本文介紹了基于STC89C51單片機(jī)為核心的,以AD0809數(shù)模轉(zhuǎn)換芯片作為采樣,以四位八段數(shù)碼管作為顯示的具有測量功能的具有一定精度的數(shù)字電壓表。在實(shí)現(xiàn)基礎(chǔ)功能的情況下,另外還可以擴(kuò)展串行口通信,時(shí)鐘,等其他一系列功能,使系統(tǒng)達(dá)到了良好的設(shè)計(jì)效果和要求。本課題主要解決A/D轉(zhuǎn)換,數(shù)據(jù)處理及顯示控制等三個(gè)模塊。
主要系統(tǒng):STC89C51;數(shù)字電壓表;模數(shù)轉(zhuǎn)換;數(shù)字信號
2019-7-24 14:16 上傳
- #define TLC2543_GLOBAL
- #include "TLC2543.h"
- uint read_TLC2543(uchar channel)
- register uchar i;
- uint tempAD = 0;
- while(!TLC2543GetEoc()); //wait TLC2543 free
- _delay_us(3);
- channel <<= 4;
- TLC2543Clk(TLC2543_CLR);
- TLC2543_Cs(TLC2543_SET);
- TLC2543_Cs(TLC2543_CLR); //_CS TLC2543 select
- _delay_us(3);
- for( i = 0; i < 12; i ++ )
- tempAD <<= 1;
- if( TLC2543GetDo() ) //read value
- tempAD |= 0x01;
- if( channel&0x80 )
- TLC2543Di(TLC2543_SET);
- else
- TLC2543Di(TLC2543_CLR);
- channel <<= 1;
- TLC2543Clk(TLC2543_SET);
- nop();
- TLC2543_Cs(TLC2543_SET); //TLC2543 close
- _delay_us(1);
- return tempAD;
- void _delay_us(uint us)
- uchar delayi;
- while(--us)
- for(delayi=0;delayi<10;delayi++);
復(fù)制代碼- #include "led.h"
- const uchar code displayMode=0x0f;
- uchar displayBuff[4]={0x7e,0x7e,0x7e,0x7e}; //數(shù)碼管顯示緩沖區(qū),低兩位為時(shí)間,最高位為搶答號
- const uchar code digitalNumber[10]={0x7e,0x06,0x6d,0x79,0x33,0x5b,0x5f,0x70,0x7f,0x73};
- void main()
- uint voltageReadTemp;
- uint voltageRead;
- uchar temp;
- uchar i,j;
- init_led();
- while(1)
- ledSweepDisplay(displayBuff,displayMode,4);
- voltageRead=read_TLC2543(0x05);
- voltageRead=voltageRead*0x05;
- for(i=4;i>0;i--)
- temp=(uchar)(voltageRead/0x0fff);
- if(i==4)
- displayBuff[i-1]=digitalNumber[temp]|0x80;
- else
- displayBuff[i-1]=digitalNumber[temp];
- voltageRead=voltageRead%0x0fff;
- voltageReadTemp=voltageRead<<1;
- voltageRead=0x0000;
- for(j=0;j<5;j++)
- voltageRead+=voltageReadTemp;//voltageRead=voltageRead*10
數(shù)字電壓表.zip
(25.75 KB, 下載次數(shù): 66)
2019-7-24 10:19 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
