查看: 3579|回復: 0
FPGA之VHDL的74HC161和74HC90court
ID:262 發(fā)表于 2014-10-21 15:23 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
一、74HC161
Library ieee;
Use ieee.std_logic_1164.all;
Use ieee.std_logic_unsigned.all;
Entity LS74161 is
Port(ENT,ENP,CLK,MR,LD:in std_logic;
                     D:in std_logic_vector(3 downto 0);
       Q:out std_logic_vector(3 downto 0);
        Co:out std_logic);
end;
Architecture LS of LS74161 is
signal qq:std_logic_vector(3 downto 0);
begin
process(ENT,ENP,CLK,MR,LD,D)
   begin
if ENT='1' and ENP='1' then
    if CLK'event and CLK='1' then
       if LD='0' then qq<=D;
     else qq<=qq+1;
     end if;
     if qq=15 then Co<='1';
     else Co<='0';
     end if;
   end if;
  end if;
  end process;
  Q<=qq;
  end;
二、74HC90
Library ieee;
Entity HC90 is
Port(CLK0,CLK1:in std_logic;
     S9,R0:in std_logic_vector(1 downto 0);
      Q:out std_logic_vector(2 downto 0);
        Q0:out std_logic);
end;
Architecture LS of HC90 is
signal qq:std_logic_vector(2 downto 0);
signal qq0:std_logic;
begin
process(CLK0,CLK1,S9,R0)
   begin
if CLK0'event and CLK0='0' then
    qq0<=not qq0;
end if;
if CLK1'event and CLK1='0' then
         if qq=4 then qq<="000";
     else qq<=qq+1;
     end if;
end if;
if S9=3 then qq<="100";qq0<='1';
end if;
if R0="11" then qq<="000";qq0<='0';
end if;
end process;
Q<=qq;Q0<=qq0;
  end;
