查看: 8581|回復(fù): 32
NTC熱敏電阻查表程序如何轉(zhuǎn)換成溫度顯示?
ID:348282 發(fā)表于 2020-12-14 21:20 | 顯示全部樓層 |閱讀模式
大家好,本人第一次做溫度顯示,有關(guān)于這方面的資料在網(wǎng)上搜索過(guò),但不齊全很難理解,故在這請(qǐng)各位大佬指點(diǎn)下.現(xiàn)在的問(wèn)題是溫度顯示亂碼,不知以下對(duì)應(yīng)數(shù)值表是否正確?
  1. #include <STC15.H>
  2. #include<math.h>
  3. #include"intrins.h"
  5. #define uint  unsigned int
  6. #define ulong unsigned long
  7. #define ADC_POWER   0x80
  8. #define ADC_FLAG    0x10
  9. #define ADC_START   0x08
  10. #define ADC_SPEEDLL 0x00
  11. #define ADC_SPEEDL  0x20
  12. #define ADC_SPEEDH  0x40
  13. #define ADC_SPEEDHH 0x60
  14. void display(uint but);
  15. void Time_Init(void);
  16. void IO_Init(void);
  17. void ADC_Init(void);
  18. sbit b_wei=P1^0;          //百位
  19. sbit s_wei=P1^1;         //十位
  20. sbit g_wei=P1^2;        //個(gè)位
  21. uchar code LED_tk[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x40,0x46,0x79,0xff};
  22. uint volatge=0,Tep=0,measure=38,Temperature=0,tempvalue=0;
  23. volatile uint LS_20ms=0,Bg=0;
  24. volatile uint Num=0,time=0,pmt=3000,temp=0,Pnet=0,Bzeep_ms=200, I_samp=0;
  25. volatile uchar u8Temp_1=0,u8Temp_2=0,u8Temp_3=0,NK=888,ADCcount;
  26. volatile uchar sum=0,SP_10ms=0,Su8Temp_3=0,Su8Temp_2=0,Su8Temp_1=0,Hee_1=0,Hee_2=0,Hee_3=0;
  27. bit Vauel_play_flag=1,shan_flag=0,fan_on_flag=0,Dig_flag=0,Beesp_on_flag=0,Dai_He_flag=0,Beez_u8ge=0,Tne_Bee_flag=0;
  28. bit Temp_flag=0,volue_flag=0;
  29. /**************êy¾Y±í(NTC--10k--B3950)ADÖμ****************/
  30. ulong code  NTCcode[121]={
  31.                            934,930,925,921,916,911,905,900,894,889,  //-10-0
  32.                            883,876,870,864,857,850,843,835,828,820,     //0-10
  33.                            812,804,796,788,779,770,762,753,743,734,     //10-20
  34.                            725,715,706,696,686,676,666,656,646,635,     //20-30
  35.        625,615,604,594,584,573,563,552,542,532,     //30-40
  36.                            522,511,501,491,481,471,461,451,442,432,     //40-50
  37.                            423,413,404,395,386,377,368,360,351,343,     //50-60
  38.                            335,327,319,311,304,296,289,282,275,268,     //60-70
  39.                            261,255,248,242,236,230,224,218,213,207,     //70-80
  40.                            202,197,192,187,182,178,173,169,164,160,     //80-90
  41.                            156,152,148,144,140,137,133,130,127,123,     //90-100
  42.                            120,117,114,111,109,106,103,101,98,96,93};  //100-110
  43.   void ADC_Init()
  44.   {
  45.
  46.    P1ASF=0x30;           //éèÖÃP1.4oíP1.5ÎaÄ£Äaêäèë
  47.
  48.    ADC_RES=0;
  49.    ADC_RESL=0;
  50.    CLK_DIV=0x20;
  51.         ADC_CONTR&=~ADC_FLAG;
  52.    ADC_CONTR=ADC_POWER|ADC_SPEEDHH|ADC_START;
  53.    Delay(5);
  54. }
  55.   uint Get_ADC(uchar channel)
  56.   {
  57.      uint b=0,c=0;
  58.           ADC_RES=0;
  59.           ADC_RESL=0;
  60.
  61.      ADC_CONTR=ADC_POWER|ADC_SPEEDHH|ADC_START|channel;
  62.          _nop_();
  63.          _nop_();
  64.          _nop_();
  65.          _nop_();
  66.
  67.     while(!(ADC_CONTR&ADC_FLAG));
  68.      ADC_CONTR&=~ADC_FLAG;
  69.           b=ADC_RES*256;
  70.           c=ADC_RESL;
  71.           b=b|c;
  72.
  73.      return   b;
  74.   }
  75. /************溫度處理*************/
  76. void fighting_0(void)
  77. {
  78.         uchar N;
  79.         Tep=Get_ADC(4);
  80.         tempvalue=Get_Temperature(Tep);
  81.         for(N=0;N<8;N++)
  82.         {
  83.         Temperature+=tempvalue;
  84.                   _nop_();
  85.                         _nop_();
  86.                         _nop_();
  87.         }
  88.
  89.   Temperature/=8;
  90. }
  91. uint Get_Temperature(uint Adc)  //查表溫度計(jì)算
  92. {
  93.
  94.          uint  i,tmpL,tmpH;
  95.          uint t,ftmp;
  96.          if(Adc<676)//如果小于25度向前查
  97. for(i=25;i>0;i-)//25表示溫度
  98.   {
  99.   if(Adc>NTCcode[i])
  100.   {
  101.   tmpL=NTCcode[i];//實(shí)測(cè)阻值前后溫度
  102.   tmpH=NTCcode[i+1];//用于計(jì)算小數(shù)點(diǎn)位
  103.   t=i; //得到對(duì)應(yīng)溫度
  104.   i=0;
  105.   }
  106. }
  107. else //向后查
  108.         if(Adc>676)
  109. for(i=25;i<121;i++)
  110. {
  111. if( Adc<NTCcode[i])
  112. {
  113. tmpH=NTCcode[i];
  114. tmpL=NTCcode[i-1];
  115. t=i;
  116. i=121;
  117. }
  118. }
  119. //計(jì)算小數(shù)*10整數(shù)
  120. ftmp=(Adc-tmpL)*10/(tmpH-tmpL);
  121. t=t*10+ftmp;
  122. return t;
  123. }
  124. /*************數(shù)碼管顯示*************/
  125. void display(uint but)
  126. {
  127.     uchar i;
  128.          for(i=20;i>0;i--)
  129.          {
  130.    P3=LED_tk[but/100];
  131.    b_wei=1;
  132.    Delay(5);
  133.    b_wei=0;
  134.
  135.    P3=LED_NK[but%100/10];
  136.    s_wei=1;
  137.    Delay(5);
  138.    s_wei=0;
  139.    P3=LED_tk[but%10];
  140.    g_wei=1;
  141.    Delay(5);
  142.    g_wei=0;
  143.          }
  144.   }
  145. void main()
  146. {        IO_Init();
  147.         ADC_Init();
  148.    Time_Init();
  149. while(1)
  150.         {
  151.          fighting_0();
  152. display(Temperature);
  153. }
  154. }
ID:348282 發(fā)表于 2020-12-15 09:09 | 顯示全部樓層
為什么AD讀出來(lái)的值比原來(lái)的大很多??
ID:739545 發(fā)表于 2020-12-15 09:10 | 顯示全部樓層
查表的含義就是和表值進(jìn)行對(duì)比,然后修正成實(shí)際數(shù)值。顯示亂碼的原因更多可能是你調(diào)用的溫度值本身就不對(duì)。P3=LED_NK是什么,都沒(méi)看到定義,是否編譯過(guò)都是問(wèn)題,所以懷疑你壓根就沒(méi)有試驗(yàn),copy代碼就問(wèn)問(wèn)題
參與人數(shù) 1黑幣 +20 收起 理由
ID:348282 發(fā)表于 2020-12-15 09:13 | 顯示全部樓層
就好像要再另外計(jì)算才能對(duì)得上數(shù)值表,但具體是要怎樣計(jì)算呢?
ID:420836 發(fā)表于 2020-12-15 09:38 | 顯示全部樓層
為了準(zhǔn)確地使用NTC熱敏電阻測(cè)量溫度,您需要連接一個(gè)穩(wěn)定的DC電壓作為參考電壓,例如5VDC,然后添加一個(gè)上拉電阻,例如10k ohm。 在已知參考電壓和上拉電阻的情況下,您可以根據(jù)模數(shù)轉(zhuǎn)換器測(cè)量的電壓來(lái)計(jì)算數(shù)字計(jì)數(shù),假設(shè)它是10位ADC,則全5V對(duì)應(yīng)于1024。獲得計(jì)數(shù)后,您可以 可以使用插值法找到NTC熱敏電阻的電阻,然后確定溫度。
ID:348282 發(fā)表于 2020-12-15 10:31 | 顯示全部樓層
lovezjf234 發(fā)表于 2020-12-15 09:10
查表的含義就是和表值進(jìn)行對(duì)比,然后修正成實(shí)際數(shù)值。顯示亂碼的原因更多可能是你調(diào)用的溫度值本身就不對(duì)。 ...
P3=LED_NK[]這是小數(shù)點(diǎn)編碼來(lái)的,LED_tk是沒(méi)有小數(shù)點(diǎn),這個(gè)不重要,主要是溫度轉(zhuǎn)換那里,謝謝。
ID:348282 發(fā)表于 2020-12-15 10:32 | 顯示全部樓層
TTQ001 發(fā)表于 2020-12-15 09:38
為了準(zhǔn)確地使用NTC熱敏電阻測(cè)量溫度,您需要連接一個(gè)穩(wěn)定的DC電壓作為參考電壓,例如5VDC,然后添加一個(gè)上 ...
NTC那里我串聯(lián)一個(gè)5.1K電阻,然后分壓給ADC輸入
ID:852300 發(fā)表于 2020-12-15 10:34 | 顯示全部樓層
是不是用了12位AD的芯片?
ID:348282 發(fā)表于 2020-12-15 10:37 | 顯示全部樓層
有的說(shuō)不用轉(zhuǎn)電壓,就直接AD值查找,有的要轉(zhuǎn)成電壓,各有各的說(shuō),如果表格是溫度的AD數(shù)值則不用轉(zhuǎn)成電壓,如表格是溫度的電壓值或電阻值,則要轉(zhuǎn)成電壓值,或計(jì)算成電阻值。
ID:348282 發(fā)表于 2020-12-15 10:38 | 顯示全部樓層
6620680 發(fā)表于 2020-12-15 10:34
是不是用了12位AD的芯片?
使用的是STC15W408AS芯片,10位AD
ID:348282 發(fā)表于 2020-12-15 10:42 | 顯示全部樓層
現(xiàn)在我的數(shù)表中是用溫度測(cè)量過(guò)的AD值,那么在AD讀取NTC電壓時(shí)不用轉(zhuǎn)成電壓,現(xiàn)在查表會(huì)顯示亂碼就是AD數(shù)值與數(shù)表不對(duì),AD值明顯大于數(shù)表上的值,所以是不是有一些計(jì)算公式來(lái)轉(zhuǎn)換的?
ID:348282 發(fā)表于 2020-12-15 10:46 | 顯示全部樓層
網(wǎng)上關(guān)于NTC溫度查表轉(zhuǎn)換的搜一大片,說(shuō)一半留一半。
ID:213173 發(fā)表于 2020-12-15 13:59 | 顯示全部樓層
law110 發(fā)表于 2020-12-15 10:37
有的說(shuō)不用轉(zhuǎn)電壓,就直接AD值查找,有的要轉(zhuǎn)成電壓,各有各的說(shuō),如果表格是溫度的AD數(shù)值則不用轉(zhuǎn)成電壓 ...
各種說(shuō)法都沒(méi)有說(shuō)錯(cuò),要看你怎么去理解。AD值就是NTC隨溫度變化而變化的電壓數(shù)據(jù),由于熱敏電阻溫阻曲線的非線性,AD轉(zhuǎn)換得到的電壓變化曲線也呈非線性,很難用簡(jiǎn)單公式計(jì)算出來(lái)。所以就通過(guò)數(shù)據(jù)表進(jìn)行比對(duì)(查表法),可以很方便的獲得溫度值。假設(shè)NTC與分壓電阻都是10K,VCC=5V,環(huán)境溫度25度,那么10位ADC結(jié)果就=512,通過(guò)查表得到溫度值=25度。但實(shí)際應(yīng)用中由于外界干擾因素需要平滑濾波,誤差補(bǔ)償?shù)鹊取?/td>
ID:213173 發(fā)表于 2020-12-15 14:06 | 顯示全部樓層
給你一個(gè)制表方法和應(yīng)用示例參考。 10K B3950 NTC溫阻電壓編碼表 上偏電阻2.4K.zip (33.74 KB, 下載次數(shù): 71)
-30~150度數(shù)碼管溫度計(jì)(對(duì)分查表).zip (31.06 KB, 下載次數(shù): 52)
ID:348282 發(fā)表于 2020-12-15 14:30 | 顯示全部樓層
現(xiàn)在的程序中,顯示的亂碼是因?yàn)楝F(xiàn)時(shí)讀到的值與數(shù)據(jù)表對(duì)不上,如果減去讀到的值去比較,就顯示正常,但高溫的時(shí)候上不去,這明顯是要補(bǔ)償計(jì)算。
ID:401564 發(fā)表于 2020-12-15 15:07 | 顯示全部樓層
如果你是有了別人現(xiàn)成的電路和程序,那就直接復(fù)制來(lái)直接用
如果不是,那就得自己設(shè)計(jì),而這NTC溫度查表應(yīng)用本身并不是什么高深技術(shù),自己基礎(chǔ)好點(diǎn)的就可以自己寫代碼和畫電路了
不要怪人家說(shuō)一半留一半,很少是有像小學(xué)生99乘法那樣的完整給你的,你自己肯定要知道原理,如果你連原理都不知道,那還是先看一下ADC和NTC的相關(guān)原理吧1:你要有這個(gè)NTC對(duì)應(yīng)的電阻溫度表
2:選定電路中另一個(gè)分壓電阻的阻值
3:選定參考電壓和ADC電源
4:根據(jù)不同溫度下的NTC阻值和分壓電阻串聯(lián)電阻來(lái)計(jì)算ADC的值
4:溫度表格最好是某段ADC值,比如是:100-800的ADC值對(duì)應(yīng)-10到60攝氏度,這其中,你就要有701個(gè)地址的表格,用來(lái)保證這一段溫度范圍內(nèi)所有ADC的值都能在表格內(nèi)找到
而你的表并不是這樣的,比如開(kāi)始的:934,930....那如果ADC的結(jié)果是932呢?
如果你完全看不明白我說(shuō)的,那就再看一下ADC和NTC相關(guān)的資料就可以了
完全現(xiàn)成的東西可能沒(méi)有,運(yùn)氣好的話能找到,但最好的結(jié)果是你自己會(huì)做
ID:226055 發(fā)表于 2020-12-15 16:09 | 顯示全部樓層
    1、待采集的模擬信進(jìn)單片機(jī)的ADC引腳,理論上都是要求具有盡可能大的輸出阻抗。因?yàn)槿绻斎氲拇杉盘?hào)輸出阻抗和單片機(jī)ADC引腳的對(duì)地等效電阻(芯片內(nèi)部)在一個(gè)數(shù)量級(jí)上,那么很容易影響采集效果。
    2、所以,很多情況下會(huì)采用在待采集信號(hào)后加電壓跟隨器的辦法解決這個(gè)問(wèn)題。下面截圖下艾克姆的NTC熱敏電阻模塊(帶電壓跟隨器)的原理圖幫助大家直觀理解下。
    3、STC15W408芯片沒(méi)有用過(guò),下面附件是STC15W4K56S4關(guān)聯(lián)這個(gè)NTC熱敏電阻傳感器模塊的例程。需要注意NTC熱敏電阻模塊的供電VCC和單片機(jī)的VCC電平一致。這樣10位的ADC采集NTC才是準(zhǔn)的,另外說(shuō)下NTC熱敏電阻型號(hào)是10K  3950。(本人已測(cè)試,測(cè)溫效果很好)
全部資料51hei下載地址:
實(shí)驗(yàn)3-11-4:熱敏傳感器實(shí)驗(yàn) - 模擬量.rar (49.12 KB, 下載次數(shù): 50)
參與人數(shù) 1黑幣 +40 收起 理由
admin + 40 回帖助人的獎(jiǎng)勵(lì)!
ID:348282 發(fā)表于 2020-12-16 08:02 | 顯示全部樓層
多謝各位了,我先嘗試下。
ID:348282 發(fā)表于 2020-12-17 08:59 | 顯示全部樓層
昨天弄一整天,把數(shù)據(jù)表更新下,測(cè)試發(fā)現(xiàn)在用烙鐵靠近NTC時(shí),溫度最高只有70多度就上不去了,測(cè)了NTC輸入電壓是有變化的,但顯示基本沒(méi)什么變化,將上偏電阻原5.1K改為2.4K后,還是這樣子。不知是那里的問(wèn)題?
uint code  NTCcode[]={
                                                  839,838,837,836,835,834,833,832,831,830,
                                                   829,828,827,826,825,824,823,822,821,820,
                                                   819,818,817,816,815,814,813,812,811,810,
                                                   809,808,807,806,805,804,803,802,801,800,
                                                  799,798,797,796,795,794,793,792,791,790,
                                                  789,788,787,786,785,784,783,782,781,780,
                                                  779,778,777,776,775,774,773,772,771,770,
                                                  769,768,767,766,765,764,763,762,761,760,
                                                 759,758,757,756,755,754,753,752,751,750,
                                                 749,748,747,746,745,744,743,742,741,740,
                                                 739,738,737,736,735,734,733,732,731,730,
                                                   729,728,727,726,725,724,723,722,721,720,
                                                   719,718,717,716,715,714,713,712,711,710,
                                                   709,708,707,706,705,704,703,702,701,700,
                                                   699,698,697,696,695,694,693,692,691,690,
                                                   689,688,687,686,685,684,683,682,681,680,
                                                   679,678,677,676,675,674,673,672,671,670,
                                                   669,668,667,666,665,664,663,662,661,660,
                                                  659,658,657,656,655,654,653,652,651,650,
                                                  649,648,647,646,645,644,643,642,641,640,
                                                 639,638,637,636,635,634,633,632,631,630,
                                                 629,628,627,626,625,624,623,622,621,620,
                                                 619,618,617,616,615,614,613,612,611,610,
                                                609,608,607,606,605,604,603,602,601,600,
                                               599,598,597,596,595,594,593,592,591,590,
                                               589,588,587,586,585,584,583,582,581,580,
                                               579,578,577,576,575,574,573,572,571,570,
                                               569,568,567,566,565,564,563,562,561,560,
                                               559,558,557,556,555,554,553,552,551,550,
                                               549,548,547,546,545,544,543,542,541,540,
                                               539,538,837,536,535,534,533,532,531,530,
                                                529,528,527,526,525,524,523,522,521,520,
                                                519,518,517,516,515,514,513,512,511,510,
                                                509,508,507,506,505,504,503,502,501,500,
                                                499,498,487,496,495,494,493,492,491,490,
                                                489,488,487,486,485,484,483,482,481,480,
                                                479,478,477,476,475,474,473,472,471,470,
                                                469,468,467,466,465,464,463,462,461,460,
                                                459,458,457,456,455,454,453,452,451,450,
                                                449,448,447,446,445,444,443,442,441,440,
                                                439,438,437,436,435,434,433,432,431,430,
                                                429,428,427,426,425,424,423,422,421,420,
                                                419,418,417,416,415,414,413,412,411,410,
                                                409,408,407,406,405,404,403,402,401,400,
                                                399,398,397,396,395,394,393,392,391,390,
                                                389,388,387,386,385,384,383,382,381,380,
                                                379,378,377,376,375,374,373,372,371,370,
                                                369,368,367,366,365,364,363,362,361,360,
                                                359,358,357,356,355,354,353,352,351,350,
                                                349,348,347,346,345,344,343,432,341,340,
                                                339,338,337,336,335,334,333,332,331,330,
                                                329,328,327,326,325,324,323,322,321,320,
                                                319,318,317,316,315,314,313,312,311,310,
                                                309,308,307,306,305,304,303,302,301,300,
                                                299,298,297,296,295,294,293,292,291,290,
                                                289,288,287,286,285,284,283,282,281,280,
                                                279,278,277,276,275,274,273,272,271,270,
                                                269,268,267,266,265,264,263,262,261,260,
                                                259,258,257,256,255,254,253,252,251,250,
                                                249,248,247,246,245,244,243,242,241,240,
                                                239,238,237,236,235,234,233,232,231,230,
                                                229,228,227,226,225,224,223,222,221,220,
                                                219,218,217,216,215,214,213,212,211,210,
                                                209,208,207,206,205,204,203,202,201,200,
                                                199,198,197,196,195,194,193,192,191,190,
                                                189,188,187,186,185,184,183,182,181,180,
                                                179,178,177,176,175,174,173,172,171,170,
                                                169,168,167,166,165,164,163,162,161,160,
                                                159,158,157,156,155,154,153,152,151,150,
                                                149,148,147,146,145,144,143,142,141,140,
                                                139,138,137,136,135,134,133,132,131,130,
                                                129,128,127,126,125,124,123,122,121,120,
                                                119,118,117,116,115,114,113,112,111,110};//-10---+110
/************溫度檢測(cè)處理*************/
   uint measure=38;
        Tep=Get_ADC(4);
Temperature=NTCcode[Tep-measure];
  IO_init();
    fighting_0();
ID:348282 發(fā)表于 2020-12-17 09:04 | 顯示全部樓層
這數(shù)據(jù)表的分辨率是0.1度測(cè)量出來(lái),還有當(dāng)NTC受外部高溫影響時(shí),正常是以1度或10度的瞬間上升變化的,但顯示以0.1度的變化上升,不知問(wèn)題出在那里?
ID:348282 發(fā)表于 2020-12-17 09:13 | 顯示全部樓層
這數(shù)據(jù)表發(fā)出來(lái)有延時(shí)。
ID:401564 發(fā)表于 2020-12-17 11:09 | 顯示全部樓層
NTC的溫度表怎么可能是像這樣這么有規(guī)律的呢?
如果你上偏電阻是5.1K,接上10KNTC
那么在10攝氏度的時(shí)候ADC的值是:813
11攝氏度ADC的值是:805
這中間只有8個(gè)數(shù)字量,如果你要表示0.1攝氏度的精度,那肯定是要有誤差的了,比如:813是顯示10.0攝氏度,814也是10.0攝氏度,不然怎么夠分呢?
ID:348282 發(fā)表于 2020-12-17 11:34 | 顯示全部樓層
Y_G_G 發(fā)表于 2020-12-17 11:09
那么在10攝氏度的時(shí)候A ...
現(xiàn)在不是精度問(wèn)題,而是在測(cè)高溫顯示上不去。
ID:401564 發(fā)表于 2020-12-17 13:58 | 顯示全部樓層
law110 發(fā)表于 2020-12-17 11:34
1,你這個(gè)表本身就有問(wèn)題
2,NTC兩頭的電壓有變化,但顯示就是上不去,那無(wú)非就兩個(gè)原因:一個(gè)是ADC數(shù)據(jù)處理出問(wèn)題,一個(gè)查表顯示出問(wèn)題,從這找,很快就能找到原因了
一個(gè)完整的實(shí)用程序并不是那么容易就搞出來(lái)的,網(wǎng)上復(fù)制來(lái)的東西,很多是不行的
你要一步一步來(lái),這NTC顯示溫度并不是什么高深的程序的,慢慢來(lái),幾天就能搞定的
一,你要先寫好顯示部分的代碼,并燒錄運(yùn)行,比如,你要顯示12345,就能顯示12345,保證顯示絕對(duì)正常之后再進(jìn)行下一步
二,寫好ADC和處理的代碼,這ADC肯定是要濾波的,至少是要進(jìn)行8次或者更多次的ADC,然后取平均值,你可以是顯示ADC的值,或者是顯示電壓,用萬(wàn)用表和顯示進(jìn)行對(duì)比,顯示的數(shù)據(jù)和實(shí)際數(shù)據(jù)相差不大,或者是在誤差范圍之內(nèi)的,才能證明你的ADC和顯示部分是OK的
三,用EXCEL或者自己手工寫也行,寫好溫度表格,溫度表格絕對(duì)不會(huì)是像你這個(gè)表格這樣有規(guī)律的,不管是溫度ADC結(jié)果的值還是溫度,都不是規(guī)律的
ID:213173 發(fā)表于 2020-12-17 14:32 | 顯示全部樓層
給你的資料你也不看,實(shí)測(cè)20~100度范圍誤差不超過(guò)0.5度。你那個(gè)程序本來(lái)就有不少問(wèn)題。
ID:348282 發(fā)表于 2020-12-17 16:02 | 顯示全部樓層
wulin 發(fā)表于 2020-12-17 14:32
多謝了,看是看了,但要結(jié)合自己的實(shí)際情況,可能一時(shí)消化不了。
ID:213173 發(fā)表于 2020-12-17 16:26 | 顯示全部樓層
law110 發(fā)表于 2020-12-17 16:02
數(shù)據(jù)表根本不需要做這么大,每度一個(gè)數(shù)據(jù)即可,小數(shù)用插補(bǔ)的方法獲取。何況廠家一般也不會(huì)提供這么精細(xì)的數(shù)據(jù)。
ID:748788 發(fā)表于 2020-12-17 16:27 | 顯示全部樓層
//溫度與NTC電阻阻值對(duì)應(yīng)關(guān)系表
//MF52 10K3435 溫度特性表
uint16 code ntc10k_tab[] = {
// 阻值(Ω),溫度
// 190556, /* -40 */
// 183413, /* -39 */
// 175674, /* -38 */
// 167647, /* -37 */
// 159565, /* -36 */
// 151598, /* -35 */
// 143862, /* -34 */
// 136436, /* -33 */
// 129364, /* -32 */
// 122668, /* -31 */
// 116352, /* -30 */
// 110410, /* -29 */
// 104827, /* -28 */
// 99585, /* -27 */
// 94661, /* -26 */
// 90033, /* -25 */
// 85678, /* -24 */
// 81575, /* -23 */
// 77703, /* -22 */
// 74044, /* -21 */
// 70581, /* -20 */
// 67299, /* -19 */
// 64183, /* -18 */
// 61223, /* -17 */
// 58408, /* -16 */
// 55728, /* -15 */
// 53177, /* -14 */
// 50746, /* -13 */
// 48429, /* -12 */
// 46222, /* -11 */
//44120, /* -10 */
42118, /* -9 */
40212, /* -8 */
38399, /* -7 */
36675, /* -6 */
35036, /* -5 */
33480, /* -4 */
32004, /* -3 */
30603, /* -2 */
29275, /* -1 */
28017, /* 0 */
26826, /* 1 */
25697, /* 2 */
24629, /* 3 */
23618, /* 4 */
22660, /* 5 */
21752, /* 6 */
20892, /* 7 */
20075, /* 8 */
19299, /* 9 */
18560, /* 10 */
18482, /* 11 */
18149, /* 12 */
17632, /* 13 */
16992, /* 14 */
16280, /* 15 */
15535, /* 16 */
14787, /* 17 */
14055, /* 18 */
13354, /* 19 */
12690, /* 20 */
12068, /* 21 */
11490, /* 22 */
10954, /* 23 */
10458, /* 24 */
10000, /* 25 */
9576, /* 26 */
9184, /* 27 */
8819, /* 28 */
8478, /* 29 */
8160, /* 30 */
7861, /* 31 */
7579, /* 32 */
7311, /* 33 */
7056, /* 34 */
6813, /* 35 */
6581, /* 36 */
6357, /* 37 */
6142, /* 38 */
5934, /* 39 */
5734, /* 40 */
5541, /* 41 */
5353, /* 42 */
5173, /* 43 */
4998, /* 44 */
4829, /* 45 */
4665, /* 46 */
4507, /* 47 */
4355, /* 48 */
4208, /* 49 */
4065, /* 50 */
3927, /* 51 */
3794, /* 52 */
3664, /* 53 */
3538, /* 54 */
3415, /* 55 */
3294, /* 56 */
3175, /* 57 */
3058, /* 58 */
2941, /* 59 */
2825, /* 60 */
2776, /* 61 */
2718, /* 62 */
2652, /* 63 */
2582, /* 64 */
2508, /* 65 */
2432, /* 66 */
2356, /* 67 */
2280, /* 68 */
2207, /* 69 */
2135, /* 70 */
2066, /* 71 */
2000, /* 72 */
1938, /* 73 */
1879, /* 74 */
1823, /* 75 */
1770, /* 76 */
1720, /* 77 */
1673, /* 78 */
1628, /* 79 */
1586, /* 80 */
1546, /* 81 */
1508, /* 82 */
1471, /* 83 */
1435, /* 84 */
1401, /* 85 */
1367, /* 86 */
1334, /* 87 */
1301, /* 88 */
1268, /* 89 */
1236, /* 90 */
1204, /* 91 */
1171, /* 92 */
1139, /* 93 */
1107, /* 94 */
1074, /* 95 */
1042, /* 96 */
1010, /* 97 */
979, /* 98 */
948, /* 99 */
// 918, /* 100 */
// 889, /* 101 */
// 861, /* 102 */
// 835, /* 103 */
// 810, /* 104 */
// 787, /* 105 */
// 767, /* 106 */
// 749, /* 107 */
// 733, /* 108 */
// 721, /* 109 */
// 713, /* 110 */
詳見(jiàn):
http://www.torrancerestoration.com/bbs/dpj-197657-1.html
ID:852300 發(fā)表于 2020-12-17 18:22 | 顯示全部樓層
law110 發(fā)表于 2020-12-17 08:59
昨天弄一整天,把數(shù)據(jù)表更新下,測(cè)試發(fā)現(xiàn)在用烙鐵靠近NTC時(shí),溫度最高只有70多度就上不去了,測(cè)了NTC輸入電 ...
上拉電阻一般是1%的10K
ID:852300 發(fā)表于 2020-12-17 18:24 | 顯示全部樓層
wulin 發(fā)表于 2020-12-17 16:26
數(shù)據(jù)表根本不需要做這么大,每度一個(gè)數(shù)據(jù)即可,小數(shù)用插補(bǔ)的方法獲取。何況廠家一般也不會(huì)提供這么精細(xì)的 ...
估計(jì)是上拉電阻用小了,上拉小了,取樣點(diǎn)電壓下不來(lái),顯示值自然上不去!
ID:348282 發(fā)表于 2020-12-17 20:57 | 顯示全部樓層
6620680 發(fā)表于 2020-12-17 18:24
我之前是用了10k上拉電阻,也是這種問(wèn)題.
ID:213173 發(fā)表于 2020-12-18 08:33 | 顯示全部樓層
law110 發(fā)表于 2020-12-17 20:57
NTC配套分壓電阻是可以在很大范圍內(nèi)取值的。要依據(jù)設(shè)備的測(cè)溫跨度范圍選取,通常作低溫檢測(cè)取值較大,作高溫檢測(cè)取值較小,目的是使測(cè)溫范圍的中點(diǎn)電壓大致落在1/2參考電壓附近。所以用于常溫范圍檢測(cè)的NTC配套分壓電阻往往取值與NTC標(biāo)稱值相同。樓主“用烙鐵靠近NTC時(shí),溫度最高只有70多度就上不去了”一般是算法錯(cuò)誤所致。建議樓主用一個(gè)阻值不小于500Ω的電位器代替NTC和分壓電阻的輸入電路,把ADC轉(zhuǎn)換值直接顯示在數(shù)碼管或LCD上,調(diào)整電位器使讀數(shù)在0~1023范圍變化,證明ADC轉(zhuǎn)換沒(méi)有問(wèn)題后再著手解決后期數(shù)據(jù)處理問(wèn)題。否則出現(xiàn)異常胡亂猜測(cè),越理越亂。再次提醒:數(shù)據(jù)表是根據(jù)NTC溫阻表(廠商提供)和所選分壓電阻阻值計(jì)算得到的,其變化曲線呈非線性!絕不是等階遞增遞減。詳見(jiàn)上帖附件《10K B3950 NTC溫阻電壓編碼表 上偏電阻2.4K.zip》
ID:348282 發(fā)表于 2020-12-18 14:48 | 顯示全部樓層
wulin 發(fā)表于 2020-12-18 08:33
NTC配套分壓電阻是可以在很大范圍內(nèi)取值的。要依據(jù)設(shè)備的測(cè)溫跨度范圍選取,通常作低溫檢測(cè)取值較大,作 ...
多謝。我再檢查下。
