搶答器vhdl源程序
查看數(shù): 3795 | 評論數(shù): 2 | 收藏 0
發(fā)布時間: 2017-12-11 14:18
動定義為“開始”(即enable)的開關(guān)后,一排指示燈變亮,之后搶答開始,有4個扳動開關(guān)代表4個搶答器,數(shù)碼管將顯示出最先被扳動的開關(guān)的序號,同時發(fā)出聲音,表示搶答成功。若未按“開始”前,有任意開關(guān)被扳動,則 ...
ID:323384 發(fā)表于 2019-6-3 12:13
真棒真棒真棒
ID:260092 發(fā)表于 2017-12-11 14:20
eached for the definition of "start" (enable) the switch, a row of bright lights changed, after Responder, a four flick of a switch on behalf of four Responder, digital controls are to be shown first to be reached for the switch serial number, also issued voices saying Responder success. If the failure to "start" before it was switched on the flick, Digital Display was the flick of a switch the serial numbers, and issued another voice, someone Responder.
