查看: 2005|回復: 0
任意調整時間的單片機程序,分2次顯示,一次時和秒,一次分鐘和秒
ID:254373 發(fā)表于 2017-11-27 21:05 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
uchar code tab[]=
0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
0x80,0x90};
unsigned char cnt = 0;
unsigned char cnt0 = 0;
unsigned char sec0 = 0;
unsigned char sec1 = 0;
unsigned char sec2 = 0;
bit flag=0;
bit flag0=0;
bit flag1=0;
bit flag1s=0;
sbit key0=P3^2;
sbit key1=P3^3;
sbit key2=P3^4;
sbit key3=P3^5;
void delay(uint ms)
  while(ms--);
sec2=23;
sec1=59;
sec0=55;
  EX0=1;                //外部中斷0
    IT0=1;
        EX1=1;                //外部中斷1
        IT1=1;
        EA = 1;
        TMOD = 0x01;
    TH0=(65536-50000)/256;
    TL0=(655356-50000)%256;
    ET0=1;
        TR0=1;
                P2 = 0x80;P0 = tab[sec0%10];delay(10);P0 = 0xff;
                P2 = 0x40;P0 = tab[sec0/10];delay(10);P0 = 0xff;
           if(flag1s==0)
                      P2 = 0x20;P0 = tab[sec1%10];delay(10);P0 = 0xff;
                      P2 = 0x10;P0 = tab[sec1/10];delay(10);P0 = 0xff;
                          P2 = 0x20;    P0 =0x7f;      delay(10);P0=0xff;
                      P2 = 0x20;P0 = tab[sec2%10];delay(10);P0 = 0xff;
                        P2 = 0x10;P0 = tab[sec2/10];delay(10);P0 = 0xff;
             if((key2==0)&&(flag0==0))
               flag0=1;
                   if((key2==1)&&(flag0==1))
              flag=0;
                          flag1s=0;
                      flag0=0;
                  sec1++;
                  if(sec1==60)
                     sec1 = 0;
                 sec2++;
         if((key3==0)&&(flag1==0))
                   flag1=1;
                   if((key3==1)&&(flag1==1))
                         flag=0;
                         flag1s=1;
                  flag1=0;
                  sec2++;
                  if(sec2==24)
                    sec2 =0;
void t0(void) interrupt 1 using 3
     TH0 = (65536-50000)/256;
         TL0 = (65536-50000)%256;
     cnt++;
    if (cnt >= 20)
            if(flag==1)
         cnt = 0;
                 cnt0++;
                 if(cnt0==5)
                 flag1s=~flag1s;
                 cnt0=0;
                 sec0++;
                  if(sec0==60)
                     sec0=0;
                         sec1++;
                         if(sec1==60)
                           sec1=0;
                           sec2++;
                           if(sec2==24)
                             sec2=0;
void int0_()interrupt 0 using 1
  if(key0==0)
         flag=1;
void int1_()interrupt 2 using 2
   if(key1==0)
         flag=0;
         sec0++;
             if(sec0==60)
             sec0 = 0;
             sec1++;
Powered by 單片機教程網
