查看: 4598|回復: 0
關于8x8x8階光立方資料
ID:180782 發(fā)表于 2018-5-28 18:45 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
全部資料51hei下載地址:
573 2803 程序 原理圖 PCB_20130606213915.zip (1.76 MB, 下載次數(shù): 22)
上位機程序.zip (29.11 KB, 下載次數(shù): 12)
所有.pdf (185.51 KB, 下載次數(shù): 10)
PCB.pdf (570.92 KB, 下載次數(shù): 9)
原理圖.pdf (591.54 KB, 下載次數(shù): 10)
部分程序
  1. #include <REG52.H>
  2. #include <intrins.h>
  4. #define uint unsigned int
  5. uchar display[8][8];
  6. /*rank:A,1,2,3,4,I,心,U*/
  7. uchar code table_cha[8][8]={0x51,0x51,0x51,0x4a,0x4a,0x4a,0x44,0x44,0x18,0x1c,0x18,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0x66,0x30,0x18,0xc,0x6,0xf6,0x3c,0x66,0x60,0x38,0x60,0x60,0x66,0x3c,0x30,0x38,0x3c,0x3e,0x36,0x7e,0x30,0x30,0x3c,0x3c,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0xff,0xff,0xff,0x7e,0x3c,0x18,0x18,0x66,0x66,0x66,0x66,0x66,0x66,0x7e,0x3c};
  8. /*the "ideasoft"*/
  9. uchar code table_id[40]={0x81,0xff,0x81,0x00,0xff,0x81,0x81,0x7e,0x00,0xff,0x89,0x89,0x00,0xf8,0x27,0x27,0xf8,0x00,0x8f,0x89,0x89,0xf9,0x00,0xff,0x81,0x81,0xff,0x00,0xff,0x09,0x09,0x09,0x01,0x0,0x01,0x01,0xff,0x01,0x01,0x00};
  10. /*railway*/
  11. uchar code dat[128]={0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x6f,0x8f,0x93,0x73,0x6f,0x8f,0x93,0x73,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
  12. /*railway 2*/
  13. uchar code dat2[28]={0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4};
  14. /*railway 3*/
  15. uchar code dat3[24]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x16,0x26,0x36,0x46,0x56,0x66,0x65,0x64,0x63,0x62,0x61,0x60,0x50,0x40,0x30,0x20,0x10};
  16. /*3p char*/
  17. uchar code table_3p[3][8]={0xff,0x89,0xf5,0x93,0x93,0xf5,0x89,0xff,0x0e,0x1f,0x3f,0x7e,0x7e,0x3f,0x1f,0x0e,0x18,0x3c,0x7e,0xff,0x18,0x18,0x18,0x18};
  18. /*initializtion
  19. That is to initialize the program .
  20. It is write to set the timer in c52 mcu.
  21. So the program can renovate the led_3d_cube in fixed time use the interrupt function.*/
  22. void sinter()
  23. {
  24.          IE=0x82;
  25.          TCON=0x01;
  26.          TH0=0xc0;
  27.          TL0=0;
  28.          TR0=1;
  29. }
  30. void delay5us(void)   //誤差 -0.026765046296us STC 1T 22.1184Mhz
  31. {
  32.     unsigned char a,b;
  33.     for(b=7;b>0;b--)
  34.         for(a=2;a>0;a--);
  35. }
  36. void delay(uint i)
  37. {
  38.          while (i--){
  39.                  delay5us();}//12t的mcu 注釋這個延時即可
  40. }
  41. /*To judge the num bit*/
  42. uchar judgebit(uchar num,uchar b)
  43. {
  44.          char n;
  45.          num=num&(1<<b);
  46.          if (num)
  47.          n=1;
  48.          else
  49.          n=0;
  50.          return n;
  51. }
  52. /*To figure out the round number*/
  53. uchar abs(uchar a)
  54. {
  55.          uchar b;
  56.          b=a/10;
  57.          a=a-b*10;
  58.          if (a>=5)
  59.          b++;
  60.          return b;
  61. }
  62. /*To figure out the absolute value*/
  63. uchar abss(char a)
  64. {
  65.          if (a<0)
  66.          a=-a;
  67.          return a;
  68. }
  69. /*The function can comparat the character.
  70. And remove the big one to the back.*/
  71. void max(uchar *a,uchar *b)
  72. {
  73.    uchar t;
  74.    if ((*a)>(*b))
  75.    {
  76.                    t=(*a);
  77.                    (*a)=(*b);
  78.                    (*b)=t;
  79.    }
  80. }
  81. /*The function is to figure out the max number and return it.*/
  82. uchar maxt(uchar a,uchar b,uchar c)
  83. {
  84.          if (a<b)
  85.          a=b;
  86.          if (a<c)
  87.          a=c;
  88.          return a;
  89. }
  90. void clear(char le)
  91. {
  92.          uchar i,j;
  93.          for (j=0;j<8;j++)
  94.          {
  95.                    for (i=0;i<8;i++)
  96.                    display[j][i]=le;
  97.          }
  98. }
  99. void trailler(uint speed)
  100. {
  101.          char i,j;
  102.          for (i=6;i>=-3;i--)
  103.          {
  104.                    if (i>=0)
  105.                    {
  106.                             for (j=0;j<8;j++)
  107.                             display[j][i]=display[j][i+1];
  108.                    }
  109.                    if (i<4)
  110.                    {
  111.                             for (j=0;j<8;j++)
  112.                             display[j][i+4]=0;
  113.                    }
  114.                    delay(speed);
  115.          }
  116. }
  117. void point(uchar x,uchar y,uchar z,uchar le)
  118. {
  119.          uchar ch1,ch0;
  120.          ch1=1<<x;
  121.          ch0=~ch1;
  122.          if (le)
  123.          display[z][y]=display[z][y]|ch1;
  124.          else
  125.          display[z][y]=display[z][y]&ch0;
  126. }
  127. void type(uchar cha,uchar y)
  128. {
  129.          uchar xx;
  130.          for (xx=0;xx<8;xx++)
  131.          {
  132.          display[xx][y]=table_cha[cha][xx];
  133.          }
  134. }
  135. /*The first variable is the distance from the midpoint.
  136. The second is the layer.
  137. the third is the flash speed of the time between each two point.
  138. The forth is the enable io,it controls weather draw or claen.*/
  139. void cirp(char cpp,uchar dir,uchar le)
  140. {
  141.          uchar a,b,c,cp;
  142.          if ((cpp<128)&(cpp>=0))
  143.          {
  144.                    if (dir)
  145.                    cp=127-cpp;
  146.                    else
  147.                    cp=cpp;
  148.                    a=(dat[cp]>>5)&0x07;
  149.                    b=(dat[cp]>>2)&0x07;
  150.                    c=dat[cp]&0x03;
  151.                    if (cpp>63)
  152.                    c=7-c;
  153.                    point (a,b,c,le);
  154.          }
  155. }
  156. void line(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar le)
  157. {
  158.          char t,a,b,c,a1,b1,c1,i;
  159.          a1=x2-x1;
  160.          b1=y2-y1;
  161.          c1=z2-z1;
  162.          t=maxt(abss(a1),abss(b1),abss(c1));
  163.          a=x1*10;
  164.          b=y1*10;
  165.          c=z1*10;
  166.          a1=a1*10/t;
  167.          b1=b1*10/t;
  168.          c1=c1*10/t;
  169.          for (i=0;i<t;i++)
  170.          {
  171.                    point(abs(a),abs(b),abs(c),le);
  172.                    a+=a1;
  173.                    b+=b1;
  174.                    c+=c1;
  175.          }
  176.          point(x2,y2,z2,le);
  177. }
  178. void box(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le)
  179. {
  180.          uchar i,j,t=0;
  181.          max(&x1,&x2);
  182.          max(&y1,&y2);
  183.          max(&z1,&z2);
  184.          for (i=x1;i<=x2;i++)
  185.                    t|=1<<i;
  186.          if (!le)
  187.                    t=~t;
  188.          if (fill)
  189.          {
  190.                    if (le)
  191.                    {
  192.                             for (i=z1;i<=z2;i++)
  193.                             {
  194.                                      for (j=y1;j<=y2;j++)
  195.                                                display[j][i]|=t;
  196.                             }
  197.                    }
  198.                    else
  199.                    {
  200.                             for (i=z1;i<=z2;i++)
  201.                             {
  202.                                      for (j=y1;j<=y2;j++)
  203.                                                display[j][i]&=t;
  204.                             }
  205.                    }
  206.          }
復制代碼
詳細的都在壓縮包中,圖片點亮燈形狀等都有。
