是用51hei單片機(jī)開發(fā)板 電路圖詳見:http://www.torrancerestoration.com/f/51hei-5.pdf 的數(shù)碼管部分, 用2個(gè)74hc573 鎖存,p0口作為數(shù)據(jù)口 ,p3.6和p3.7分別是段和位的鎖存端口.
- #include<reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar code SEG7[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- sbit D=P3^6;
- sbit V=P3^7;
- void delay(uint k)
- uint i,j;
- for(i=0;i<k;i++){
- for(j=0;j<121;j++)
- void main(void)
- uint s,sum;
- for(s=50;s<=100;s=s+2)
- {sum=sum+s;}
- while(1)
- D=1;P0=SEG7[sum%10];D=0;P0=0xff;V=1;P0=0xf7;V=0;delay(5);
- D=1;P0=SEG7[(sum%100)/10];D=0;P0=0xff;V=1;P0=0xfb;V=0;delay(5);
- D=1;P0=SEG7[(sum/100)%10];D=0;P0=0xff;V=1;P0=0xfd;V=0;delay(5);
- D=1;P0=SEG7[sum/1000];D=0;P0=0xff;V=1;P0=0xfe;V=0;delay(5);
