在LED1602顯示時(shí)間 00:00:00
可以顯示溫度。
- module lcd(clk,rs,miao0,miao1,fen2,fen3,shi4,shi5, wendu,rw, en,dat,rst_n);
- input clk;
- input rst_n;
- input [3:0]miao0,miao1,fen2,fen3,shi4,shi5;
- input [15:0] wendu;
- output [7:0] dat;
- output rs,rw,en;
- reg e;
- reg [7:0] dat;
- reg rs;
- reg [15:0] counter;
- reg [4:0] next;
- reg clkr;
- reg [1:0] cnt;
- parameter set0=4'h0;
- parameter set1=4'h1;
- parameter set2=4'h2;
- parameter set3=4'h3;
- parameter set4=4'h4;
- parameter dat0=4'h5;
- parameter dat1=4'h6;
- parameter dat2=4'h7;
- parameter dat3=4'h8;
- parameter dat4=4'h9;
- parameter dat5=4'hA;
- parameter dat6=4'hB;
- parameter dat7=4'hC;
- parameter set5=5'hD;
- parameter dat8=4'hE;
- parameter dat9=4'hF;
- parameter dat10=5'h10;
- parameter dat11=5'h11;
- parameter dat12=5'h12;
- parameter nul=5'h13;
- always @(posedge clk )
- begin
- counter=counter+1;
- if(counter==16'h000f)
- clkr=~clkr;
- end
- always @(posedge clkr)
- begin
- case(next)
- set0: begin rs<=0; dat<=8'h38; next<=set1; end //設(shè)置為顯示2行,數(shù)據(jù)線8位 5x7點(diǎn)陣
- set1: begin rs<=0; dat<=8'h0c; next<=set2; end //顯示功能開,無(wú)光標(biāo)
- set2: begin rs<=0; dat<=8'h6; next<=set3; end //光標(biāo)右移,顯示屏不動(dòng)
- set3: begin rs<=0; dat<=8'h1; next<=set4; end //清屏
- set4: begin rs<=0; dat<=8'h80; next<=dat0; end
- dat0: begin rs<=1; dat<=shi5+8'h30; next<=dat1; end
- dat1: begin rs<=1; dat<=shi4+8'h30; next<=dat2; end
- dat2: begin rs<=1; dat<=":"; next<=dat3; end
- dat3: begin rs<=1; dat<=fen3+8'h30; next<=dat4; end
- dat4: begin rs<=1; dat<=fen2+8'h30; next<=dat5; end
- dat5: begin rs<=1; dat<=":"; next<=dat6; end
- dat6: begin rs<=1; dat<=miao1+8'h30; next<=dat7; end
- dat7: begin rs<=1; dat<=miao0+8'h30; next<=set5; end
- set5: begin rs<=0; dat<=8'hc0; next<=dat8; end
- dat8: begin rs<=1;if (wendu[15]==0) begin dat<="+"; next<=dat9; end
- else begin dat<="-"; next<=dat9; end
- end
- dat9: begin rs<=1;if (wendu[15]==0) begin dat<=((wendu[15:5]/8)%100)/10+8'h30; next<=dat10; end
- else begin dat<=(((~wendu[14:5]+1)/8)%100)/10+8'h30; next<=dat10; end
- end
- dat10: begin rs<=1;if (wendu[15]==0) begin dat<=((wendu[15:5]/8)%100)%10+8'h30; next<=dat11; end
- else begin dat<=(((~wendu[14:5]+1)/8)%100)%10+8'h30; next<=dat11; end
- end
- dat11: begin rs<=1; dat<=8'hdf; next<=dat12; end //顯示° 8'hdf
- dat12: begin rs<=1; dat<="C"; next<=nul; end
- //dat13: begin rs<=1; dat<=" "; next<=nul; end
- nul: begin dat<=" ";next<=set4;end
- default: next<=set0;
- endcase
- end
- assign en=clkr|e;
- assign rw=0; //只寫入
- endmodule
全部資料51hei下載地址:
日時(shí)鐘.7z
(4.96 MB, 下載次數(shù): 15)
2019-7-15 18:29 上傳
點(diǎn)擊文件名下載附件
工程
