- #include <reg52.h>
- sbit BUZZ = P1^6;
- sbit ADDR3 = P1^3;
- sbit ENLED = P1^4;
- sbit KEY_IN_1 = P2^4;
- sbit KEY_IN_2 = P2^5;
- sbit KEY_IN_3 = P2^6;
- sbit KEY_IN_4 = P2^7;
- sbit KEY_OUT_1 = P2^3;
- sbit KEY_OUT_2 = P2^2;
- sbit KEY_OUT_3 = P2^1;
- sbit KEY_OUT_4 = P2^0;
- unsigned char code LedChar[] = { //數(shù)碼管顯示字符轉(zhuǎn)換表
- 0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
- 0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
- unsigned char LedBuff[7] = { //數(shù)碼管+獨(dú)立LED顯示緩沖區(qū)
- 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
- unsigned char code KeyCodeMap[4][4] = { //矩陣按鍵編號(hào)到標(biāo)準(zhǔn)鍵盤(pán)鍵碼的映射表
- { 0x31, 0x32, 0x33, 0x26 }, //數(shù)字鍵1、數(shù)字鍵2、數(shù)字鍵3、向上鍵
- { 0x34, 0x35, 0x36, 0x25 }, //數(shù)字鍵4、數(shù)字鍵5、數(shù)字鍵6、向左鍵
- { 0x37, 0x38, 0x39, 0x28 }, //數(shù)字鍵7、數(shù)字鍵8、數(shù)字鍵9、向下鍵
- { 0x30, 0x1B, 0x0D, 0x27 } //數(shù)字鍵0、ESC鍵、 回車(chē)鍵、 向右鍵
- unsigned char KeySta[4][4] = { //全部矩陣按鍵的當(dāng)前狀態(tài)
- {1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}, {1, 1, 1, 1}
- unsigned long pdata KeyDownTime[4][4] = { //每個(gè)按鍵按下的持續(xù)時(shí)間,單位ms
- {0, 0, 0, 0}, {0, 0, 0, 0}, {0, 0, 0, 0}, {0, 0, 0, 0}
- bit enBuzz = 0; //蜂鳴器使能標(biāo)志
- bit flag1s = 0; //1秒定時(shí)標(biāo)志
- bit flagStart = 0; //倒計(jì)時(shí)啟動(dòng)標(biāo)志
- unsigned char T0RH = 0; //T0重載值的高字節(jié)
- unsigned char T0RL = 0; //T0重載值的低字節(jié)
- unsigned int CountDown = 0; //倒計(jì)時(shí)計(jì)數(shù)器
- void ConfigTimer0(unsigned int ms);
- void ShowNumber(unsigned long num);
- void KeyDriver();
- void main()
- EA = 1; //使能總中斷
- ENLED = 0; //選擇數(shù)碼管和獨(dú)立LED
- ADDR3 = 1;
- ConfigTimer0(1); //配置T0定時(shí)1ms
- ShowNumber(0); //上電顯示0
- while (1)
- KeyDriver(); //調(diào)用按鍵驅(qū)動(dòng)函數(shù)
- if (flagStart && flag1s) //倒計(jì)時(shí)啟動(dòng)且1秒定時(shí)到達(dá)時(shí),處理倒計(jì)時(shí)
- flag1s = 0;
- if (CountDown > 0) //倒計(jì)時(shí)未到0時(shí),計(jì)數(shù)器遞減
- CountDown--;
- ShowNumber(CountDown); //刷新倒計(jì)時(shí)數(shù)顯示
- if (CountDown == 0) //減到0時(shí),執(zhí)行聲光報(bào)警
- enBuzz = 1; //啟動(dòng)蜂鳴器發(fā)聲
- LedBuff[6] = 0x00; //點(diǎn)亮獨(dú)立LED
- /* 配置并啟動(dòng)T0,ms-T0定時(shí)時(shí)間 */
- unsigned long tmp; //臨時(shí)變量
- tmp = 11059200 / 12; //定時(shí)器計(jì)數(shù)頻率
- tmp = (tmp * ms) / 1000; //計(jì)算所需的計(jì)數(shù)值
- tmp = 65536 - tmp; //計(jì)算定時(shí)器重載值
- tmp = tmp + 28; //補(bǔ)償中斷響應(yīng)延時(shí)造成的誤差
- T0RH = (unsigned char)(tmp>>8); //定時(shí)器重載值拆分為高低字節(jié)
- T0RL = (unsigned char)tmp;
- TMOD &= 0xF0; //清零T0的控制位
- TMOD |= 0x01; //配置T0為模式1
- TH0 = T0RH; //加載T0重載值
- TL0 = T0RL;
- ET0 = 1; //使能T0中斷
- TR0 = 1; //啟動(dòng)T0
- /* 將一個(gè)無(wú)符號(hào)長(zhǎng)整型的數(shù)字顯示到數(shù)碼管上,num-待顯示數(shù)字 */
- signed char i;
- unsigned char buf[6];
- for (i=0; i<6; i++) //把長(zhǎng)整型數(shù)轉(zhuǎn)換為6位十進(jìn)制的數(shù)組
- buf[i] = num % 10;
- num = num / 10;
- for (i=5; i>=1; i--) //從最高位起,遇到0轉(zhuǎn)換為空格,遇到非0則退出循環(huán)
- if (buf[i] == 0)
- LedBuff[i] = 0xFF;
- else
- break;
- for ( ; i>=0; i--) //剩余低位都如實(shí)轉(zhuǎn)換為數(shù)碼管顯示字符
- LedBuff[i] = LedChar[buf[i]];
- /* 按鍵動(dòng)作函數(shù),根據(jù)鍵碼執(zhí)行相應(yīng)的操作,keycode-按鍵鍵碼 */
- void KeyAction(unsigned char keycode) //按鍵動(dòng)作函數(shù),根據(jù)鍵碼執(zhí)行相應(yīng)動(dòng)作
- if (keycode == 0x26) //向上鍵,倒計(jì)時(shí)設(shè)定值遞增
- if (CountDown < 9999) //最大計(jì)時(shí)9999秒
- CountDown++;
- else if (keycode == 0x28) //向下鍵,倒計(jì)時(shí)設(shè)定值遞減
- if (CountDown > 1) //最小計(jì)時(shí)1秒
- CountDown--;
- else if (keycode == 0x0D) //回車(chē)鍵,啟動(dòng)倒計(jì)時(shí)
- flagStart = 1; //啟動(dòng)倒計(jì)時(shí)
- else if (keycode == 0x1B) //Esc鍵,取消倒計(jì)時(shí)
- enBuzz = 0; //關(guān)閉蜂鳴器
- LedBuff[6] = 0xFF; //關(guān)閉獨(dú)立LED
- flagStart = 0; //停止倒計(jì)時(shí)
- CountDown = 0; //倒計(jì)時(shí)數(shù)歸零
- /* 按鍵驅(qū)動(dòng)函數(shù),檢測(cè)按鍵動(dòng)作,調(diào)度相應(yīng)動(dòng)作函數(shù),需在主循環(huán)中調(diào)用 */
- void KeyDriver()
- unsigned char i, j;
- static unsigned char pdata backup[4][4] = { //按鍵值備份,保存前一次的值
- static unsigned long pdata TimeThr[4][4] = { //快速輸入執(zhí)行的時(shí)間閾值
- {1000, 1000, 1000, 1000}, {1000, 1000, 1000, 1000},
- for (i=0; i<4; i++) //循環(huán)掃描4*4的矩陣按鍵
- for (j=0; j<4; j++)
- if (backup[i][j] != KeySta[i][j]) //檢測(cè)按鍵動(dòng)作
- if (backup[i][j] != 0) //按鍵按下時(shí)執(zhí)行動(dòng)作
- KeyAction(KeyCodeMap[i][j]); //調(diào)用按鍵動(dòng)作函數(shù)
- backup[i][j] = KeySta[i][j]; //刷新前一次的備份值
- if (KeyDownTime[i][j] > 0) //檢測(cè)執(zhí)行快速輸入
- if (KeyDownTime[i][j] >= TimeThr[i][j])
- { //達(dá)到閾值時(shí)執(zhí)行一次動(dòng)作
- TimeThr[i][j] += 200; //時(shí)間閾值增加200ms,以準(zhǔn)備下次執(zhí)行
- else //按鍵彈起時(shí)復(fù)位閾值時(shí)間
- TimeThr[i][j] = 1000; //恢復(fù)1s的初始閾值時(shí)間
- /* 按鍵掃描函數(shù),需在定時(shí)中斷中調(diào)用 */
- void KeyScan()
- unsigned char i;
- static unsigned char keyout = 0; //矩陣按鍵掃描輸出索引
- static unsigned char keybuf[4][4] = { //矩陣按鍵掃描緩沖區(qū)
- {0xFF, 0xFF, 0xFF, 0xFF}, {0xFF, 0xFF, 0xFF, 0xFF},
- //將一行的4個(gè)按鍵值移入緩沖區(qū)
- keybuf[keyout][0] = (keybuf[keyout][0] << 1) | KEY_IN_1;
- keybuf[keyout][1] = (keybuf[keyout][1] << 1) | KEY_IN_2;
- keybuf[keyout][2] = (keybuf[keyout][2] << 1) | KEY_IN_3;
- keybuf[keyout][3] = (keybuf[keyout][3] << 1) | KEY_IN_4;
- //消抖后更新按鍵狀態(tài)
- for (i=0; i<4; i++) //每行4個(gè)按鍵,所以循環(huán)4次
- if ((keybuf[keyout][i] & 0x0F) == 0x00)
- { //連續(xù)4次掃描值為0,即4*4ms內(nèi)都是按下?tīng)顟B(tài)時(shí),可認(rèn)為按鍵已穩(wěn)定的按下
- KeySta[keyout][i] = 0;
- KeyDownTime[keyout][i] += 4; //按下的持續(xù)時(shí)間累加
- else if ((keybuf[keyout][i] & 0x0F) == 0x0F)
- { //連續(xù)4次掃描值為1,即4*4ms內(nèi)都是彈起狀態(tài)時(shí),可認(rèn)為按鍵已穩(wěn)定的彈起
- KeySta[keyout][i] = 1;
- KeyDownTime[keyout][i] = 0; //按下的持續(xù)時(shí)間清零
- //執(zhí)行下一次的掃描輸出
- keyout++; //輸出索引遞增
- keyout &= 0x03; //索引值加到4即歸零
- switch (keyout) //根據(jù)索引,釋放當(dāng)前輸出引腳,拉低下次的輸出引腳
- case 0: KEY_OUT_4 = 1; KEY_OUT_1 = 0; break;
- case 1: KEY_OUT_1 = 1; KEY_OUT_2 = 0; break;
- case 2: KEY_OUT_2 = 1; KEY_OUT_3 = 0; break;
- case 3: KEY_OUT_3 = 1; KEY_OUT_4 = 0; break;
- default: break;
- /* LED動(dòng)態(tài)掃描刷新函數(shù),需在定時(shí)中斷中調(diào)用 */
- void LedScan()
- static unsigned char i = 0; //動(dòng)態(tài)掃描索引
- P0 = 0xFF; //關(guān)閉所有段選位,顯示消隱
- P1 = (P1 & 0xF8) | i; //位選索引值賦值到P1口低3位
- P0 = LedBuff[i]; //緩沖區(qū)中索引位置的數(shù)據(jù)送到P0口
- if (i < 6) //索引遞增循環(huán),遍歷整個(gè)緩沖區(qū)
- i++;
- else
- i = 0;
- /* T0中斷服務(wù)函數(shù),完成數(shù)碼管、按鍵掃描與秒定時(shí) */
- void InterruptTimer0() interrupt 1
- static unsigned int tmr1s = 0; //1秒定時(shí)器
- TH0 = T0RH; //重新加載重載值
- TL0 = T0RL;
- if (enBuzz) //蜂鳴器發(fā)聲處理
- BUZZ = ~BUZZ; //驅(qū)動(dòng)蜂鳴器發(fā)聲
- else
- BUZZ = 1; //關(guān)閉蜂鳴器
- LedScan(); //LED掃描顯示
- KeyScan(); //按鍵掃描
- if (flagStart) //倒計(jì)時(shí)啟動(dòng)時(shí)處理1秒定時(shí)
- tmr1s++;
- if (tmr1s >= 1000)
- tmr1s = 0;
- flag1s = 1;
- else //倒計(jì)時(shí)未啟動(dòng)時(shí)1秒定時(shí)器始終歸零
- tmr1s = 0;
長(zhǎng)短按鍵連續(xù)按鍵功能實(shí)現(xiàn).rar
(40.77 KB, 下載次數(shù): 47)
2018-11-13 15:45 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
