茉莉星瞳 發(fā)表于 2021-12-30 21:28 這是我掃描的文字,關于2764編程的內容: CAUTION:Exceeding 22V on pin 1(Vpp)will damage the NMC2764. Initially,and after each erasure,all bits of the NMC2764 are in the"1"state.Data is introduced by selectively pro- gramming "Os"into the desired bit locations.Although only"Os"will be programmed,both"1s"and"Os”can be presented in the data word.The only way to change a“o” to a “1”is by ultraviolet light erasure. The NMC2764 is in the programming mode when the Vpp input is at 21V and CE and PGM are both at TTL low. It is re- quired that a 0.1 uF capacitor be placed across Vpp,Vcc and ground to suppress spurious voltage transients which may damage the device.The data to be programmed is ap- plied 8 bits in parallel to the data output pins.The levelsre- quired for the address and data inputs are TTL. For programming,CE should be kept TTL low at all times while Vpp is kept at 21V.When the address and data are stable,a 50 ms(10 ms for the NMC2764H devices)active low TTL program pulse is applied to PGM input.A program pulse must be applied at each address location to be pro- grammed.You can program any location at any time一 either individually,sequentially,or at random.The pro- NMC2764H devices). gram pulse has a maximum width of 55 ms(11 ms for the Programming of multiple NMC2764s in parallel with the ity of the programming requirements.Like inputs of the same data can be easily accomplished due to the simplic- paralleled NMC2764s may be connected together when they are programmed with the same data.A low level TTL pulse applied to the PGM input programs the paralleled NMC2764S. //原文件:可以去alldatasheetcn搜索即可查看 |
茉莉星瞳 發(fā)表于 2021-12-30 21:28 ![]() 第1腳Vpp加22V,27腳PGM接地,進入編程狀態(tài) 按地址Ax,從Dx輸入數據。 |
名字不是重點 發(fā)表于 2021-12-30 17:28 您好,所以在vpp加25v電壓就行了嗎,還有固件調入是不是隨便添加個.bin文件就行了 |
茉莉星瞳 發(fā)表于 2021-12-30 19:36 空白沒有數據肯定不行的,隨便找一個bin文件不難啊 |
hhdsdy 發(fā)表于 2021-12-30 19:02 我在之前就百度添加了一個.bin空白文件,好像沒啥用 |
茉莉星瞳 發(fā)表于 2021-12-30 18:16 不是要給2764添加bin文件,而是要正常顯示,2764需要有數據,實際電路中,只要不是空片,2764里面都會有數據的(原先使用預留下來的),而模擬運行,默認就是空片的,需要自己添加,添加的文件格式應該就是bin格式的。 沒有模擬運行過2764,應該和單片機一樣,2764右鍵-編輯屬性,在Program File:的后面點文件夾圖標,找到對應的2764添加數據進去就可以了。 添加隨意一個bin文件即可,只要文件大小不要超過2764的容量,總有一些數據可以顯示出來的,如果想讓它按自己的意愿顯示,就要使用二進制編輯軟件修改bin文件里的內容了,這個比較復雜,自己百度一下吧(包括4511的邏輯關系)。 |
hhdsdy 發(fā)表于 2021-12-30 17:36 問題就在這兒了,我查到好像要給2764添加一個.bin文件,然后這個文件里要寫入一堆數據,我不知道這個咋弄,你知道嗎大哥教教我,我在百度找不見啊 |
hhdsdy 發(fā)表于 2021-12-30 10:58 換成29系列或者28系列的吧!29系列以前老電腦主板的CMOS芯片用的,很容易找到 |
茉莉星瞳 發(fā)表于 2021-12-30 14:25 那是因為2764輸出的是11111111,按CD4511的邏輯關系,進入消隱不顯示狀態(tài)了,你把2764的數據更改試試就看得到效果了,也可能是A8到A12的引腳需要接+5V |
你確定這個圖紙能用的嗎?我總覺的有點懸。。 2764做為高壓才能編程的器件,你這圖中沒有高壓電源。所以,2764在這圖中只能做為只讀,并不能寫入!你的2764有固件已調入了嗎? 你AD0808的數據經573鎖存到的 是2764的地址線上,所以在圖中的573其實是可以不要的. |
冰火風輪 發(fā)表于 2021-12-30 16:21 不知道為啥,我的proteus里用不了啊,能找到這個元件,但是報錯說沒有這個模型 |
茉莉星瞳 發(fā)表于 2021-12-30 15:44 不是回了么,28c64 接近 RAM 操作,片擦除才用到 12V |
冰火風輪 發(fā)表于 2021-12-30 14:48 那您能幫我看看,有沒有什么辦法可以把這個元件替換成不用燒寫時序,然后就可以讓電路正常工作的元件嗎 |
wc86110 發(fā)表于 2021-12-30 15:28 圖應該沒錯啊 |
冰火風輪 發(fā)表于 2021-12-30 14:48 您好,這個燒寫時序應該怎么做啊 |
仿真圖不對,數碼管又有何用 |
2764 要 25V(27C64 要 12.5V)的編程燒寫電壓,還要求燒寫時序,28C64 才是 5V 的 |
最近也在用,同問 |
茉莉星瞳 發(fā)表于 2021-12-30 12:48 2764沒用的A8到A12一定要接(看你存儲的數據地址在哪),一般來說就接地吧,但是存儲的數據也要在這個范圍內; CE是片選引腳,低電平有效,所以這個引腳一定要接地; PGM和VPP是編程寫入時用的,讀數據時一般是接+5V的(OE還是接地不動)。 |
需要21V或者12V高壓燒寫的。 |
上網搜“串行EEPROM芯片”或“并行EEPROM芯片”、“串行Flah芯片”或“并行Flah芯片”,有大量型號。而且也能搜到大量例程,使用不算太困難。如今通常,使用紫外線擦除的EPROM沒有必要。 |
2764是紫外線擦除的EPROM。太老了?捎秒姴脸鼸EPROM或FLash芯片代替,與單片機接口方式,串行、并行的均有。 |
沒有電路圖,不知道你是怎么接的,不好說。 2764(27C64)是紫外線擦除的只讀存儲器,空片也就只能寫一次,再寫就數據錯亂了(沒有擦除的原因),需要隨時讀寫的需要換別的類型的存儲器,比如6264(斷電丟失數據)等。 |
