查看: 6009|回復: 0
關于FPGA的VHDL算數(shù)運算
ID:51269 發(fā)表于 2014-11-10 15:24 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
    算數(shù)運算時FPGA編程設計中常會用到的功能,其規(guī)則直接影響變成效果,調(diào)用use  ieee.std_logic_unsigned.all;此程序包對不同的數(shù)據(jù)類型可以進行適當?shù)乃銛?shù)運算:
   1.std_logic_vector()可進行相同位數(shù)的加減運算(被加數(shù)必須和輸出位數(shù)相同);
   2.std_logic_vector()可進行相乘法運算(積的位數(shù)等于倆乘數(shù)位數(shù)之和);
Library ieee;
Use ieee.std_logic_1164.all;
Use ieee.std_logic_unsigned.all;
entity adder_n is
port(a,b:in std_logic_vector(4 downto 0);
     c:in std_logic_vector(2 downto 0);
     Sum1,sum2:out std_logic_vector(9 downto 0);
     sum4,sum3 :out std_logic_vector(4 downto 0) );
end;
Architecture add of adder_n is
begin
Sum1<="00000"&a + b;
Sum2<=a * b;
sum3<=a - b;
sum4<=a + b;
end;
3.Integer(整數(shù))可以進行加、減、乘、除和取余運算;
Library ieee;
Useieee.std_logic_1164.all;
Useieee.std_logic_unsigned.all;
entity adder_n is
generic(n:integer:=4);----改變w的值可以改變運算寬度
port(a:in integerrange 0 to 4095;
     dd,b:in integer range 0 to 255;
     cin:in integer range 0 to 64;
     Sum1,sum2:out integer range 0 to 4095;
     ddd:out integer range 0 to 1023;
     co1,co2:out integer range 0 to 1023);
end;
begin
Sum1<=a * b;---a,b一個可以是常數(shù),如 Sum1<=2 * b
sum2<=a + b;
ddd<=a / b;---- 雖然是除,但實際為商 取整運算
co1<=a - dd;
co2<= a REM cin;  ---  取余
  end;
