- 1-9為數(shù)字鍵,p2.0為小數(shù)點(diǎn),p2.3為確認(rèn)鍵,p2,4為取消鍵,可以定時(shí)范圍0-99分鐘 ,時(shí)間到達(dá)后亮燈或者蜂鳴,O(∩_∩)O哈哈~
- ORG 00H
- START:
- MOV P0, #00H
- MOV R0, #2;
- CLR P2.7 ;
- SETTING:
- CHK_0:
- JB P1.0, CHK_1;
- CALL FILTER
- JNB P1.0, $
- MOV R1, #0
- JMP TIMERSET
- CHK_1:
- JB P1.1, CHK_2;
- CALL FILTER
- JNB P1.2, $
- MOV R1, #1
- JMP TIMERSET
- CHK_2:
- JB P1.2, CHK_3;
- CALL FILTER
- JNB P1.2, $
- MOV R1, #2
- JMP TIMERSET
- CHK_3:
- JB P1.3, CHK_4;
- CALL FILTER
- JNB P1.3, $
- MOV R1, #3
- JMP TIMERSET
- CHK_4:
- JB P1.4, CHK_5;
- CALL FILTER
- JNB P1.4, $
- MOV R1, #4
- JMP TIMERSET
- CHK_5:
- JB P1.5, CHK_6;
- CALL FILTER
- JNB P1.5, $
- MOV R1, #5
- JMP TIMERSET
- CHK_6:
- JB P1.6, CHK_7;
- CALL FILTER
- JNB P1.6, $
- MOV R1, #6
- JMP TIMERSET
- CHK_7:
- JB P1.7, CHK_8;
- CALL FILTER
- JNB P1.7, $
- MOV R1, #7
- JMP TIMERSET
- CHK_8:
- JB P2.1, CHK_9;
- CALL FILTER
- JNB P2.1, $
- MOV R1, #8
- JMP TIMERSET
- CHK_9:
- JB P2.2, CHK_AGAIN;
- CALL FILTER
- JNB P2.2, $
- MOV R1, #9
- JMP TIMERSET
- CHK_AGAIN:
- JMP CHK_0
- TIMERSET:
- DJNZ R0, LSB
- JMP MSB
- LSB:
- MOV 30H, R1
- JMP SETTING
- MSB:
- MOV A , R1
- SWAP A
- ADD A ,30H
- MOV 31H, A
- MOV P0, A
- CONFIRM:
- OK:
- JB P2.3, CANCEL
- CALL FILTER
- JNB P2.4, $
- MOV A, #00H
- JMP TIMING
- CANCEL:
- JB P2.4, OK
- CALL FILTER
- JNB P2.4 , $
- RESTART:
- JMP START
- TIMING:
- MOV P0 , A
- MIN:
- MOV R0, #60
- SEC:
- MOV R1, #10
- SEC_10:
- MOV R2, #200
- CALL DELAY
- DJNZ R1, SEC_10
- CPL P2.0
- DJNZ R0, SEC
- ADD A, #1
- DA A
- CJNE A, 31H,TIMING
- BEEP:
- MOV R2, #5;
- REPEAT:
- SETB P2.7
- CALL LONGDELAY
- CLR P2.7
- CALL LONGDELAY
- DJNZ R2,REPEAT
- JMP START
- DELAY:
- MOV R3, #248
- JNB P2.4, RESTART
- DJNZ R3, $
- DJNZ R2, DELAY
- RET
- FILTER:
- MOV R6, #60
- F1:
- MOV R7, #248
- DJNZ R7, $
- DJNZ R6, F1
- RET
- LONGDELAY:
- MOV R3, #50
- DL1:
- MOV R4, #20
- DL2:
- MOV R5, #248
- DJNZ R5,$
- DJNZ R4, DL2
- DJNZ R3 , DL1
- RET
- END
