查看: 4095|回復(fù): 1
我的數(shù)字電位器FPGA verilog i2c控制設(shè)計(jì) 含源碼文檔原理圖
ID:429897 發(fā)表于 2019-2-14 14:20 | 顯示全部樓層 |閱讀模式
數(shù)字電位器的型號(hào)是tpl0102
我所做的內(nèi)容是用iSe14.7設(shè)計(jì)一個(gè)i2c,來(lái)控制它輸出電阻的大小;
總阻值是100KΩ;
  1. `timescale 1ns / 1ns
  2. //////////////////////////////////////////////////////////////////////////////////
  3. // Company:
  4. // Engineer:
  5. //
  6. // Create Date:    08:59:53 02/12/2019
  7. // Design Name:
  8. // Module Name:    IIC
  9. // Project Name:
  10. // Target Devices:
  11. // Tool versions:
  12. // Description:
  13. //
  14. // Dependencies:
  15. //
  16. // Revision:
  17. // Revision 0.01 - File Created
  18. // Additional Comments:
  19. //
  20. //////////////////////////////////////////////////////////////////////////////////
  21. module IIC(
  22.                 clk_sys,
  23.                 rst_n,
  24.                 //key_wr,
  25.                 //key_rd,
  26.                 eeprom_scl,
  27.                 //led,
  28.                 eeprom_sda
  29. );
  30. input clk_sys;
  31. input rst_n;
  32. //input key_rd;
  33. //input key_wr;
  34. output reg eeprom_scl;
  35. //output [3:0] led;
  36. //output reg [7:0] result; //256
  37. //output reg led;
  38. inout  eeprom_sda;
  39. //reg [3:0] led;
  40. reg clk;
  41. reg [7:0] cnt;//256
  42. reg [7:0] state;//256
  43. reg [3:0] counter;//16
  44. reg link_sda;
  45. reg wr;
  46. //reg rd;
  47. reg sda_buf;
  48. reg [7:0] data;
  49. //reg [24:0] Cl; // C1 延時(shí)計(jì)數(shù)器
  50. //wire C1_Clk;   // 產(chǎn)生一個(gè)脈動(dòng)時(shí)鐘
  51. //assign Cl_Clk = (Cl == 25'd24999999 ) ? 1 : 0;
  52. assign eeprom_sda = (link_sda)?sda_buf:1'hz;
  53. always @ ( negedge clk_sys or negedge rst_n)
  54.         begin
  55.                 if(!rst_n)
  56.                         begin
  57.                                 clk <= 0;
  58.                                 cnt <= 0;
  59.                                 //Cl  <= 0;
  60.                         end
  61.                 else
  62.                         begin
  63.                                 if(cnt<249)
  64.                                         cnt <= cnt + 1'b1;
  65.                                 else
  66.                                         begin
  67.                                                 clk <= ~clk;
  68.                                                 cnt <= 0;
  69.                                         end
  70.                                 //if(Cl<25'd24999999)Cl <= Cl + 1'b1;
  71.                                 //else Cl <= 25'd0;
  72.                         end
  73.         end//250*20ns=5000ns=5us=200KHZ;5us*2=10Us=100KHZ;
  74.
  75. always @(negedge clk or negedge rst_n)
  76.         begin
  77.                 if(!rst_n)
  78.                         begin
  79.                                 eeprom_scl <= 0;
  80.                         end
  81.                 else
  82.                         eeprom_scl <= ~eeprom_scl;
  83.         end//50KHz=20us=20000ns
  84.
  85. always @ (posedge clk or negedge rst_n)
  86.         begin
  87.                 if(!rst_n)
  88.                         begin
  89.                                 state <= 0;
  90.                                 link_sda <= 0;
  91.                                 sda_buf <= 0;
  92.                                 counter <= 0;
  93.                                 wr <= 1;
  94.                                 //led = 1;
  95.                                 //rd <= 0;
  96.                                 //result <= 0;
  97.                                 data <= 0;
  98.                                 //led <= 4'b0001;
  99.                         end
  100.                 else
  101.                         begin
  102.                                         case(state)
  103.                                                 0:begin
  104.        wr <= 1;
  105.                                                         if(!eeprom_scl)
  106.        begin
  107.        link_sda <= 1;
  108.        sda_buf <= 1;
  109.        state <= 1;
  110.        end
  111.                                                 end
  112.
  113.                                                 1:begin
  114.                                                         if(eeprom_scl)
  115.        begin
  116.        sda_buf <= 0;
  117.        state <= 2;
  118.        data <= 8'b10100000;
  119.
  120.        end
  121.                                                 end
  122.
  123.                                                 2:begin
  124.                                                         if((counter<8)&&(!eeprom_scl))
  125.        begin
  126.        counter <= counter + 1'b1;
  127.        data <= {data[6:0],data[7]};
  128.        sda_buf <= data[7];
  129.        end
  130.                                                         else if((counter == 8)&&(!eeprom_scl))
  131.        begin
  132.        counter <= 0;
  133.        state <= 3;
  134.        link_sda <= 0;
  135.        end
  136.                                                         end
  137.
  138.                                                 3:begin
  139.                                                         if(eeprom_scl)
  140.        begin
  141.        if(!eeprom_sda)
  142.        begin
  143.        state <= 4;
  144.        data <= 8'h00;//μ??·
  145.        end
  146.        end
  147.
  148.                                                 end
  149.
  150.                                                 4:begin
  151.                                                         link_sda <= 1;
  152.                                                         if((counter < 8)&&(!eeprom_scl))
  153.        begin
  154.        counter <= counter + 1'b1;
  155.        data <= {data[6:0],data[7]};
  156.        sda_buf <= data[7];
  157.        end
  158.                                                         else if ((counter == 8)&&(!eeprom_scl))
  159.        begin
  160.        counter <= 0;
  161.        state <= 5;
  162.        link_sda <= 0;
  163.        sda_buf <= 1;
  164.        end
  165.                                                 end//
  166.
  167.                                                 5:begin
  168.                                                         if(eeprom_scl)
  169.        begin
  170.        if(!eeprom_sda)
  171.        begin
  172.        if(wr == 1)
  173.
  174.        begin
  175.        state <= 6;
  176.        end
  177.        data <= 8'b00000101;//
  178.        end
  179.        end
  180.                                                 end
  181.
  182.                                                 6:begin
  183.                                                         link_sda <= 1;
  184.                                                         if((counter < 8)&&(!eeprom_scl))
  185.        begin
  186.        counter <= counter + 1'b1;
  187.        data <= {data[6:0], data[7]};
  188.        sda_buf <= data[7];
  189.        end
  190.                                                         else if((counter == 8)&&(!eeprom_scl))
  191.        begin
  192.        counter <= 0;
  193.        state <= 7;
  194.        link_sda <= 0;
  195.        end
  196.                                            end
  197.
  198.                                                 7:begin
  199.                                                         if(eeprom_scl)
  200.        begin
  201.        if(!eeprom_sda)
  202.        state <= 8;
  203.        end
  204.
  205.                                                 end
  206.
  207.                                                 8:begin
  208.                                                         link_sda <= 1;
  209.                                                         sda_buf <= 0;//先拉低,再拉高;
  210.                                                         if(eeprom_scl)
  211.                                                          begin
  212.        //led <= 0;
  213.        sda_buf <= 1;
  214.        state <= 0;
  215.        //wr <= 0;
  216.        //led <= 4'b0100;
  217.        //led[0] <= 1;
  218.        //led[1] <= 0;
  219.                                                          end
  220.                                                          //if(Cl_Clk)led[3] <= ~led[3];
  221.                                                 end
  222.                                         default : state <= 0;
  223.                                         endcase
  224.                                 end
  225.                 end
  226. endmodule
tpl0102-ep.pdf
1.07 MB, 下載次數(shù): 27, 下載積分: 黑幣 -5
煉獄傳奇-IIC之戰(zhàn).pdf
934.5 KB, 下載次數(shù): 26, 下載積分: 黑幣 -5
IIC.zip
232.27 KB, 下載次數(shù): 32, 下載積分: 黑幣 -5
ID:15726 發(fā)表于 2020-9-13 19:31 | 顯示全部樓層
學(xué)習(xí)一下IIC知識(shí),感謝分享。
無(wú)效樓層,該帖已經(jīng)被刪除
5#
6#
