查看: 5943|回復(fù): 8
1602+ds1302+stc89c52電子鬧鐘代碼+pcb文件+電路圖
ID:425732 發(fā)表于 2018-11-13 16:48 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
花了幾個(gè)星期制作了一個(gè)電子鬧鐘,能顯示自定義字符。三個(gè)按鍵調(diào)整時(shí)間和鬧鐘,主要是程序調(diào)試
單片機(jī)源代碼:
  1. #define  _MAIN_C
  2. #include "config.h"
  3. #include "Lcd1602.h"
  4. #include "keyboard.h"
  5. #include "DS1302.h"
  6. #include "DS18B20.h"
  7. #include "Time.h"
  8. #include "main.h"
  9. bit flag2s = 0;    //2s定時(shí)標(biāo)志位
  10. bit flag200ms = 0; //200ms定時(shí)標(biāo)志
  11. uint8 T0RH = 0;    //T0重載值的高字節(jié)
  12. uint8 T0RL = 0;    //T0重載值的低字節(jié)
  13. enum eStaSystem staSystem = E_NORMAL;  //系統(tǒng)運(yùn)行狀態(tài)
  14. uint8 code table[]={0x00,0x00,0x00,0x1F,0x00,0x00,0x00,0x00,
  15. 0x00,0x00,0x0E,0x00,0x00,0x1F,0x00,0x00,
  16. 0x00,0x00,0x0E,0x00,0x0E,0x00,0x1F,0x00,
  17. 0x00,0x1F,0x15,0x15,0x1B,0x11,0x1F,0x00,
  18. 0x00,0x1E,0x08,0x1E,0x0A,0x0A,0x0A,0x1F,
  19. 0x00,0x04,0x00,0x1F,0x0A,0x11,0x11,0x00,
  20. 0x00,0x1F,0x11,0x11,0x1F,0x11,0x11,0x1F,
  21. 0x00,0x04,0x0E,0x0E,0x0E,0x1F,0x00,0x0E };
  22. void main()
  23. {
  24.         uint8 ledsj=0;
  25.     EA = 1;           //開總中斷
  26.     ConfigTimer0(1);  //配置T0定時(shí)1ms
  27.     InitDS1302();     //初始化實(shí)時(shí)時(shí)鐘模塊
  28.     InitLcd1602();    //初始化液晶模塊
  29.         LED=0;
  30.         WriteROM();
  31.     Start18B20();     //啟動(dòng)首次溫度轉(zhuǎn)換
  32.      LcdShowStr(2, 0,"Zhao Wen jie");
  33.           LcdShowStr(0, 1,"Qichuangnaozhong");
  34.    while (!flag2s);  //上電后延時(shí)2秒
  35.     flag2s = 0;
  36.    LcdClearScreen();  //液晶清屏
  37.    RefreshDate(1);   //立即刷新日期顯示
  38.    RefreshTemp(1);   //立即刷新溫度顯示
  39.    RefreshTime();   //刷新當(dāng)前時(shí)間
  40.
  41.     while (1)  //進(jìn)入主循環(huán)
  42.     {
  43.         KeyDriver();      //執(zhí)行按鍵驅(qū)動(dòng)
  44.
  45.         if (flag200ms)    //每隔200ms執(zhí)行以下分支
  46.         {
  47.             flag200ms = 0;
  48.
  49.
  50.            if (staSystem == E_NORMAL)  //正常運(yùn)行時(shí)刷新日期顯示
  51.             {
  52.                                    AlarmMonitor();  //監(jiān)控鬧鐘
  53.                                  if(key==0)
  54.                                          {
  55.                                         if(bakekey==0)
  56.                                                         {
  57.        LcdClearScreen();  //液晶清
  58.        RefreshDate(1);   //立即刷新日期顯示
  59.                                                              RefreshTemp(1);   //立即刷新溫度顯示
  60.        bakekey=1;
  61.                                                         }
  62.                                                   if(bakekey==1)
  63.                                                          {
  64.        RefreshTime();   //刷新當(dāng)前時(shí)間
  65.        RefreshDate(0);   //立即刷新日期
  66.                                                         }
  67.                                                 else
  68.                                                 {
  69.                                                         ;;
  70.                                                 }
  71.                                         }
  72.                                 else
  73.                                          {
  74.                                                          LcdClearScreen();  //液晶清屏
  75.                                                      RefreshAlarm();
  76.                                         }
  77.
  78.             }
  79.        }
  80.       if (flag2s)  //每隔2s執(zhí)行以下分支
  81.         {
  82.                         flag2s = 0;
  83.                         if (staSystem == E_NORMAL)  //正常運(yùn)行時(shí)刷新日期顯示
  84.                                 {
  85.                                          ledsj++;
  86.                                         if(ledsj>=30)
  87.                                                 {
  88.                                                         ledsj=0;
  89.                                                         LED=1;
  90.                                                 }
  91.
  92.                              RefreshTemp(0);
  93.                                }
  94.         }
  95.     }
  96. }
  97. /* 溫度刷新函數(shù),讀取當(dāng)前溫度并根據(jù)需要刷新液晶顯示,
  98. ** ops-刷新選項(xiàng):為0時(shí)只當(dāng)溫度變化才刷新,非0則立即刷新 */
  99. void RefreshTemp(uint8 ops)
  100. {
  101.     int16 temp;
  102.     uint8 pdata str[8];
  103.     static int16 backup = 0;
  104.
  105.     Get18B20Temp(&temp); //獲取當(dāng)前溫度值16bit
  106.     Start18B20();        //啟動(dòng)下一次轉(zhuǎn)換
  107.     temp >>= 4;          //舍棄4bit小數(shù)位
  108.     if ((backup!=temp) || (ops!=0)) //按需要刷新液晶顯示
  109.     {
  110.                 if((temp>>7)&0x1f)
  111.                         {
  112.                           LcdShowChar(12, 1, '-');
  113.                           temp=(uint8)temp<<5;
  114.                           temp=~(temp)+1;
  115.                         }
  116.         str[0] = (temp/10) + '0';  //十位轉(zhuǎn)為ASCII碼
  117.         str[1] = (temp%10) + '0';  //個(gè)位轉(zhuǎn)為ASCII碼
  118.         str[2] = 'C';
  119.         str[3] = '\0';             //字符串結(jié)束符
  120.         LcdShowStr(13, 1, str);    //顯示到液晶上
  121.         backup = temp;             //刷新上次溫度值
  122.     }
  123. }
  124. /* 配置并啟動(dòng)T0,ms-T0定時(shí)時(shí)間 */
  125. void ConfigTimer0(uint16 ms)
  126. {
  127.     uint32 tmp;
  128.
  129.     tmp = (SYS_MCLK*ms)/1000; //計(jì)算所需的計(jì)數(shù)值
  130.     tmp = 65536 - tmp;        //計(jì)算定時(shí)器重載值
  131.     tmp = tmp + 33;           //補(bǔ)償中斷響應(yīng)延時(shí)造成的誤差
  132.     T0RH = (uint8)(tmp>>8);   //定時(shí)器重載值拆分為高低字節(jié)
  133.     T0RL = (uint8)tmp;
  134.     TMOD &= 0xF0;   //清零T0的控制位
  135.     TMOD |= 0x01;   //配置T0為模式1
  136.     TH0 = T0RH;     //加載T0重載值
  137.     TL0 = T0RL;
  138.     ET0 = 1;        //使能T0中斷
  139.     TR0 = 1;        //啟動(dòng)T0
  140. }
  141. /* T0中斷服務(wù)函數(shù),實(shí)現(xiàn)系統(tǒng)定時(shí)和按鍵掃描 */
  142. void InterruptTimer0() interrupt 1
  143. {
  144.     static uint8 tmr2s = 0;
  145.     static uint8 tmr200ms = 0;
  146.
  147.     TH0 = T0RH;  //重新加載重載值
  148.     TL0 = T0RL;
  149.     tmr200ms++;  //定時(shí)200ms
  150.     if (tmr200ms >= 200)
  151.     {
  152.         tmr200ms = 0;
  153.         flag200ms = 1;
  154.         tmr2s++;  //定時(shí)2s
  155.         if (tmr2s >= 10)
  156.         {
  157.             tmr2s = 0;
  158.             flag2s = 1;
  159.         }
  160.     }
  161.     KeyScan();   //執(zhí)行按鍵掃描
  162. }
  163.   void WriteROM()
  164.   {
  165.   uint8 i=0;
  166.    LcdWriteCmd(0x40);
  167.    for(i=0;i<64;i++)
  168.    {
  169.         LcdWriteDat(table[i]);
  170.    }
  171.    }
  172. 其他子程序在附件中。
全部資料51hei下載地址:
電路圖.rar (2.89 MB, 下載次數(shù): 106)
c.rar (107.45 KB, 下載次數(shù): 102)
收藏收藏3 分享淘帖 頂 踩
ID:425825 發(fā)表于 2018-11-13 17:12 | 只看該作者
要是能提供下實(shí)物照片看看多好
ID:425732 發(fā)表于 2018-11-14 13:56 | 只看該作者
來51學(xué)習(xí) 發(fā)表于 2018-11-13 17:12
要是能提供下實(shí)物照片看看多好
圖片沒上傳上去。然后我不知道怎么能。
ID:229304 發(fā)表于 2018-11-20 23:54 | 只看該作者
鬧鐘如何調(diào)?文件里面沒有說明
ID:229304 發(fā)表于 2018-11-21 00:52 | 只看該作者
原理圖里面的LED指的是什么?
ID:270331 發(fā)表于 2018-12-10 19:21 | 只看該作者
程序很規(guī)范,一看就是行家里手,贊一個(gè)!
ID:443824 發(fā)表于 2018-12-11 09:34 | 只看該作者
這是個(gè)高手
ID:404878 發(fā)表于 2018-12-11 13:57 | 只看該作者
看看程序自己也仿照著試試
ID:683548 發(fā)表于 2020-1-8 14:24 來自手機(jī) | 只看該作者
很贊哦希望可以做出實(shí)物
