sbit Led_shengwen=P1^4; //升溫?zé)?/div>
sbit Key_TH1 = P3^2;
sbit Key_TH2 = P3^3;
sbit Key_HH1 = P3^4;
sbit Key_HH2 = P3^5;
//定義標(biāo)識
volatile bit FlagStartRH = 0; //開始溫濕度轉(zhuǎn)換標(biāo)志
volatile bit FlagKeyPress = 0; //有鍵按下
//定義溫濕度傳感器用外部變量
extern U8 U8FLAG,k;
extern U8 U8count,U8temp;
extern U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
extern U8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
extern U8 U8comdata;
extern U8 count,count_r;
U16 temp;
S16 temperature, humidity;
S16 idata TH, HH; //溫度上限和濕度上限
char * pSave;
U8 keyvalue, keyTH1, keyTH2, keyHH1, keyHH2;
//定義變量
U16 RHCounter;
//數(shù)據(jù)初始化
void Data_Init()
RHCounter = 0;
Led_qushi = 1;
Led_jiangwen =1;
Led_shengwen =1;
TH = 40;
HH = 85;
keyvalue = 0;
keyTH1 = 1;
keyTH2 = 1;
keyHH1 = 1;
keyHH2 = 1;
//定時器0初始化
void Timer0_Init()
ET0 = 1; //允許定時器0中斷
TMOD =1; //定時器工作方式選擇
TL0 =0x06;
TH0 =0xf8; //定時器賦予初值
TR0 = 1; //啟動定時器
//定時器0中斷
void Timer0_ISR (void) interrupt 1 using 0
TL0 = 0x06;
//每2秒鐘啟動一次溫濕度轉(zhuǎn)換
RHCounter ++;
if (RHCounter>= 1000)
FlagStartRH= 1;
RHCounter = 0;
//存入設(shè)定值、
void Save_Setting()
pSave = (char *)&TH; //地址低位對應(yīng)低8位,高位對應(yīng)高8位
wrteeprom(0,*pSave); //存溫度上限值TH低8位
DELAY(500);
pSave ++;
wrteeprom(1,*pSave); //存溫度上限值TH高8位
DELAY(500);
pSave = (char *)&HH;
wrteeprom(2,*pSave); //存濕度上限值RH低8位
DELAY(500);
pSave ++;
wrteeprom(3,*pSave); //存濕度上限值RH高8位
DELAY(500);
//載入設(shè)定值、
void Load_Setting()
*pSave++ =rdeeprom(0);
*pSave =rdeeprom(1);
pSave = (char*)&HH;
*pSave++ =rdeeprom(2);
*pSave =rdeeprom(3);
if((TH>99)||(TH<0)) TH = 40;
if((HH>99)||(HH<0)) HH = 85;
void KeyProcess(uint num)
switch (num)
case 1:
if (TH<99) TH++;
L1602_char(1, 15, TH/10+48);
L1602_char(1, 16, TH%10+48);
break;
case 2:
if (TH>1) TH--;
break;
case 3:
if (HH<99) HH++;
L1602_char(2, 15, HH/10+48);
L1602_char(2, 16, HH%10+48);
break;
case 4:
if (HH>1) HH--;
break;
default:
break;
Save_Setting();
* 名稱 : Main()
* 功能 : 主函數(shù)
U16 i, j,testnum;
EA = 0;
Timer0_Init(); //定時器0初始化
Data_Init();
EA = 1;
L1602_init();
L1602_string(1,1,"Welcome to T&H ");
L1602_string(2,1,"Control System! ");
//延時
for(i=0;i<500;i++)
for (j=0;j<1000;j++)
//清屏
L1602_string(1,1," ");
L1602_string(2,1," ");
L1602_string(1,1,"Tem: C TH:");
L1602_string(2,1,"Hum: % HH:");
//載入溫度上限和濕度上限設(shè)定值
Load_Setting();
L1602_char(1,15, TH/10+48);
L1602_char(1,16, TH%10+48);
L1602_char(2,15, HH/10+48);
L1602_char(2,16, HH%10+48);
//溫濕度轉(zhuǎn)換標(biāo)志檢查
if (FlagStartRH == 1)
TR0 = 0;
testnum = RH();
FlagStartRH = 0;
TR0 = 1;
//讀出溫濕度,只取整數(shù)部分
humidity = U8RH_data_H;
temperature = U8T_data_H;
//顯示溫濕度
L1602_int(1,5,temperature);
L1602_int(2,5,humidity);
//溫濕度控制
if(temperature > TH) Led_jiangwen = 0;
elseLed_jiangwen = 1; //降溫
if(humidity > HH) Led_qushi = 0;
elseLed_qushi = 1; //去濕
//鍵盤查詢,在彈起時響應(yīng)
if((Key_TH1)&&(keyTH1==0)) {FlagKeyPress = 1; keyvalue = 1;}
else if((Key_TH2)&&(keyTH2==0)) {FlagKeyPress = 1; keyvalue = 2;}
else if((Key_HH1)&&(keyHH1==0)) {FlagKeyPress = 1; keyvalue = 3;}
else if((Key_HH2)&&(keyHH2==0)) {FlagKeyPress = 1; keyvalue = 4;}
if(FlagKeyPress == 1)
KeyProcess(keyvalue);
FlagKeyPress = 0;
if (!Key_TH1)keyTH1 = 0;
elsekeyTH1 = 1;
if(!Key_TH2) keyTH2 = 0;
elsekeyTH2 = 1;
if(!Key_HH1) keyHH1 = 0;
elsekeyHH1 = 1;
if(!Key_HH2) keyHH2 = 0;
elsekeyHH2 = 1;
2019-6-12 21:20 上傳
全部資料51hei下載地址:
基于單片機的溫濕度系統(tǒng)設(shè)計.zip
(257.92 KB, 下載次數(shù): 112)
2019-6-12 15:26 上傳
點擊文件名下載附件
帶仿真電路
下載積分: 黑幣 -5
