查看: 1707|回復(fù): 0
Servo+Knob Arduino代碼
ID:1059445 發(fā)表于 2023-1-1 18:02 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
  1. /*
  2. Controlling a servo position using a potentiometer (variable resistor)
  3. modified on 8 Nov 2013
  4. */
  5. #include <Servo.h>
  6. Servo myservo;  // create servo object to control a servo
  7. int potpin = 0;  // analog pin used to connect the potentiometer
  8. int val;    // variable to read the value from the analog pin
  9. void setup() {
  10.   myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  11. }
  12. void loop() {
  13.   val = analogRead(potpin);            // reads the value of the potentiometer (value between 0 and 1023)
  14.   val = map(val, 0, 1023, 0, 180);     // scale it to use it with the servo (value between 0 and 180)
  15.   myservo.write(val);                  // sets the servo position according to the scaled value
  16.   delay(15);                           // waits for the servo to get there
  17. }
