int layer[4]={A3,A2,A1,A0}; //初始化和聲明LED層
int column[16]={13,12,11,10,9,8,7,6,5,4,3,2,1,0,A5,A4}; //初始化和聲明LED行
int time = 250;
void setup()
for(int i = 0; i<16; i++)
pinMode(column[i], OUTPUT); //setting rows to ouput
for(int i = 0; i<4; i++)
pinMode(layer[i], OUTPUT); //setting layers to output
randomSeed(analogRead(10)); //seeding random for random pattern
void loop()
turnEverythingOff();
flickerOn();
turnEverythingOn();
delay(time);
turnOnAndOffAllByLayerUpAndDownNotTimed();
layerstompUpAndDown();
spiralInAndOut();
turnOnAndOffAllByColumnSideways();
delay(time);
aroundEdgeDown();
randomflicker();
randomRain();
diagonalRectangle();
goThroughAllLedsOneAtATime();
propeller();
spiralInAndOut();
flickerOff();
delay(2000);
//turn all off 全部關(guān)閉
void turnEverythingOff()
digitalWrite(column[i], 1);
digitalWrite(layer[i], 0);
//turn all on 全部打開
void turnEverythingOn()
digitalWrite(column[i], 0);
//turning on layers
digitalWrite(layer[i], 1);
//turn columns off 關(guān)閉列
void turnColumnsOff()
//flicker on 閃爍
void flickerOn()
int i = 150;
while(i != 0)
turnEverythingOn();
delay(i);
delay(i);
i-= 5;
//turn everything on and off by layer up and down NOT TIMED 按層上下打開和關(guān)閉所有內(nèi)容,不定時
void turnOnAndOffAllByLayerUpAndDownNotTimed()
int x = 75;
for(int i = 5; i != 0; i--)
turnEverythingOn();
for(int i = 4; i!=0; i--)
digitalWrite(layer[i-1], 0);
delay(x);
delay(x);
delay(x);
digitalWrite(layer[i-1], 1);
delay(x);
//turn everything on and off by column sideways 按列橫向打開和關(guān)閉所有內(nèi)容
void turnOnAndOffAllByColumnSideways()
int x = 75;
//turn on layers
for(int y = 0; y<3; y++)
//turn on 0-3
delay(x);
//turn on 4-7
for(int i = 4; i<8; i++)
delay(x);
//turn on 8-11
for(int i = 8; i<12; i++)
delay(x);
//turn on 12-15
for(int i = 12; i<16; i++)
delay(x);
//turn off 0-3
delay(x);
//turn off 4-7
delay(x);
//turn off 8-11
delay(x);
//turn off 12-15
delay(x);
//turn on 12-15
delay(x);
//turn on 8-11
delay(x);
//turn on 4-7
delay(x);
//turn on 0-3
delay(x);
//turn off 12-15
delay(x);
//turn off 8-11
delay(x);
//turn off 4-7
delay(x);
//turn off 0-3
delay(x);
//up and down single layer stomp 上下單層移動
void layerstompUpAndDown()
int x = 75;
for(int y = 0; y<5; y++)
for(int count = 0; count<1; count++)
delay(x);
for(int i = 4; i !=0; i--)
delay(x);
delay(x);
delay(x);
//flicker off
void flickerOff()
turnEverythingOn();
for(int i = 0; i!= 150; i+=5)
delay(i+50);
turnEverythingOn();
delay(i);
//around edge of the cube down 沿著立方體邊緣向下
void aroundEdgeDown()
for(int x = 200; x != 0; x -=50)
for(int i = 4; i != 0; i--)
digitalWrite(column[5], 0);
digitalWrite(column[6], 0);
digitalWrite(column[9], 0);
digitalWrite(column[10], 0);
digitalWrite(column[0], 0);
delay(x);
digitalWrite(column[0], 1);
digitalWrite(column[4], 0);
delay(x);
digitalWrite(column[4], 1);
digitalWrite(column[8], 0);
delay(x);
digitalWrite(column[8], 1);
digitalWrite(column[12], 0);
delay(x);
digitalWrite(column[12], 1);
digitalWrite(column[13], 0);
delay(x);
digitalWrite(column[13], 1);
digitalWrite(column[15], 0);
delay(x);
digitalWrite(column[15], 1);
digitalWrite(column[14], 0);
delay(x);
digitalWrite(column[14], 1);
digitalWrite(column[11], 0);
delay(x);
digitalWrite(column[11], 1);
digitalWrite(column[7], 0);
delay(x);
digitalWrite(column[7], 1);
digitalWrite(column[3], 0);
delay(x);
digitalWrite(column[3], 1);
digitalWrite(column[2], 0);
delay(x);
digitalWrite(column[2], 1);
digitalWrite(column[1], 0);
delay(x);
digitalWrite(column[1], 1);
//random flicker 隨機閃爍
void randomflicker()
int x = 10;
for(int i = 0; i !=750; i+=2)
int randomLayer = random(0,4);
int randomColumn = random(0,16);
digitalWrite(layer[randomLayer], 1);
digitalWrite(column[randomColumn], 0);
delay(x);
digitalWrite(layer[randomLayer], 0);
digitalWrite(column[randomColumn], 1);
delay(x);
//random rain 隨機降雨
void randomRain()
int x = 100;
for(int i = 0; i!=60; i+=2)
digitalWrite(layer[0], 1);
delay(x+50);
digitalWrite(layer[0], 0);
digitalWrite(layer[1], 1);
delay(x);
digitalWrite(layer[1], 0);
digitalWrite(layer[2], 1);
delay(x);
digitalWrite(layer[2], 0);
digitalWrite(layer[3], 1);
delay(x+50);
digitalWrite(layer[3], 0);
//diagonal rectangle 對角矩形
void diagonalRectangle()
int x = 350;
for(int count = 0; count<5; count++)
//top left
for(int i = 0; i<8; i++)
delay(x);
//middle middle
for(int i = 4; i<12; i++)
delay(x);
//bottom right
for(int i = 8; i<16; i++)
delay(x);
//bottom middle
delay(x);
//bottom left
delay(x);
//middle middle
delay(x);
//top right
delay(x);
//top middle
delay(x);
//top left
delay(x);
//propeller 螺旋槳
void propeller()
int x = 90;
for(int y = 4; y>0; y--)
for(int i = 0; i<6; i++)
//turn on layer
digitalWrite(layer[y-1], 1);
//a1
turnColumnsOff();
delay(x);
//b1
turnColumnsOff();
delay(x);
//c1
turnColumnsOff();
delay(x);
//d1
turnColumnsOff();
delay(x);
//d2
turnColumnsOff();
delay(x);
//d3
turnColumnsOff();
delay(x);
//d4
turnColumnsOff();
delay(x);
//spiral in and out 螺旋進出
void spiralInAndOut()
turnEverythingOn();
int x = 60;
//spiral in clockwise
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
digitalWrite(column[5], 1);
delay(x);
digitalWrite(column[6], 1);
delay(x);
digitalWrite(column[10], 1);
delay(x);
digitalWrite(column[9], 1);
delay(x);
//spiral out counter clockwise 逆時針旋出
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
//spiral in counter clock wise 逆時針螺旋
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
//spiral out clock wise 按時鐘方向螺旋輸出
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
delay(x);
//go through all leds one at a time 逐一檢查所有LED
void goThroughAllLedsOneAtATime()
int x = 15;
//0-3
for(int count = 4; count != 0; count--)
digitalWrite(layer[count-1], 1);
delay(x);
delay(x);
digitalWrite(layer[count-1], 0);
//4-7
for(int count = 0; count < 4; count++)
digitalWrite(layer[count], 1);
delay(x);
delay(x);
digitalWrite(layer[count], 0);
//8-11
delay(x);
delay(x);
//12-15
delay(x);
delay(x);
