查看: 5121|回復(fù): 2
EDA 汽車尾燈控制器設(shè)計(jì)VHDL源碼
ID:292670 發(fā)表于 2018-7-1 14:11 | 顯示全部樓層 |閱讀模式
EDA作業(yè)
全部資料51hei下載地址:
汽車尾燈控制器設(shè)計(jì).rar (363.1 KB, 下載次數(shù): 65)
  1. Library ieee;
  2. Use ieee.std_logic_1164.all;
  3. Use ieee.std_logic_unsigned.all;
  4. Entity tp is
  5. Port(clk:in std_logic;
  6.         Left:in std_logic;
  7.         Right:in std_logic;
  8.         Brake:in std_logic;
  9.         Night:in std_logic;
  10.         Ld1,Ld2,Ld3:out std_logic;
  11.         Rd1,Rd2,Rd3:out std_logic);
  12. End;
  13. Architecture bh of tp is
  14. Component sz is
  15.         Port(clk:in std_logic;
  16.         Cp:out std_logic);
  17. End component;
  18. Component ctrl is
  19.         Port(left,right,brake,night:in std_logic;
  20.         Lp,rp,lr,brake_led,night_led:out std_logic);
  21. End component;
  22. Component lc is
  23.         Port(clk,lp,lr,brake,night:in std_logic;
  24.         Ledl,ledb,ledn:out std_logic);
  25. End component;
  26. Component rc is
  27.         Port(clk,rp,lr,brake,night:in std_logic;
  28.         Ledr,ledb,ledn:out std_logic);
  29. End component;
  30. Signal tmp0,tmp1,tmp2,tmp3,tmp4:std_logic;
  31. Signal err0,err1,err2,err3,err4,err5:std_logic;
  32. signal bm:std_logic;
  33. Begin
  34. U1:sz port map(clk,bm);
  35. U2:ctrl port map(left,right,brake,night,tmp0,tmp1,tmp2,tmp3,tmp4);
  36. U3:lc port map(clk,tmp0,tmp2,tmp3,tmp4,err0,err1,err2);
  37. U4:rc port map(clk,tmp1,tmp2,tmp3,tmp4,err3,err4,err5);
  38. Ld1<=err0 and bm;
  39. Ld2<=err1;
  40. Ld3<=err2;
  41. Rd1<=err3 and bm;
  42. Rd2<=err4;
  43. Rd3<=err5;
  44. End;
ID:566697 發(fā)表于 2019-6-19 13:17 | 顯示全部樓層
非常需要
ID:992677 發(fā)表于 2022-6-14 18:36 | 顯示全部樓層
下到版子里有問題
