Library ieee;
Use ieee.std_logic_1164.all;
Use ieee.std_logic_unsigned.all;
Entity water is
Port(clk:in std_logic;
RW,EN:out std_logic;
LCD_Data:out std_logic_vector(8 downto 0);
LEDR:out std_logic_vector(17 downto 0);
second:out std_logic;
Qb0,Qb1:out std_logic_vector(3 downto 0);
Qd0,Qd1:out std_logic_vector(6 downto 0));
end;
Architecture dd of water is
signal Qsfp,Qwfp:std_logic_vector(24 downto 0);
signal cps,cpw,LCD_clk:std_logic;
signal qq0,qq1:std_logic_vector(3 downto 0);
signal N:integer range 0 to 73;
signal s:integer range 0 to 1000000;
procedure sum( x:in std_logic_vector(3 downto 0);
y:out std_logic_vector(6 downto 0))is
begin
case x is
when"0000"=>y:="0111111";
when"0001"=>y:="0000110";
when"0010"=>y:="1011011";
when"0011"=>y:="1001111";
when"0100"=>y:="1100110";
when"0101"=>y:="1101101";
when"0110"=>y:="1111101";
when"0111"=>y:="0000111";
when"1000"=>y:="1111111";
when"1001"=>y:="1101111";
when others=>y:=Null;
end case;
end sum;
begin
-------cps means 1s---cpw means flash LED------
Process(clk)
begin
if clk'event and clk='1' then
Qsfp<=Qsfp+1; --1s court
Qwfp<=Qwfp+1; --0.1s court
s<=s+1;
if Qsfp=24999999 then
Qsfp<="0000000000000000000000000";
cps<=not cps; --1Hz
end if;
if Qwfp=1499999 then
Qwfp<="0000000000000000000000000";
cpw<=not cpw; --10Hz
end if;
if s=0 then
LCD_clk<= not LCD_clk;
end if;
end if;
end process;
-------------- 60s court--------------
Process(cps)
begin
if cps'event and cps='1' then
qq0<=qq0+1;
------ge-------
if qq0=9 then
qq0<="0000";
qq1<=qq1+1;
end if;
------shi-------
if qq1=5 and qq0=9 then
qq1<="0000";
end if;
end if;
end process;
----------display 60s court-------
process(qq0,qq1,cps)
variable y0,y1:std_logic_vector(6 downto 0);
begin
second<=cps;
Qb0<=qq0;
Qb1<=qq1;
sum(qq0,y0);
sum(qq1,y1);
Qd0<=not y0;
Qd1<=not y1;
end process;
---------display flash LED-----------
Process(cpw)
begin
if cpw'event and cpw='1' then
N<=N+1;
if N=90 then
N<=0;
end if;
if N<18 then
LEDR(N)<='1';
end if;
if N>17 and N<36 then
LEDR(35-N)<='0';
end if;
if N>35 and N<54 then
LEDR(N-36)<='0';
LEDR(N-35)<='1';
end if;
if N>53 and N< 73 then
LEDR(72-N)<='0';
LEDR(71-N)<='1';
end if;
if N>72 and N< 81 then
LEDR(N-72)<='1';
LEDR(90-N)<='1';
end if;
If N>80 and N<90 then
LEDR(N-71)<='0';
LEDR(90-N)<='0';
end if;
end if;
end process;
------------Display LCD------------------
EN<=LCD_clk;
RW<='0';
process(LCD_clk)
variable cnt:std_logic_vector(5 downto 0);
begin
if LCD_clk'event and LCD_clk='1' then
cnt:=cnt+1;
case cnt is
--------------寫指令--------------
when "000000"=>LCD_Data<="000111000";--/*設(shè)置8位格式,2行,5*7*/ ,順序2,3的要求
when "000001"=>LCD_Data<="000001100"; --/*整體顯示,關(guān)光標(biāo),光標(biāo)閃爍/ ,順序4的要求
when "000010"=>LCD_Data<="000000001";--清屏,順序5的要求
when "000011"=>LCD_Data<="000000110"; --/*顯示移動(dòng)格式,看最后兩位,10表示光標(biāo)右移,順序6的要求
when "000100"=>LCD_Data<="010000000";--設(shè)定顯示的位置在00H+80H,即顯示屏第一行第一個(gè)位置,順序7的要求
--------------寫數(shù)據(jù)---------------
when "000101"=>LCD_Data<="110100000";--空格
when "000110"=>LCD_Data<="110100000";--空格
when "000111"=>LCD_Data<="110100000";--空格
when "001000"=>LCD_Data<="101011001"; --Y
when "001001"=>LCD_Data<="101110101";--u
when "001010"=>LCD_Data<="101101010";--j
when "001011"=>LCD_Data<="101101001";--i
when "001100"=>LCD_Data<="101100001";--a
when "001101"=>LCD_Data<="101101110";--n
when "001110"=>LCD_Data<="101110001";--q
when "001111"=>LCD_Data<="101110101";--u
when "010000"=>LCD_Data<="101100001";--a
when "010001"=>LCD_Data<="101101110";--n
when "010010"=>LCD_Data<="110100000";---空格
when "010011"=>LCD_Data<="110100000";---空格
when "010100"=>LCD_Data<="110100000";---空格
when "010101"=>LCD_Data<="011000000";--設(shè)定顯示的位置在10H+80H,
when "010110"=>LCD_Data<="101000100";---D diangong xueyuan
when "010111"=>LCD_Data<="101101001";---i
when "011000"=>LCD_Data<="101100001";---a
when "011001"=>LCD_Data<="101101110";---n
when "011010"=>LCD_Data<="101100111";---g
when "011011"=>LCD_Data<="101101111";---o
when "011100"=>LCD_Data<="101101110";--n
when "011101"=>LCD_Data<="101100111";---g
when "011110"=>LCD_Data<="110100000";--- 空格
when "011111"=>LCD_Data<="101011000";---X
when "100000"=>LCD_Data<="101110101";---u
when "100001"=>LCD_Data<="101100101";---e
when "100010"=>LCD_Data<="101111001";---y
when "100011"=>LCD_Data<="101110101";---u
when "100100"=>LCD_Data<="101100001";---a
when "100101"=>LCD_Data<="101101110";---n
when others =>LCD_Data<="110100000";
--when "01100"=>LCD_Data<="011000000";--設(shè)定顯示的位置在10H+80H,即顯示屏第2行第一個(gè)位置
end case;
end if;
end process;
end;
