查看: 4957|回復(fù): 4
紅外使用單片機(jī)外部中斷+定時(shí)器解碼
ID:61973 發(fā)表于 2018-8-5 21:36 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
包含了紅外解碼,自動(dòng)根據(jù)波特率設(shè)置定時(shí)器溢出率以及使用定時(shí)器延時(shí)
串口部分:
void UART1_Init(u32 Boud)
        u16 Temp = (65536 - FOSC/Boud/4);
        SCON = 0x50;
    T2L = Temp;
    T2H = Temp >> 8;
    AUXR |= 0x15;                                //啟動(dòng)定時(shí)器
    ES = 1;                                     //使能串口中斷
char putchar(u8 c)
        SBUF = c;
        while(!TI);
        TI = 0;
        return c;
void UART1_ISR() interrupt 4 using 1
    if(RI)
        RI = 0;                                 //清中斷標(biāo)志
//        if(TI)
//                TI = 0;                                 //清中斷標(biāo)志
//定時(shí)器延時(shí)部分
#include "delay.h"
#define TICK_US                (FOSC/1000000/12)
volatile u16 told = 0;                                //計(jì)數(shù)器舊值
volatile u16 tnow = 0;                                //計(jì)數(shù)器新值
volatile u16 tick = 0;                                //計(jì)數(shù)值
volatile u16 delay_tick = 0;                //延時(shí)計(jì)數(shù)值
void delay_init(void)
        T4L = 0;
    T4H = 0;
        T4T3M &= 0x0F;
        T4T3M |= B1000_0000;         //啟動(dòng)定時(shí)器 12T
        told = 0;
        tnow = 0;
        tick = 0;
        delay_tick = 0;
void delay(u16 us)
        told = T4H << 8 | T4L;
        tnow = 0;tick = 0;
        delay_tick = us * TICK_US;
                tnow = T4H << 8 | T4L;
                if(tnow != told)
                        if(tnow > told)
                                tick += tnow - told;
                        else                                //定時(shí)器溢出
                                tick += 65535 + tnow - told;
                        told = tnow;
                        if(tick >= delay_tick)
                                break;
//紅外解碼
#include "INT.h"
#include "USART.h"
u8 IR_Cnt = 0;
#define T51                                (FOSC/1000000/12)
#define REMOTE_ID                 0
//遙控器接收狀態(tài)
//[7]:收到了引導(dǎo)碼標(biāo)志
//[6]:得到了一個(gè)按鍵的所有信息
//[5]:保留
//[4]:標(biāo)記上升沿是否已經(jīng)被捕獲
//[3:0]:溢出計(jì)時(shí)器
u8 IR_sta = 0;
u32 IR_Rec = 0;
sbit INT0 = P3^2;
void IR_Init(void)
        IT0 = 0;            //使能INT0上升沿和下降沿中斷
    EX0 = 1;             //使能INT0中斷
        AUXR &= 0x7F;                //定時(shí)器時(shí)鐘12T模式
        TMOD &= 0xF0;                //設(shè)置定時(shí)器模式
        TMOD |= 0x01;                //設(shè)置定時(shí)器模式
        TF0 = 0;                //清除TF0標(biāo)志
        TL0 = 0;                //設(shè)置定時(shí)初值
        TH0 = 0;                //設(shè)置定時(shí)初值
        TR0 = 0;                //定時(shí)器0開始計(jì)時(shí)
        ET0 = 1;
//處理紅外鍵盤
//返回值:
//         0,沒有任何按鍵按下
//其他,按下的按鍵鍵值.
u8 IR_Scan(void)
        u8 Key = 0;
        if(IR_sta & (1<<6))//得到一個(gè)按鍵的所有信息了
                u8 TEMP[2];
            TEMP[0] = IR_Rec>>24;                        //得到地址碼
            TEMP[1] = (IR_Rec>>16)&0xff;        //得到地址反碼
             if((TEMP[0] == (u8)~TEMP[1]) && TEMP[0] == REMOTE_ID)//檢驗(yàn)遙控識(shí)別碼(ID)及地址
                TEMP[0] = IR_Rec>>8;
                TEMP[1] = IR_Rec;
                if(TEMP[0] == (u8)~TEMP[1])
                                Key = TEMP[0];//鍵值正確
                if(Key == 0||(IR_sta&0X80) == 0)//按鍵數(shù)據(jù)錯(cuò)誤/遙控已經(jīng)沒有按下了
                        IR_sta&=~(1<<6);//清除接收到有效按鍵標(biāo)識(shí)
                        IR_Cnt = 0;                //清除按鍵次數(shù)計(jì)數(shù)器
    return Key;
void INT0_ISR(void) interrupt 0 using 1
        if(INT0)//上升沿捕獲
                TR0 = 1;                //定時(shí)器0開始計(jì)時(shí)
                IR_sta |= 0X10;                                        //標(biāo)記上升沿已經(jīng)被捕獲
        else //下降沿捕獲
                u16 Count_Time = 0;
                Count_Time = TH0 << 8|TL0;
                if(IR_sta & 0X10)                                        //完成一次高電平捕獲
                        if(IR_sta & 0X80)//接收到了引導(dǎo)碼
                                if(Count_Time > (300 * T51) && Count_Time < (800 * T51))                        //560為標(biāo)準(zhǔn)值,560us
                                        IR_Rec <<= 1;        //左移一位.
                                        IR_Rec |= 0;        //接收到0
                                else if(Count_Time > (1400 * T51) && Count_Time < (1800 * T51))        //1680為標(biāo)準(zhǔn)值,1680us
                                        IR_Rec |= 1;        //接收到1
                                else if(Count_Time > (2200 * T51) && Count_Time < (2600 * T51))        //得到按鍵鍵值增加的信息 2500為標(biāo)準(zhǔn)值2.5ms
                                        IR_Cnt++;                 //按鍵次數(shù)增加1次
                                        IR_sta&=0XF0;        //清空計(jì)時(shí)器
                        else if(Count_Time > (4200 * T51) && Count_Time < (4700 * T51))                //4500為標(biāo)準(zhǔn)值4.5ms
                                IR_sta|=1<<7;        //標(biāo)記成功接收到了引導(dǎo)碼
                                IR_Cnt=0;                //清除按鍵次數(shù)計(jì)數(shù)器
                IR_sta &=~(1<<4);
void TIME0_ISR(void) interrupt 1 using 1
        if(IR_sta&0x80)//上次有數(shù)據(jù)被接收到了
                IR_sta &= ~0X10;                                                //取消上升沿已經(jīng)被捕獲標(biāo)記
                if((IR_sta&0X0F) == 0X00)
                        IR_sta|=1<<6;//標(biāo)記已經(jīng)完成一次按鍵的鍵值信息采集
                if((IR_sta&0X0F) < 14)
                        IR_sta++;
                        IR_sta&=~(1<<7);//清空引導(dǎo)標(biāo)識(shí)
                        IR_sta&=0XF0;        //清空計(jì)數(shù)器
STC8.rar
288.26 KB, 下載次數(shù): 28, 下載積分: 黑幣 -5
收藏收藏2 分享淘帖 頂 踩
相關(guān)帖子
ID:290576 發(fā)表于 2018-8-22 00:22 | 只看該作者
標(biāo)記下  感謝樓主
ID:337813 發(fā)表于 2018-10-21 23:22 | 只看該作者
感謝您的無(wú)私分享,謝謝你。。
ID:298008 發(fā)表于 2018-10-22 15:39 | 只看該作者
謝謝樓主分享
ID:615610 發(fā)表于 2020-6-24 20:10 | 只看該作者
謝謝樓主分享
