查看: 3406|回復(fù): 2
求告訴思路關(guān)于交通燈
ID:66468 發(fā)表于 2015-1-20 18:13 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
我下面的程序是實(shí)現(xiàn)了主干道14、3s和9s的切換,接下來(lái)是想實(shí)現(xiàn)對(duì)應(yīng)的支干道9s、3s和14秒的切換,在8個(gè)數(shù)碼管上同時(shí)實(shí)現(xiàn)切換,該如何寫(xiě),請(qǐng)各位大神提高下思路。
程序?yàn)椋?br /> #include<reg52.h>
typedef unsigned int  uint;
typedef unsigned char uchar;
#define SegPort   P2
sbit duan=P1^0;
sbit beef=P1^5;//定義蜂鳴器
uchar  code  segcode[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
uchar code bitcode[]={0xfe,0xfd,0xef,0xdf};
uchar major_count,minor_count,led_num; //major_count主干道信息,minor_count次干道信息
uchar LED_dispbuf[4];
unsigned int  num,Ex_Num;//Ex_Num交換次數(shù)
uchar data  _1s_flag;
uchar data  _2ms_flag;
void init(void)
        TMOD=0x01;
        TH0=(65536-2000)/256;
        TL0=(65536-2000)%256;
        EA=1;
        ET0=1;
        TR0=1;
        Ex_Num=3;
        major_count=9;
        num=0;
        led_num=0;
        _1s_flag=0;
        _2ms_flag=0;
void T0_timer0(void) interrupt 1
        _2ms_flag=1;
        num++;
        if(num==500)
                num=0;
                _1s_flag=1;
void  display(uchar major_Data)
        LED_dispbuf[0]=major_Data/10;
        LED_dispbuf[1]=major_Data%10;
        LED_dispbuf[2]=major_Data/10;
        LED_dispbuf[3]=major_Data%10;
        if(_2ms_flag==1)
                _2ms_flag=0;
                if(major_count<4)        //倒計(jì)時(shí)小于3s后閃爍
                        if(num<150)
                                P0=0xff;
                                beef=1;
                                 P0=bitcode[led_num];
                                 beef=0;
                duan=1;
                SegPort=segcode[LED_dispbuf[led_num]];
                duan=0;
                led_num++;
                if(led_num>3)
                led_num=0;
void LED_Exchange(void)
        switch(Ex_Num)
                case 3:
                    uchar SynNum_1=10; //同步遞減變量1
                                if(_1s_flag==1)
                                        _1s_flag=0;
                                        display(major_count);
                                        major_count--;
                                    SynNum_1--;
                                        if(SynNum_1==0)
                                                break;
                        Ex_Num=2;
                        major_count=4;
            };break;
                case 2:
                           uchar SynNum_2=5; //同步遞減變量2
                                if(_1s_flag==1)
                                        _1s_flag=0;
                                        major_count--;
                                        SynNum_2--;
                                        if(SynNum_2==0)
                                                break;
                        Ex_Num=1;
                        major_count=14;
                        };break;
                case 1:
                        uchar SynNum_3=15; //同步遞減變量3
                                if(_1s_flag==1)
                                        _1s_flag=0;
                                        major_count--;
                                        SynNum_3--;
                                        if(SynNum_3==0)
                                                break;
                        Ex_Num=3; //返回到初始時(shí)刻
                        major_count=9;
                };break;
void main(void)
        init();
                LED_Exchange();
ID:196241 發(fā)表于 2017-5-6 21:16 | 只看該作者
樓主程序語(yǔ)言設(shè)計(jì)學(xué)了多長(zhǎng)時(shí)間  真厲害
ID:116078 發(fā)表于 2017-5-7 12:41 | 只看該作者
* 實(shí)驗(yàn)名                           : 動(dòng)態(tài)顯示數(shù)碼管實(shí)驗(yàn)
* 使用的IO             :
* 實(shí)驗(yàn)效果       : 數(shù)碼管顯示76543210。
*        注意                                         :當(dāng)位選用P1口的時(shí)候注意可能會(huì)有一位不亮,那么調(diào)整J21
#include<reg51.h>
//--定義使用的IO口--//
#define GPIO_DIG   P0
#define GPIO_PLACE P1
#define GPIO_TRAFFIC P2
sbit RED10   = P2^0;   //上人行道紅燈
sbit GREEN10 = P2^1;   //上人行道綠燈
sbit RED11   = P2^2;
sbit YELLOW11= P2^3;
sbit GREEN11 = P2^4;
sbit RED00   = P3^0;        //右人行道紅燈
sbit GREEN00 = P3^1;        //右人行道綠燈
sbit RED01   = P2^5;
sbit YELLOW01= P2^6;
sbit GREEN01 = P2^7;
//--定義全局變量--//
unsigned char code DIG_PLACE[8] = {
0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//位選控制   查表的方法控制
unsigned char code DIG_CODE[17] = {
//0、1、2、3、4、5、6、7、8、9、A、b、C、d、E、F的顯示碼
unsigned char DisplayData[8];
//用來(lái)存放要顯示的8位數(shù)的值
unsigned char Time, Second;                  //用來(lái)存放定時(shí)時(shí)間
//--聲明全局函數(shù)--//
void DigDisplay(); //動(dòng)態(tài)顯示函數(shù)
void Timer0Cofig(void);
* 函 數(shù) 名         : main
* 函數(shù)功能                   : 主函數(shù)
* 輸    入         : 無(wú)
* 輸    出         : 無(wú)
void main(void)
        Second = 1;
        Timer0Cofig();
                if(Second == 70)
                        Second = 1;
                //--寶田路通行,30秒--//
                if(Second < 31)
                        DisplayData[0] = 0x00;
                        DisplayData[1] = 0x00;
                        DisplayData[2] = DIG_CODE[(30 - Second) % 100 / 10];
                        DisplayData[3] = DIG_CODE[(30 - Second) %10];
                        DisplayData[4] = 0x00;
                        DisplayData[5] = 0x00;
                        DisplayData[6] = DisplayData[2];
                        DisplayData[7] = DisplayData[3];
                        DigDisplay();
                        //--寶田路通行--//
                        GPIO_TRAFFIC = 0xFF;  //將所有的燈熄滅
                        RED00 = 1;
                        GREEN00 = 1;
                        GREEN11 = 0;    //寶田路綠燈亮
                        GREEN10        = 0;    //寶田路人行道綠燈亮
                        RED01 = 0;      //前進(jìn)路紅燈亮
                        RED00 = 0;      //前進(jìn)路人行道紅燈亮
                //--黃燈等待切換狀態(tài),5秒--//
                else if(Second < 36)
                        DisplayData[2] = DIG_CODE[(35 - Second) % 100 / 10];
                        DisplayData[3] = DIG_CODE[(35 - Second) %10];
                        DigDisplay();
                        //--黃燈階段--//
                        RED00 = 1;
                        GREEN00 = 1;
                        YELLOW11 = 0;    //寶田路黃燈亮
                        RED10        = 0;     //寶田路人行道紅燈亮
                        YELLOW01 = 0;    //前進(jìn)路紅燈亮
                //--前進(jìn)路通行--//
                else if(Second < 66)
                        DisplayData[2] = DIG_CODE[(65 - Second) % 100 / 10];
                        DisplayData[3] = DIG_CODE[(65 - Second) %10];
                        DigDisplay();
                        //--黃燈階段--//
                        RED00 = 1;
                        GREEN00 = 1;
                        RED11 = 0;       //寶田路紅燈亮
                        GREEN01 = 0;     //前進(jìn)路綠燈亮
                        GREEN00 = 0;     //前進(jìn)路人行道綠燈亮
                        DisplayData[2] = DIG_CODE[(70 - Second) % 100 / 10];
                        DisplayData[3] = DIG_CODE[(70 - Second) %10];
                        DigDisplay();
                        //--黃燈階段--//
                        RED00 = 1;
                        GREEN00 = 1;
* 函 數(shù) 名         : DigDisplay
* 函數(shù)功能                   : 使用數(shù)碼管顯示
* 輸    入         : 無(wú)
* 輸    出         : 無(wú)
void DigDisplay()
        unsigned char i;
        unsigned int j;
        for(i=0; i<8; i++)
                GPIO_PLACE = DIG_PLACE[i];           //發(fā)送位選
                GPIO_DIG = DisplayData[i];     //發(fā)送段碼
                j = 10;                                                   //掃描間隔時(shí)間設(shè)定
                while(j--);
                GPIO_DIG = 0x00;               //消隱
* 函 數(shù) 名         : Timer0Cofig
* 函數(shù)功能                   : 配置定時(shí)器
* 輸    入         : 無(wú)
* 輸    出         : 無(wú)
        TMOD = 0x01;     //定時(shí)器0選擇工作方式1
    TH0  = 0x3C;         //設(shè)置初始值,定時(shí)50MS
    TL0  = 0xB0;
    EA   = 1;             //打開(kāi)總中斷
    ET0  = 1;                 //打開(kāi)定時(shí)器0中斷
    TR0  = 1;                 //啟動(dòng)定時(shí)器0
* 函數(shù)功能                   : 定時(shí)器0中斷函數(shù)
* 輸    入         : 無(wú)
* 輸    出         : 無(wú)
void Timer0() interrupt 1
        TL0 = 0xB0;
        Time++;
        if(Time == 20)
                Second ++;
                Time = 0;
