! ");
L1602_string(2,1,"Designed by AAA ");
//延時(shí)
for (i=0;i<1000;i++)
for (j=0;j<1000;j++)
//清屏
L1602_string(1,1," ");
L1602_string(2,1," ");
L1602_string(1,1,"Alcohol: mg/L");
L1602_string(2,1,"Thresho: mg/L");
//載入設(shè)定值
Load_Setting();
//如果FlagStartAL標(biāo)志置位,則進(jìn)行AD轉(zhuǎn)換
if (FlagStartAL == 1)
//酒精濃度換算,50mg/L=62.5ppm,傳感器靈敏度應(yīng)事先校準(zhǔn)
ALValue = 500 * GetADVal() / 256; //8位ADC,首先得到電壓值,單位10毫伏
ALValue = ALValue - K_ZERO; //首先減去零點(diǎn)漂移,一般是130mV
if (ALValue < 0) ALValue = 0;
ALValue = ALValue * K_MG_MV; //將mV轉(zhuǎn)變成mg/L,K_MG_MV系數(shù)需要校準(zhǔn)
L1602_int(1,9,ALValue);
if (ALValue > Threshold) Led_Warn1 = 0; //超過閾值,則 Led_Warn1燈報(bào)警,否則報(bào)警燈滅。
else Led_Warn1 = 1;
FlagStartAL = 0;
//查詢乙醇傳感器TTL電平,該指示燈為傳感器模塊報(bào)警
if (DOUT == 0) Led_Warn2 = 0;
//鍵盤查詢,在彈起時(shí)響應(yīng)
if ((Key_Up)&&(keyUp==0)) {FlagKeyPress = 1; keyvalue = 1;}
else if ((Key_Down)&&(keyDown==0)) {FlagKeyPress = 1; keyvalue = 2;}
if (FlagKeyPress == 1)
KeyProcess(keyvalue);
FlagKeyPress = 0;
if (!Key_Up) keyUp = 0;
else keyUp = 1;
if (!Key_Down) keyDown = 0;
else keyDown = 1;
DELAY(100);
原理圖
