2021-1-15 15:54 上傳
- library ieee ;
- use ieee.std_logic_1164.all ;
- use ieee.std_logic_arith.all ;
- use work.butter_lib.all ;
- entity control_main is
- port (
- a_small , sign_a , sign_b : in std_logic ;
- sign_out , add_sub , reset_all : out std_logic ;
- en_sub , en_swap , en_shift , addpulse , normalise : out std_logic ;
- fin_sub , fin_swap , finish_shift , add_finish , end_all : in std_logic ;
- clock_main , clock , reset , enbl , zero_num , change: in std_logic ) ;
- end control_main ;
- architecture rtl of control_main is
- signal current_state , next_state : state ;
- begin
- process (current_state , add_finish , finish_shift , end_all , enbl , clock_main , fin_sub , fin_swap , zero_num , change)
- begin
- case current_state is
- when reset1 =>
- if( enbl = '1' and clock_main = '1') then
- normalise <= '0' ;
- addpulse <= '0' ;
- reset_all <= '1' ;
- next_state <= reset2 ;
- elsif ( enbl = '0') then
- next_state <= reset7 ;-- last state to exit
- else
- next_state <= reset1 ;
- end if ;
- when reset2 =>
- reset_all <= '0' ; -- else values willnot cchange
- en_sub <= '1' ;
- en_swap <= '1' ;
- next_state <= reset3 ;
- when reset3 =>
- if (zero_num = '1') then
- next_state <= reset5 ;
- en_sub <= '0' ;
- en_swap <= '0' ;
- elsif(fin_sub= '1') then
- if(fin_swap = '1') then
- en_shift <= '1' ;
- en_sub <= '0' ;
- en_swap <= '0' ;
- next_state <= reset4 ;
- end if ;
- else
- end if ;
- when reset4 =>
- if (finish_shift = '1') then
- en_shift <= '0' ;
- addpulse <= '1' ;
- else
- end if ;
- when reset5 =>
- normalise <= '1' ;
- next_state <= reset6 ;
- elsif (add_finish = '1') then
- addpulse <= '0' ;
- else
- end if ;
- when reset6 =>
- if (end_all = '1' and clock_main = '1') then
- elsif (end_all = '1' and clock_main = '0') then
- else
- end if ;
- when reset7 =>
- when others =>
- end case ;
- end process ;
- process(clock , reset , change)
- begin
- if(change = '1') then
- current_state <= reset1 ;
- elsif (reset = '1') then
- elsif (clock= '1' and clock'event) then
- current_state <= next_state ;
- end if ;
- end process ;
- process (a_small , sign_a , sign_b)
- begin
- if (sign_a = '0' and sign_b = '0') then
- sign_out <= '0' ;
- add_sub <= '1' ;
- elsif (sign_a = '1' and sign_b = '1') then
- sign_out <= '1' ;
- add_sub <= '1' ;
- elsif (a_small = '1' and sign_a = '0') then
- sign_out <= '1' ;
- add_sub <= '0' ;
- elsif (a_small = '0' and sign_a = '1') then
- sign_out <= '1' ;
- add_sub <= '0' ;
- else
- sign_out <= '0' ;
- add_sub <= '0' ;
- end if ;
- end process ;
- end rtl ;
FFT變換的IP核的源代碼.zip
2021-1-15 14:01 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
35.22 KB, 下載次數(shù): 15, 下載積分: 黑幣 -5
FFT變換的IP核的源代碼.zip
