查看: 482|回復(fù): 2
VERILONG串口單秒發(fā)數(shù)據(jù)簡(jiǎn)單實(shí)例
ID:285416 發(fā)表于 2024-12-24 10:37 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
/*+++++++TOP++++++++++++*/
module uart_tx(
    input                wire            sclk,
        input                wire                  rst_n,
        output                reg         uart_tx
parameter                  CLK_FREQ             =24000000;        //時(shí)鐘頻率50M
parameter                  UART_BAUD             = 115200;        //時(shí)鐘頻率50M
parameter                  MAX_BIT_COUNT         = 31;        //時(shí)鐘頻率50M
localparam                 MAX_BAUD_CNT         = CLK_FREQ / UART_BAUD;//434
reg [7:0] write_data;   //發(fā)送數(shù)據(jù)
//運(yùn)行計(jì)數(shù)器
reg [31:0] run_cnt;        //波特率計(jì)數(shù)器
always @(posedge sclk or negedge rst_n)
begin
    if(rst_n == 1'b0)
        run_cnt <= 32'd0;
    else if(run_cnt == CLK_FREQ)
         run_cnt <= 0;
        run_cnt <= run_cnt + 1;
end
//波特率計(jì)數(shù)器
reg [8:0] baud_cnt;        //波特率計(jì)數(shù)器
reg en_baud_cnt;        //波特率計(jì)數(shù)器開(kāi)關(guān)
begin
    if(rst_n == 1'b0)
        baud_cnt <= 8'd0;
    else if(en_baud_cnt == 1'b1) begin
        if(baud_cnt == MAX_BAUD_CNT)
            baud_cnt <= 8'd0;
            baud_cnt <= baud_cnt + 1;
    end
        baud_cnt <= baud_cnt;
end
//發(fā)送位計(jì)數(shù)器
reg [4:0] bit_cnt = 0;        //波特率計(jì)數(shù)器
begin
    if(rst_n == 1'b0)
        bit_cnt <= 4'd0;
    else if(baud_cnt == MAX_BAUD_CNT)
        begin
            if(bit_cnt ==  MAX_BIT_COUNT)
                bit_cnt <= 4'd0;
                bit_cnt <= bit_cnt + 1;
        end
        bit_cnt <= bit_cnt;
end
//位發(fā)送邏輯
begin
    if(rst_n == 1'b0)
        uart_tx <= 1'b0;
    else if(baud_cnt == MAX_BAUD_CNT/2)
        begin
            if(bit_cnt ==  0)
                uart_tx <= 1'b0;
            else if(bit_cnt == MAX_BIT_COUNT)
                uart_tx <= 1'b1;
            begin
            case(bit_cnt)
                1:uart_tx <= write_data[0];
                2:uart_tx <= write_data[1];
                3:uart_tx <= write_data[2];
                4:uart_tx <= write_data[3];
                5:uart_tx <= write_data[4];
                6:uart_tx <= write_data[5];
                7:uart_tx <= write_data[6];
                8:uart_tx <= write_data[7];
                default:uart_tx <= uart_tx;
            endcase
            end
            //uart_tx <= write_data[bit_cnt-1];
        end
        uart_tx <= uart_tx;
end
begin
    if(rst_n == 1'b0)
        en_baud_cnt <= 1'b0;
    else if(run_cnt == 0) begin
        en_baud_cnt <= 1'b1;
    end
    else if(bit_cnt ==  MAX_BIT_COUNT && baud_cnt == MAX_BAUD_CNT)
        en_baud_cnt <= en_baud_cnt;
end
begin
    if(rst_n == 1'b0)
        write_data <= 8'd0;
        write_data <= write_data + 1;
        write_data <= write_data;
end
endmodule
畫(huà)紅線的一個(gè)小問(wèn)題,有沒(méi)有人幫我解釋一下?
寄存器是八位的最大數(shù)值255
但是
MAX_BAUD_CNT數(shù)值是434這個(gè)應(yīng)該怎么理解?
ID:275826 發(fā)表于 2024-12-25 17:00 | 只看該作者
reg [8:0] baud_cnt;是9位
ID:285416 發(fā)表于 2024-12-26 18:32 來(lái)自觸屏版 | 只看該作者
對(duì)對(duì)對(duì)  我,low   真是一起語(yǔ)醒夢(mèng)中人   謝謝
