查看: 1571|回復(fù): 11
有沒(méi)有大佬幫忙看看這個(gè)單片機(jī)程序我寫(xiě)的是用tcs230然后用數(shù)碼管顯示
ID:1121149 發(fā)表于 2024-5-17 13:04 | 顯示全部樓層 |閱讀模式
我現(xiàn)在為了測(cè)試我上面的tcs傳感器的程序簡(jiǎn)便使用數(shù)碼管檢驗(yàn)我的顏色傳感器是否可以識(shí)別,我結(jié)果無(wú)論是什么顏色都顯示1,但是我的數(shù)碼管直接不亮,有大佬可以幫我看一下是單片機(jī)程序的問(wèn)題還是我傳感器的問(wèn)題?
#include <reg52.h>
#include<math.h>       //Keil library
#include<stdio.h>      //Keil library
#include<INTRINS.H>
sbit S2 = P0^0;
sbit S3 = P0^1;
sbit OUT = P0^2;
sbit S0 = P0^3;
sbit S1 = P0^4;
sbit P2_0 = P2^0;
sbit P2_1 = P2^1;
sbit P2_2 = P2^2;
sbit P2_3 = P2^3;
int white_balance_red,white_balance_green,white_balance_blue;
uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,
                        0xf8,0x80,0x90};
void delay(unsigned int t) {
    unsigned int i, j;
    for (i = 0; i < t; i++)
        for (j = 0; j < 125; j++);
unsigned int read_pulse() {
          return 100;
void perform_white_balance() {
    S2 = 0;
    S3 = 0;
    delay(100);
    white_balance_red = read_pulse();
    S2 = 1;
    S3 = 1;
    delay(100);
    white_balance_green = read_pulse();
    S2 = 0;
    S3 = 1;
    delay(100);
    white_balance_blue = read_pulse();
unsigned char recognize_color() {
    unsigned int red_pulse, green_pulse, blue_pulse;
    red_pulse = read_pulse();
    green_pulse = read_pulse();
    blue_pulse = read_pulse();
    red_pulse -= white_balance_red;
    green_pulse -= white_balance_green;
    blue_pulse -= white_balance_blue;
    if (red_pulse > 200 && green_pulse > 200 && blue_pulse > 200) {
        return 'W';
    } else if (red_pulse > green_pulse && red_pulse > blue_pulse) {
        return 'R';
    } else if (green_pulse > red_pulse && green_pulse > blue_pulse) {
        return 'G';
    } else if (blue_pulse > red_pulse && blue_pulse > green_pulse) {
        return 'B';
    } else if (red_pulse > 150 && green_pulse > 100 && blue_pulse < 100) {
        return 'Y';
    } else if (red_pulse < 50 && green_pulse < 50 && blue_pulse < 50) {
        return 'K';
    } else {
        return 'U';
void main() {
    unsigned char color;
    perform_white_balance();
    while (1) {
        color = recognize_color_with_white_balance();
        switch (color) {
            case 'W':
        P0=table[0];
        P2_0 = 0;
        delay(5);
        P2_0 = 1;
                break;
            case 'R':   P0=table[0];
                        P2_0 = 0;
                        delay(5);
                        P2_0 = 1;
                break;
            case 'G':   P0=table[0];
        P2_0 = 0;
        delay(5);
        P2_0 = 1;
                break;
            case 'B':   P0=table[0];
        P2_0 = 0;
        delay(5);
        P2_0 = 1;
               break;
            case 'Y':   P0=table[0];
        P2_0 = 0;
        delay(5);
        P2_0 = 1;
                                OLED_Clear();
                break;
            case 'K':   P0=table[0];
   P2_0 = 0;
   delay(5);
   P2_0 = 1;
                break;
ID:879809 發(fā)表于 2024-5-17 14:30 | 顯示全部樓層
white_balance_red這幾個(gè)變量名字太長(zhǎng)了吧,標(biāo)準(zhǔn)c語(yǔ)言支持31字符長(zhǎng)度變量,這么寫(xiě)沒(méi)問(wèn)題。但是C51他不標(biāo)準(zhǔn)啊!查下最多支持幾個(gè)字符?
ID:384109 發(fā)表于 2024-5-17 15:33 | 顯示全部樓層
編譯沒(méi)報(bào)錯(cuò)嗎
ID:161164 發(fā)表于 2024-5-17 17:57 | 顯示全部樓層
你這代碼只會(huì)顯示0,絕不會(huì)顯示1
看不到哪里有讀取tcs230的代碼
ID:1121149 發(fā)表于 2024-5-17 19:08 | 顯示全部樓層
white_balance_red這幾個(gè)變量名字太長(zhǎng)了吧,標(biāo)準(zhǔn)c語(yǔ)言支持31字符長(zhǎng)度變量,這么寫(xiě)沒(méi)問(wèn)題。但是C51他不標(biāo)準(zhǔn) ...
他可以支持255個(gè)但是前32個(gè)有效,但是我在keil上可以編譯但燒入到單片機(jī)上我的顏色傳感器沒(méi)反應(yīng)
ID:1121149 發(fā)表于 2024-5-17 19:29 | 顯示全部樓層
我現(xiàn)在把變量名改短了但是我的數(shù)碼管還是不會(huì)顯示
ID:1121149 發(fā)表于 2024-5-17 21:14 | 顯示全部樓層
lkc8210 發(fā)表于 2024-5-17 17:57
看不到哪里有讀取tcs230的代碼
打錯(cuò)了是0,我的目的就是為了檢驗(yàn)我的tcs230能不能用
ID:1121149 發(fā)表于 2024-5-17 21:22 | 顯示全部樓層
人中狼 發(fā)表于 2024-5-17 15:33
沒(méi)有報(bào)錯(cuò)就是用不了
ID:1121149 發(fā)表于 2024-5-17 21:57 | 顯示全部樓層
看不到哪里有讀取tcs230的代碼
怎么提取呀我不太會(huì)
ID:384109 發(fā)表于 2024-5-17 22:15 | 顯示全部樓層
recognize_color_with_white_balance();這個(gè)代碼在哪里
ID:1121149 發(fā)表于 2024-5-17 23:30 | 顯示全部樓層
人中狼 發(fā)表于 2024-5-17 22:15
好像沒(méi)有那是用recognize_color就好了嘛
ID:384109 發(fā)表于 2024-5-18 19:03 | 顯示全部樓層
forky 發(fā)表于 2024-5-17 23:30
while (1) {
        switch (color) {
感覺(jué)你的問(wèn)題很隨意,答復(fù)的也很隨意
