汽車空調(diào)程序
- #include "gw801.h"
- void interrupt timer1(void)//中斷服務(wù)程序
- if(TMR1IF)//timer
- wdcheck=wdcheck|0x80;
- TMR1IF=0;
- TMR1H=0xf6;
- TMR1L=0x3b;
- T1CON=T1CON|0x30;
- kbit=1;
- // LED_RDEF=!LED_RDEF;
- if(tmr_delay>0) tmr_delay--;
- if(tmr_ccpr>0) tmr_ccpr--;
- if(tempdtmr>0) tempdtmr--;
- if(tempsttmr>0) tempsttmr--;
- if(modedtmr>0) modedtmr--;
- if(modesttmr>0) modesttmr--;
- if(intakesttmr>0) intakesttmr--;
- if(mem_tmr>0) mem_tmr--;
- if(tmr_test>0) tmr_test--;
- if(((amb<30)||(amb>1000))&&(tmr_amb_error<1000)) tmr_amb_error++;
- else if(((amb>30)&&(amb<1000))&&(tmr_amb_error>0)) tmr_amb_error--;
- if(((incar<30)||(incar>1000))&&(tmr_incar_error<1000)) tmr_incar_error++;
- else if(((incar>30)&&(incar<1000))&&(tmr_incar_error>0)) tmr_incar_error--;
- if(((evap<30)||(evap>1000))&&(tmr_evap_error<1000)) tmr_evap_error++;
- else if(((evap>30)&&(evap<1000))&&(tmr_evap_error>0)) tmr_evap_error--;
- if(((tempfb<5)||(tempfb>250))&&(tmr_temp_error<1000)) tmr_temp_error++;
- else if(((tempfb>5)&&(tempfb<250))&&(tmr_temp_error>0)) tmr_temp_error--;
- if(((modefb<5)||(modefb>250))&&(tmr_mode_error<1000)) tmr_mode_error++;
- else if(((modefb>5)&&(modefb<250))&&(tmr_mode_error>0)) tmr_mode_error--;
- if(tmr_system>0) tmr_system--;
- else
- tmr_system=500;
- adj|=0x3f;
- if(sensor_adtimer!=0) sensor_adtimer--;
- else
- sensor_adtimer=50;
- adj|=0x20;
- void port_init(void)
- __CONFIG(0x0f7c);
- __CONFIG(0xcaff);
- OSCCON=0x73; //IRCF2-0:101=2M 110=4M 111=8M SCS=1 由內(nèi)部時(shí)鐘作為震蕩器
- LCDREF=0x00;
- T0CS=0;
- CM1CON0=0X00; //關(guān)閉比較寄存器
- CM2CON0=0X00; //關(guān)閉比較寄存器
- WDTCON=0x12; //1024分平 2*10/2*5=2*5=32ms
- PSA=0; //將欲分頻 分配給定時(shí)器0
- SWDTEN=1; //啟動(dòng)WDT ???
- TRISA=0xb3;
- PORTA=0x4c;
- TRISB=0xfe;
- PORTB=0x01;
- TRISC=0xbb;
- PORTC=0x00;
- TRISD=0x00;
- PORTD=0xfe;
- TRISE=0x00;
- PORTE=0x03;
- TRISF=0xe2;
- PORTF=0xed;
- TRISG=0xf0;
- PORTG=0x00;
- void pwm_init(void)
- CCPTMRS0=0x3c; //ccp1:tmr2,ccp3:tmr2
- CCPTMRS1=0x03; //ccp1:tmr2,ccp3:tmr2
- PR2=0x80;//====PWM周期:2M/64=31.25K
- CCPR1L=126;
- blowernow=126;
- blowertg=126;
- CCPR4L=10;
- T2CON=0x6;//T2 ON ,PRESCALE 16,POSTSCALE 1
- CCP1CON=0x0f;//設(shè)定CCP1為pwm mode
- CCP4CON=0x0f;//設(shè)定CCP3為pwm mode
- CCP2CON=0x05;//設(shè)定CCP3為capture mode
- TMR2IE=0;//定時(shí)器2中斷:不允許
- void ad_init(void)
- { //由ADCON1.ADCS2和ADCON0.ADCS0,ADCON0.ADCS1確定分頻=FOSC/16
- ANSELA=0x03; //配置模擬輸入口
- ANSELE=0x00;
- ANSELF=0xe2; //配置模擬輸入口
- ANSELG=0x10; //配置模擬輸入口
- ADCON0=0x01; //ADFM=1(right),Vref-=Vss,Vref+=Vdd,GO/DOWN=0,ADON=0
- ADCON1=0xa0;
- void int_init(void)
- INTCON=0x0; //全局中斷、外部設(shè)備禁止
- TMR1H=0xf6;
- TMR1L=0x3b;
- T1CON=0x10;
- TMR1IF=0; //清TMR1溢出標(biāo)志
- TMR1IE=1; //允許TMR1中斷
- TMR1ON=1; //star TMR1
- CCP1IE=0; //不允許捕獲 比較
- PEIE=1; //允許外設(shè)中斷
- GIE=1; //全局中斷、外部設(shè)備允許
- void comm_init (void)
- TRISC7=1;
- TRISC6=0;
- TX1STA=0x20;
- SP1BRGL=0x33;//2400bpr
- RC1STA=0x90;
- RCIE=0;//接收中斷允許
- PEIE=1;//
- GIE=1; //
- void ad_sample(void)
- switch(channel)
- case 0:
- ADCON0=0x01;//channel=0
- nop();
- nop();
- nop();
- nop();
- GO_nDONE=1;
- while(GO_nDONE) continue;
- amb=((ADRESH*256)+ADRESL)&0x03ff;
- channel=1;
- break;
- case 1:
- ADCON0=0x05;//channel=1
- nop();
- nop();
- nop();
- nop();
- GO_nDONE=1;
- modefb=(((ADRESH*256)+ADRESL)&0x03ff)>>2;
- channel=2;
- break;
- case 2:
- ADCON0=0x15;//channel=5
- nop();
- nop();
- nop();
- nop();
- GO_nDONE=1;
- incar=(((ADRESH*256)+ADRESL)&0x03ff);
- channel=3;
- break;
- case 3:
- ADCON0=0x19;//channel=6
- nop();
- nop();
- nop();
- nop();
- GO_nDONE=1;
- ig=((((ADRESH*256)+ADRESL)&0x03ff));
- channel=4;
- break;
- case 4:
- ADCON0=0x29;//channel=10
- nop();
- nop();
- nop();
- nop();
- GO_nDONE=1;
- blowerfb=((ADRESH*256)+ADRESL)&0x03ff;
- channel=5;
- break;
- case 5:
- ADCON0=0x2d;//channel=11
- nop();
- nop();
- nop();
- nop();
- GO_nDONE=1;
- evap=((ADRESH*256)+ADRESL)&0x03ff;
- channel=6;
- break;
- case 6:
- ADCON0=0x31;//channel=12
- nop();
- nop();
- nop();
- nop();
- GO_nDONE=1;
- tempfb=(((ADRESH*256)+ADRESL)&0x03ff)>>2;
- channel=0;
- break;
- default:
- channel=0;
- break;
- void tavgw_CONVERT(void)
- signed char dif;
- signed int i;
- i=tavg_wstable-tavg;
- if(i>40)
- dif=tavgw_table[80];
- else if(i<-40)
- dif=tavgw_table[0];
- else
- dif=tavgw_table[i+40];
- tavg_w=tavg_wstable+dif;
- void tavg_CONVERT(void)
- signed char i;
- if(tamb>30) i=-1;
- else if(tamb>20) i=-1;
- else if(tamb>10) i=-1;
- else if(tamb>-0) i=-2;
- else if(tamb>-10) i=-3;
- else if(tamb>-20) i=-3;
- else i=-3;
- tavg=(tinc+i)*2;
- signed int evapSENSOR_CONVERT(unsigned int vol)
- unsigned int i;
- signed int thermo;
- if(vol>910) thermo=-30;
- else if(vol<229) thermo=60;
- else
- i=90;
- do
- i--;
- } while(vol>=evapsensor_table[i]);
- thermo=i-30;
- return thermo;
- signed int ambSENSOR_CONVERT(unsigned int vol)
- unsigned int i;
- if(vol>958) thermo=-30;
- else if(vol<252) thermo=60;
- else
- i=90;
- do
- i--;
- } while(vol>=ambsensor_table[i]);
- thermo=i-30;
- return thermo;
- signed int incarSENSOR_CONVERT(unsigned int vol)
- unsigned int i;
- if(vol>956) thermo=-30;
- else if(vol<254) thermo=60;
- else
- i=90;
- do
- i--;
- } while(vol>=incarsensor_table[i]);
- thermo=i-30;
- return thermo;
- signed int tout_CONVERT(signed int vol1,unsigned char vol2,signed int vol3)//tout(tamb,tidef_effect,tavg_w)
- signed long int k;
- signed long int b;
- k=((vol1*7)/10)+190;
- b=-(95*vol1)-850;
- thermo=(signed long int)(k*(vol3-vol2)+(b*2))/20;
- return thermo;
- void sensor_init(void)
- unsigned char i;
- for(i=0;i<4;i++)
- {amb_table[i]=amb;}
- tamb=ambSENSOR_CONVERT(amb);
- for(i=0;i<4;i++)
- {incar_table[i]=incar;}
- tinc=incarSENSOR_CONVERT(incar);
- for(i=0;i<4;i++)
- {evap_table[i]=evap;}
- tevap=evapSENSOR_CONVERT(evap);
- tavg_CONVERT();
- tavg_wstable=tset*2;
- tavgw_CONVERT();
- tout=tout_CONVERT(tamb,tidef_effect,tavg_w);
- spi_data|=SENSOR_ON;
- adj|=0x3f;
- void error_test(void)
- if(tmr_incar_error>500) {tinc=20;error_mode|=0x01;}
- else error_mode&=0xfe;
- if(tmr_amb_error>500) {tamb=20;error_mode|=0x02;}
- else error_mode&=0xfd;
- if(tmr_evap_error>500) {tevap=-2;error_mode|=0x04;}
- if(tmr_mode_error>500)error_mode|=0x08;
- else error_mode&=0xfb;
- if(tmr_temp_error>500)error_mode|=0x10;
- else error_mode&=0xf7;
- void sensor_process(void)
- unsigned char i=0;
- signed int sum;
- if(adj&0x20)
- for(i=0;i<3;i++) //amb
- {amb_table[i]=amb_table[i+1];}
- amb_table[3]=amb;
- sum=0;
- for(i=0;i<4;i++)
- {sum=sum+amb_table[i];}
- sum=sum/4;
- tamb=ambSENSOR_CONVERT(sum);
- for(i=0;i<3;i++) //incar
- {evap_table[i]=evap_table[i+1];}
- evap_table[3]=evap;
- sum=0;
- for(i=0;i<4;i++)
- {sum=sum+evap_table[i];}
- sum=sum/4;
- tevap=evapSENSOR_CONVERT(sum);
- {incar_table[i]=incar_table[i+1];}
- incar_table[3]=incar;
- sum=0;
- for(i=0;i<4;i++)
- {sum=sum+incar_table[i];}
- sum=sum/4;
- tinc=incarSENSOR_CONVERT(sum);
- error_test();
- tavg_CONVERT();
- tavgw_CONVERT();
- adj&=0xdf;
- unsigned int LOOP_LS166(void)
- unsigned char jjj;
- jjj=0xff;
- if(KEY_OFF==0) jjj&=KOFF;
- if(KEY_AUTO==0) jjj&=KAUTO;
- if(KEY_REC==0) jjj&=KREC;
- if(KEY_AC==0) jjj&=KAC;
- if(KEY_DEF==0) jjj&=KDEF;
- return jjj;
- void key_scan(void)
- keynew=LOOP_LS166();
- if(kbit>0)
- if(keynew!=0xff)
- if(keyold==keynew)
- keyyear++;
- if(!response)
- if(keynew==KTEST)
- if(keyyear>=KEY_TIMELONG)
- keyyear=0;
- response=1;
- keycom=keyold;
- else if(keyyear>=KEY_TIME)
- keyyear=0;
- response=1;
- keycom=keyold;
- else
- keyyear=0;
- keycom=0xff;
- else
- response=0;
- keyold=keynew;
- keyyear=0;
- else
- keyold=keynew;
- response=0;
- keyyear=0;
- kbit=0;
- void key_process (void)
- if(keycom!=0xff)
- mem_tmr=20;
- memflag=1;
- adj|=0x3f;
- if(test_mode)
- switch(keycom)
- case KAUTO:
- test_mode=0;
- break;
- default:
- break;
- else
- switch(keycom)
- case KAC:
- if(sys_mode&0x80)
- sys_mode&=0x77;
- ac_func&=0x7f;
- ac_func|=0x08;
- ac_old=ac_func;
- else
- sys_mode&=0xf7;
- ac_func&=0x7f;
- if(ac_func&0x08) ac_func&=0xf7;
- else ac_func|=0x08;
- ac_old=ac_func;
- break;
- case KDEF:
- if(sys_mode&0x80)
- sys_mode&=0x7f;
- if(mode_func!=0x04)
- mode_old=mode_func;
- ac_old=ac_func;
- blower_old=blower_func;
- intake_old=intake_func;
- mode_func=0x4;
- blower_func=0x07;
- intake_func=0x01;
- ac_func=0x08;
- break;
- else
- if(mode_func!=4)
- ac_old=ac_func;
- mode_func=0x4;
- blower_func=0x07;
- intake_func=0x01;
- ac_func=0x08;
- else
- mode_func=mode_old;
- blower_func=blower_old;
- intake_func=intake_old;
- ac_func=ac_old;
- break;
- case KREC:
- sys_mode&=0xf7;
- if((intake_func&0x7f)==0x00) intake_func=0x01;
- else intake_func=0x00;
- break;
- case KOFF:
- sys_mode|=0X80;
- break;
- case KAUTO:
- sys_mode=0x08;
- mode_func|=0x80;
- blower_func|=0x80;
- ac_func|=0x80;
- intake_func|=0x80;
- break;
- case KTEST:
- test_mode=1;
- tmr_test=0;
- break;
- default:
- keycom=0xff;
- break;
- keycom=0xffff;
- void temp_scan(void)
- KEY_TUP=1;
- if(KEY_TUP==1)
- {temp_scan1=1;tmr_tup=0;}
- if((KEY_TUP==0)&&(temp_scan1==1))
- tmr_tup++;
- if(tup==0)
- if((tmr_tup>KEYT_TIME)&&(keycom1==0xff))
- tmr_tup=0;
- keycom1=0;
- tup=1;
- else
- tmr_tup=0;
- keycom1=0xff;
- else
- tmr_tup=0;
- tup=0;
- KEY_TDN=1;
- if(KEY_TDN==1)
- {temp_scan2=1;tmr_tdn=0;}
- if((KEY_TDN==0)&&(temp_scan2==1))
- tmr_tdn++;
- if(tdn==0)
- if((tmr_tdn>KEYT_TIME)&&(keycom2==0xff))
- tmr_tdn=0;
- keycom2=0;
- tdn=1;
- else
- tmr_tdn=0;
- keycom2=0xff;
- else
- tmr_tdn=0;
- tdn=0;
- KEY_MUP=1;
- if(KEY_MUP==1)
- {mode_scan1=1;tmr_mup=0;}
- if((KEY_MUP==0)&&(mode_scan1==1))
- tmr_mup++;
- if(mup==0)
- if((tmr_mup>KEYT_TIME)&&(keycom5==0xff))
- tmr_mup=0;
- keycom5=0;
- mup=1;
- else
- tmr_mup=0;
- keycom5=0xff;
- else
- tmr_mup=0;
- mup=0;
- KEY_MDN=1;
- if(KEY_MDN==1)
- {mode_scan2=1;tmr_mdn=0;}
- if((KEY_MDN==0)&&(mode_scan2==1))
- tmr_mdn++;
- if(mdn==0)
- if((tmr_mdn>KEYT_TIME)&&(keycom6==0xff))
- tmr_mdn=0;
- keycom6=0;
- mdn=1;
- else
- tmr_mdn=0;
- keycom6=0xff;
- else
- tmr_mdn=0;
- mdn=0;
- KEY_BUP=1;
- if(KEY_BUP==1)
- {blow_scan1=1;tmr_bup=0;}
- if((KEY_BUP==0)&&(blow_scan1==1))
- tmr_bup++;
- if(bup==0)
- if((tmr_bup>KEYT_TIME)&&(keycom3==0xff))
- tmr_bup=0;
- keycom3=0;
- bup=1;
- else
- tmr_bup=0;
- keycom3=0xff;
- else
- tmr_bup=0;
- bup=0;
- KEY_BDN=1;
- if(KEY_BDN==1)
- {blow_scan2=1;tmr_bdn=0;}
- if((KEY_BDN==0)&&(blow_scan2==1))
- tmr_bdn++;
- if(bdn==0)
- if((tmr_bdn>KEYT_TIME)&&(keycom4==0xff))
- tmr_bdn=0;
- keycom4=0;
- bdn=1;
- else
- tmr_bdn=0;
- keycom4=0xff;
- else
- tmr_bdn=0;
- bdn=0;
- if((keycom1==0)&&(test_mode==0))
- if(!(sys_mode&0x80))
- if((sys_mode&0x03)==0x01)
- ac_func=ac_old;
- tset=20;
- sys_mode&=0xfc;
- else if(tset<30) tset=tset+2;
- else if((sys_mode&0x03)==0x02);
- else //hi
- sys_mode=(sys_mode&0xfc)|0x02;
- ac_old=ac_func;
- mode_func=0x2;
- blower_func=0x07;
- intake_func=0x01;
- ac_func=0x00;
- adj|=0x3f;
- mem_tmr=20;
- memflag=1;
- keycom1=0xff;
- if((keycom2==0)&&(test_mode==0))
- if((sys_mode&0x03)==0x02)
- ac_func=ac_old;
- tset=30;
- sys_mode&=0xfc;
- else if(tset>20) tset=tset-2;
- else if((sys_mode&0x03)==0x01);
- else //lo
- sys_mode=(sys_mode&0xfc)|0x01;
- ac_old=ac_func;
- mode_func=0x0;
- blower_func=0x07;
- intake_func=0x00;
- ac_func=0x08;
- adj|=0x3f;
- mem_tmr=20;
- memflag=1;
- keycom2=0xff;
- if((keycom3==0)&&(test_mode==0))
- sys_mode&=0xf7;
- blower_func&=0x7f;
- if(blower_func<8) blower_func++;
- adj|=0x3f;
- else sys_mode&=0x7f;
- mem_tmr=20;
- memflag=1;
- keycom3=0xff;
- if((keycom4==0)&&(test_mode==0))
- sys_mode&=0xf7;
- if(blower_func>1) blower_func--;
- adj|=0x3f;
- mem_tmr=20;
- memflag=1;
- keycom4=0xff;
- if((keycom5==0)&&(test_mode==0))
- if(sys_mode&0x80)
- sys_mode&=0x7f;
- else
- if(mode_func==0x04)
- ac_func=ac_old;
- else
- sys_mode&=0xf7;
- mode_func&=0x7f;
- if(mode_func<3) mode_func++;
- mem_tmr=20;
- memflag=1;
- keycom5=0xff;
- if((keycom6==0)&&(test_mode==0))
- if(sys_mode&0x80)
- sys_mode&=0x7f;
- else
- ac_func=ac_old;
- else
- sys_mode&=0xf7;
- mode_func&=0x7f;
- if(mode_func>0) mode_func--;
- mem_tmr=20;
- memflag=1;
- keycom6=0xff;
- void ac_drv(void)
- if((sys_mode&0x80)==0x00)
- if((ac_func&0x80)&&(!(sys_mode&0x03)))
- if(adj&0x01)
- if(tamb>=((tout-20)/10)) ac_func|=0x08;
- if(tamb<((tout-40)/10)) ac_func&=0xf7;
- adj&=0xfe;
- if(tamb<0) ac_func&=0xf7;
- if(ac_func&0x08)
- ac_func|=0x01;
- else ac_func&=0xfe;
- if(ac_func&0x01)
- spi_data|=AC_ON;
- else
- spi_data&=AC_OFF;
- void intake_proc(void)
- if((intake_func&0x80)&&(!(sys_mode&0x03)))
- if((adj&0x08)&&(!(sys_mode&0x20)))
- if(ac_func&0x08) intake_func=0x80; //內(nèi)循環(huán)
- else intake_func=0x81;
- adj&=0xf7;
- void mode_proc(void) //tout<29vent,tout>31mix
- if((mode_func&0x80)&&(!(sys_mode&0x03)))
- if(adj&0x02)
- if(tout<=290) mode_func=0x80;//vent
- if((tout>=310)&&(tout<=360)) mode_func=0x81;//bi
- if(tout>=380) mode_func=0x82;//foot
- if((tout<310)&&(tout>290))
- {if((mode_func!=0x80)&&(mode_func!=0x81))
- mode_func=0x80;}
- if((tout<380)&&(tout>360))
- {if((mode_func!=0x82)&&(mode_func!=0x81))
- mode_func=0x82;}
- adj&=0xfd;
- modetg=mode_table[mode_func&0x7];
- unsigned char Angle_convet(signed int t1,signed int t2,unsigned char a1,unsigned char a2,signed int t3)
- signed char a3;
- signed long int i;
- //k=((a2-a1)*1000)/(t2-t1);
- k=(signed long int)a2-a1;
- k=k*100;
- i=t2-t1;
- k=k/i;
- b=(signed long int)a1*100;
- i=(signed long int)k*t1;
- b=b-i;
- a3=((k*t3)+b)/100;
- return a3;
- void temp_proc(void)
- unsigned char i;
- signed char j;
- signed int tout1;
- signed int tout2;
- signed int tout3;
- signed int tout4;
- signed int tout5;
- signed int tout6;
- if(ac_func&0x01)
- tevap=5;
- else if(intake_func&0x7f)
- tevap=tamb+2;
- else
- tevap=tinc+2;
- if((sys_mode&0x03)==0x01) temptg=TEMP_MAX; //cool
- else if((sys_mode&0x03)==0x02) temptg=TEMP_MIN; //heat
- else if(adj&0x10)
- if(tevap<=-20)
- {i=0;j=-30;}
- else if(tevap<=-10)
- {i=6;j=-20;}
- else if(tevap<=0)
- {i=12;j=-10;}
- else if(tevap<=10)
- {i=18;j=0;}
- else if(tevap<=20)
- {i=24;j=10;}
- else if(tevap<=30)
- {i=30;j=20;}
- else
- {i=36;j=30;}
- if((mode_func&0xf)<=1)
- tout1=((atempvent_table[i+6]-atempvent_table[i])*(tevap-j))/10+atempvent_table[i];
- tout2=((atempvent_table[i+7]-atempvent_table[i+1])*(tevap-j))/10+atempvent_table[i+1];
- tout3=((atempvent_table[i+8]-atempvent_table[i+2])*(tevap-j))/10+atempvent_table[i+2];
- tout4=((atempvent_table[i+9]-atempvent_table[i+3])*(tevap-j))/10+atempvent_table[i+3];
- tout5=((atempvent_table[i+10]-atempvent_table[i+4])*(tevap-j))/10+atempvent_table[i+4];
- tout6=((atempvent_table[i+11]-atempvent_table[i+5])*(tevap-j))/10+atempvent_table[i+5];
- else
- tout1=((atempfoot_table[i+6]-atempfoot_table[i])*(tevap-j))/10+atempfoot_table[i];
- tout2=((atempfoot_table[i+7]-atempfoot_table[i+1])*(tevap-j))/10+atempfoot_table[i+1];
- tout3=((atempfoot_table[i+8]-atempfoot_table[i+2])*(tevap-j))/10+atempfoot_table[i+2];
- tout4=((atempfoot_table[i+9]-atempfoot_table[i+3])*(tevap-j))/10+atempfoot_table[i+3];
- tout5=((atempfoot_table[i+10]-atempfoot_table[i+4])*(tevap-j))/10+atempfoot_table[i+4];
- tout6=((atempfoot_table[i+11]-atempfoot_table[i+5])*(tevap-j))/10+atempfoot_table[i+5];
- if(tout<=tout1) temptg=TEMP_MAX;//coo
- else if(tout<=tout2)temptg=Angle_convet(tout1,tout2,ATEMP1,ATEMP2,tout);
- else if(tout<=tout3)temptg=Angle_convet(tout2,tout3,ATEMP2,ATEMP3,tout);
- else if(tout<=tout4)temptg=Angle_convet(tout3,tout4,ATEMP3,ATEMP4,tout);
- else if(tout<=tout5)temptg=Angle_convet(tout4,tout5,ATEMP4,ATEMP5,tout);
- else if(tout<=tout6)temptg=Angle_convet(tout5,tout6,ATEMP5,ATEMP6,tout);
- else temptg=TEMP_MIN;//hot
- adj&=0xef;
- void blower_proc(void)
- signed char i;
- signed char j;
- unsigned char l;
- unsigned char blowertg1;
- unsigned char blowertg2;
- if((blower_func&0x80)&&(!(sys_mode&0x03)))
- if(adj&0x04)
- l=(((tset*2)-tidef_effect)/2)-10;
- if(tamb>=40)
- blowertg1=blow_autotable40[l];
- blowertg2=blow_autotable40[l];
- i=40;
- j=40;
- else if(tamb>=30)
- blowertg2=blow_autotable30[l];
- i=30;
- j=40;
- else if(tamb>=20)
- blowertg1=blow_autotable30[l];
- blowertg2=blow_autotable20[l];
- i=20;
- j=30;
- else if(tamb>=10)
- blowertg1=blow_autotable20[l];
- blowertg2=blow_autotable10[l];
- i=10;
- j=20;
- else if(tamb>=0)
- blowertg1=blow_autotable10[l];
- blowertg2=blow_autotable0[l];
- i=0;
- j=10;
- else if(tamb>=-10)
- blowertg1=blow_autotable0[l];
- blowertg2=blow_autotablen10[l];
- i=-10;
- j=0;
- else if(tamb>=-20)
- blowertg1=blow_autotablen10[l];
- blowertg2=blow_autotablen20[l];
- i=-20;
- j=-10;
- else
- blowertg1=blow_autotablen20[l];
- blowertg2=blow_autotablen30[l];
- i=-30;
- j=-20;
- if(blowertg1>=blowertg2)
- blowertg=blowertg2+((abs_delta(blowertg1,blowertg2)*(tamb-i))/10);
- else
- blowertg=blowertg1+((abs_delta(blowertg1,blowertg2)*(j-tamb))/10);
- adj&=0xfb;
- i=6;
- do
- i--;
- } while(blowertg>blow_table[i]);
- blower_func=(i+2)|0x80;
- if(blower_func>=0x87) blower_func=0x86;
- void blower_drv(void)
- if(sys_mode&0x80)
- CCPR1L=110;
- blowernow=110;
- blowertg=110;
- BLC=0;
- spi_data&=HS_OFF;
- else if(blower_func&0x80)
- BLC=1;
- spi_data&=HS_OFF;
- else if((blower_func&0x7f)==8)
- blowertg=0;
- BLC=1;
- if(CCPR1L==0)
- spi_data|=HS_ON;
- else spi_data&=HS_OFF;
- else
- blowertg=blow_table[(blower_func&0x7f)-1];
- BLC=1;
- spi_data&=HS_OFF;
- if (tmr_ccpr==0)
- if(blowernow<blowertg) blowernow++;
- else if(blowernow>blowertg) blowernow--;
- if(CCPR1L!=blowernow) CCPR1L=blowernow;
- tmr_ccpr=5;
- void temp_drv(void)
- unsigned char tempmin;
- unsigned char tempmax;
- if((TEMP_MAX-temptg)>30) tempmax=temptg+30;
- else tempmax=TEMP_MAX;
- if((temptg-TEMP_MIN)>30) tempmin=temptg-30;
- else tempmin=TEMP_MIN;
- switch (tempws_mode)
- case 0:
- temptgn=temptg;
- if (temptgn>temptgo)
- tempsttmr=STALLTMR;
- tempws_mode=1;
- spi_data&=TOFF;
- spi_data|=TUP;
- temptgo=temptgn;
- else if (temptgn<temptgo)
- tempws_mode=2;
- spi_data&=TOFF;
- spi_data|=TDN;
- temptgo=temptgn;
- else
- spi_data&=TOFF;
- spi_data|=TSTOP;
- break;
- case 1:
- if(tempfb>tempmax)
- tempws_mode=0;
- spi_data&=TOFF;
- spi_data|=TSTOP;
- temptgo=tempfb;
- else if(tempsttmr==0)
- spi_data&=TOFF;
- spi_data|=TSTOP;
- tempws_mode=0;
- temptgo=temptgn;
- else if(temptg!=temptgn) tempws_mode=0;
- else if (temptgn==tempfb)
- spi_data&=TOFF;
- spi_data|=TSTOP;
- tempws_mode=0;
- temptgo=tempfb;
- break;
- case 2:
- if(tempfb<tempmin)
- tempws_mode=0;
- spi_data&=TOFF;
- spi_data|=TSTOP;
- temptgo=tempfb;
- spi_data&=TOFF;
- spi_data|=TSTOP;
- tempws_mode=0;
- temptgo=temptgn;
- spi_data&=TOFF;
- spi_data|=TSTOP;
- tempws_mode=0;
- break;
- default:
- tempws_mode=0;
- break;
- void mode_drv(void)
- unsigned char modemin;
- unsigned char modemax;
- if((MODE_MAX-modetg)>30) modemax=modetg+30;
- else modemax=MODE_MAX;
- if((modetg-MODE_MIN)>30) modemin=modetg-30;
- else modemin=MODE_MIN;
- switch (modews_mode)
- case 0:
- modetgn=modetg;
- if (modetgn>modetgo)
- modesttmr=STALLTMR;
- modews_mode=1;
- spi_data&=MOFF;
- spi_data|=MUP;
- modetgo=modetgn;
- else if (modetgn<modetgo)
- modews_mode=2;
- spi_data&=MOFF;
- spi_data|=MDN;
- modetgo=modetgn;
- else
- spi_data&=MOFF;
- spi_data|=MSTOP;
- break;
- case 1:
- if(modefb>modemax)
- modews_mode=0;
- spi_data&=MOFF;
- spi_data|=MSTOP;
- modetgo=modefb;
- else if(modesttmr==0)
- spi_data&=MOFF;
- spi_data|=MSTOP;
- modews_mode=0;
- modetgo=modetgn;
- else if(modetg!=modetgn) modews_mode=0;
- else if (modetgn==modefb)
- spi_data&=MOFF;
- spi_data|=MSTOP;
- modews_mode=0;
- modetgo=modefb;
- break;
- case 2:
- if(modefb<modemin)
- modews_mode=0;
- spi_data&=MOFF;
- spi_data|=MSTOP;
- modetgo=modefb;
- spi_data&=MOFF;
- spi_data|=MSTOP;
- modews_mode=0;
- modetgo=modetgn;
- spi_data&=MOFF;
- spi_data|=MSTOP;
- modews_mode=0;
- break;
- default:
- modews_mode=0;
- break;
- void intake_drv(void)
- if(intake_func!=intake_old2)
- intakesttmr=STALLTMR;
- intake_old2=intake_func;
- /* if(intakesttmr)
- if(intake_func)
- spi_data&=IOFF;
- spi_data|=IFRE;
- else
- spi_data&=IOFF;
- spi_data|=IREC;
- else
- spi_data&=IOFF;
- void act_drv(void)
- void EEROM_proc (void)
- if ((memflag!=0)&&(mem_tmr==0))
- switch (memflag)
- case 1: {EEPROM_WRITE(0x20,tset);memflag=2;} break;
- case 2: {EEPROM_WRITE(0x21,mode_func); memflag=3;} break;
- case 3: {EEPROM_WRITE(0x22,intake_func); memflag=4;} break;
- case 4: {EEPROM_WRITE(0x23,ac_func);memflag=5;}break;
- case 5: {EEPROM_WRITE(0x24,blower_func);memflag=6;}break;
- case 6: {EEPROM_WRITE(0x25,sys_mode); memflag=7;}break;
- case 7: {EEPROM_WRITE(0x26,mode_old); memflag=0;}break;
- default :
- {memflag=0; } break;
- void EEPROM_init(void)
- tset=EEPROM_READ(0x20);
- if((tset<20)||(tset>30))
- tset=24;
- sys_mode=0x80;
- mode_func=0;
- ac_func=0;
- blower_func=0x01;
- intake_func=0x01;
- else
- mode_func=EEPROM_READ(0x21);
- intake_func=EEPROM_READ(0x22);
- ac_func=EEPROM_READ(0x23);
- blower_func=EEPROM_READ(0x24);
- sys_mode=EEPROM_READ(0x25);
- mode_old=0x0;
- ac_old=0x0;
- blower_old=0x01;
- intake_old=0x01;
- void led_drv(void)
- if((sys_mode&0x80)==0)
- if(ac_func&0x08)
- LED_AC=0;
- else LED_AC=1;
- if((sys_mode&0x08)&&(mode_func!=4)) LED_AUTO=0;
- else LED_AUTO=1;
- if((sys_mode&0x03)==0x01) t_show=0x01;
- else if((sys_mode&0x03)==0x02) t_show=0x08;
- else if(tset==20) t_show=0x02;
- else if(tset==22) t_show=0x03;
- else if(tset==24) t_show=0x04;
- else if(tset==26) t_show=0x05;
- else if(tset==28) t_show=0x06;
- else if(tset==30) t_show=0x07;
- switch(t_show)
- case 1:
- LEDT18=0;
- LEDT20=1;
- LEDT22=1;
- LEDT24=1;
- LEDT26=1;
- LEDT28=1;
- LEDT30=1;
- LEDT32=1;
- break;
- case 2:
- LEDT18=1;
- LEDT20=0;
- LEDT22=1;
- LEDT24=1;
- LEDT26=1;
- LEDT28=1;
- LEDT30=1;
- LEDT32=1;
- break;
- case 3:
- LEDT18=1;
- LEDT20=1;
- LEDT22=0;
- LEDT24=1;
- LEDT26=1;
- LEDT28=1;
- LEDT30=1;
- LEDT32=1;
- break;
- case 4:
- LEDT18=1;
- LEDT20=1;
- LEDT22=1;
- LEDT24=0;
- LEDT26=1;
- LEDT28=1;
- LEDT30=1;
- LEDT32=1;
- break;
- case 5:
- LEDT18=1;
- LEDT20=1;
- LEDT22=1;
- LEDT24=1;
- LEDT26=0;
- LEDT28=1;
- LEDT30=1;
- LEDT32=1;
- break;
- case 6:
- LEDT18=1;
- LEDT20=1;
- LEDT22=1;
- LEDT24=1;
- LEDT26=1;
- LEDT28=0;
- LEDT30=1;
- LEDT32=1;
- break;
- case 7:
- LEDT18=1;
- LEDT20=1;
- LEDT22=1;
- LEDT24=1;
- LEDT26=1;
- LEDT28=1;
- LEDT30=0;
- LEDT32=1;
- break;
- case 8:
- LEDT18=1;
- LEDT20=1;
- LEDT22=1;
- LEDT24=1;
- LEDT26=1;
- LEDT28=1;
- LEDT30=1;
- LEDT32=0;
- break;
- default:break;
- switch(mode_func&0x7f)
- case 0:
- LEDVENT=0;
- LEDBL=1;
- LEDFOOT=1;
- LEDMIX=1;
- LEDDEF=1;
- break;
- case 1:
- LEDVENT=1;
- LEDBL=0;
- LEDFOOT=1;
- LEDMIX=1;
- LEDDEF=1;
- break;
- case 2:
- LEDVENT=1;
- LEDBL=1;
- LEDFOOT=0;
- LEDMIX=1;
- LEDDEF=1;
- break;
- case 3:
- LEDVENT=1;
- LEDBL=1;
- LEDFOOT=1;
- LEDMIX=0;
- LEDDEF=1;
- break;
- case 4:
- LEDVENT=1;
- LEDBL=1;
- LEDFOOT=1;
- LEDMIX=1;
- LEDDEF=0;
- break;
- default:break;
- switch(blower_func&0x7f)
- case 1:
- LEDB1=1;
- LEDB2=0;
- LEDB3=0;
- LEDB4=0;
- LEDB5=0;
- LEDB6=0;
- LEDB7=0;
- break;
- case 2:
- LEDB1=1;
- LEDB2=1;
- LEDB3=0;
- LEDB4=0;
- LEDB5=0;
- LEDB6=0;
- LEDB7=0;
- break;
- case 3:
- LEDB1=1;
- LEDB2=1;
- LEDB3=1;
- LEDB4=0;
- LEDB5=0;
- LEDB6=0;
- LEDB7=0;
- break;
- case 4:
- LEDB1=1;
- LEDB2=1;
- LEDB3=1;
- LEDB4=1;
- LEDB5=0;
- LEDB6=0;
- LEDB7=0;
- break;
- case 5:
- LEDB1=1;
- LEDB2=1;
- LEDB3=1;
- LEDB4=1;
- LEDB5=1;
- LEDB6=0;
- LEDB7=0;
- break;
- case 6:
- LEDB1=1;
- LEDB2=1;
- LEDB3=1;
- LEDB4=1;
- LEDB5=1;
- LEDB6=1;
- LEDB7=0;
- break;
- case 7:
- LEDB1=1;
- LEDB2=1;
- LEDB3=1;
- LEDB4=1;
- LEDB5=1;
- LEDB6=1;
- LEDB7=1;
- break;
- default:break;
- else
- LED_AC=1;
- LED_AUTO=1;
- LEDT18=1;
- LEDT20=1;
- LEDT22=1;
- LEDT24=1;
- LEDT26=1;
- LEDT28=1;
- LEDT30=1;
- LEDT32=1;
- LEDVENT=1;
- LEDBL=1;
- LEDFOOT=1;
- LEDMIX=1;
- LEDDEF=1;
- LEDB1=0;
- LEDB2=0;
- LEDB3=0;
- LEDB4=0;
- LEDB5=0;
- LEDB6=0;
- LEDB7=0;
- if(intake_func&0x7f) LED_REC=1;
- else LED_REC=0;
汽車空調(diào)程序.rar
(9.62 KB, 下載次數(shù): 68)
2018-3-14 15:59 上傳
點(diǎn)擊文件名下載附件
pic 汽車空調(diào)程序
