查看: 5658|回復(fù): 0
51單片機(jī)+無字庫12864測試程序(縱向取模。字節(jié)倒序)
ID:72705 發(fā)表于 2015-1-24 15:34 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
  1. /***********************************************************************
  2.         無字庫12864測試程序(縱向取模。字節(jié)倒序)
  3.                          crasyboye
  4. ***********************************************************************/
  5. #include <reg51.h>
  6. #include <ctype.h>
  7. #include <string.h>
  8. #include <stdlib.h>
  9. #include <stdio.h>
  10. #include <math.h>
  11. /* Define the register command code */
  12. #define Disp_On 0x3f
  13. #define Disp_Off 0x3e
  14. #define Col_Add 0x40
  15. #define Page_Add 0xb8
  16. #define Start_Line 0xc0
  17. #define Lcd_Bus P0 //MCU P1<------> LCM
  18. sbit Mcs=P2^3; //Master chip enable
  19. sbit Scs=P2^4; //Slave chip enable
  20. sbit Enable=P2^2; //6800 mode Enable single
  21. sbit Di=P2^0; //Data or Instrument Select
  22. sbit RW=P2^1; //Write or Read
  23. sbit Lcd_Rst=P2^5; //Lcm reset
  24. char code ce[]={
  25. /*-- 文字: 測 --*/
  26. /*-- 宋體12; 此字體下對應(yīng)的點(diǎn)陣為:寬x高=16x16 --*/
  27. 0x08,0x31,0x86,0x60,0x00,0xFE,0x02,0xF2,0x02,0xFE,0x00,0xF8,0x00,0x00,0xFF,0x00,
  28. 0x04,0xFC,0x03,0x00,0x80,0x47,0x30,0x0F,0x10,0x67,0x00,0x07,0x40,0x80,0x7F,0x00
  29. };
  30. char code shi[]={
  31. /*-- 文字: 試 --*/
  32. /*-- 宋體12; 此字體下對應(yīng)的點(diǎn)陣為:寬x高=16x16 --*/
  33. 0x40,0x42,0xDC,0x08,0x00,0x90,0x90,0x90,0x90,0x90,0xFF,0x10,0x12,0x1C,0x10,0x00,
  34. 0x00,0x00,0x7F,0x20,0x10,0x20,0x20,0x1F,0x10,0x10,0x01,0x06,0x18,0x20,0x78,0x00
  35. };
  36. char code kai[]={
  37. /*-- 文字: 開 --*/
  38. /*-- 宋體12; 此字體下對應(yīng)的點(diǎn)陣為:寬x高=16x16 --*/
  39. 0x40,0x42,0x42,0x42,0x42,0xFE,0x42,0x42,0x42,0x42,0xFE,0x42,0x42,0x42,0x42,0x00,
  40. 0x00,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x00,0x7F,0x00,0x00,0x00,0x00,0x00
  41. };
  42. char code shi3[]={
  43. /*-- 文字: 始 --*/
  44. /*-- 宋體12; 此字體下對應(yīng)的點(diǎn)陣為:寬x高=16x16 --*/
  45. 0x10,0x90,0x70,0x1F,0x12,0xF0,0x00,0x20,0x70,0x28,0x27,0x22,0x28,0x70,0x20,0x00,
  46. 0x40,0x21,0x12,0x0C,0x06,0x09,0x30,0x00,0x7F,0x21,0x21,0x21,0x21,0x7F,0x00,0x00
  47. };
  48. char code wan[]={
  49. /*-- 文字: 完 --*/
  50. /*-- 宋體12; 此字體下對應(yīng)的點(diǎn)陣為:寬x高=16x16 --*/
  51. 0x00,0x90,0x8C,0xA4,0xA4,0xA4,0xA5,0xA6,0xA4,0xA4,0xA4,0xA4,0x94,0x8C,0x04,0x00,
  52. 0x00,0x80,0x40,0x20,0x18,0x07,0x00,0x00,0x00,0x3F,0x40,0x40,0x40,0x70,0x00,0x00
  53. };
  54. char code bi[]={
  55. /*-- 文字: 畢 --*/
  56. /*-- 宋體12; 此字體下對應(yīng)的點(diǎn)陣為:寬x高=16x16 --*/
  57. 0x00,0x00,0xFF,0x88,0x48,0x28,0x08,0x80,0x7F,0x88,0x88,0x88,0x84,0x84,0xE0,0x00,
  58. 0x04,0x04,0x04,0x04,0x04,0x04,0x04,0xFF,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00
  59. };
  60. unsigned char code FirstPage[]={
  61. /*-- 調(diào)入了一幅圖像:C:\Documents and Settings\freelover\桌面\未標(biāo)題-1.bmp --*/
  62. /*-- 寬度x高度=128x64 --*/
  63. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x28,0x48,0x88,0x08,0x88,0x78,0x08,0x80,0x60,
  64. 0x3E,0xA0,0x20,0x20,0xA0,0x60,0x20,0x00,0x00,0x40,0x42,0x44,0xCC,0x00,0x00,0xF8,
  65. 0x08,0x04,0x04,0xF8,0x08,0x08,0x08,0xFC,0x08,0x00,0x00,0x00,0x80,0x40,0xF0,0x0E,
  66. 0x08,0xC8,0x48,0x48,0x48,0xFE,0x48,0x48,0x48,0xCC,0x08,0x00,0x00,0x00,0x00,0xFC,
  67. 0x44,0x44,0x44,0x44,0x44,0xFC,0x44,0x44,0x44,0x44,0xFE,0x04,0x00,0x00,0x80,0x40,
  68. 0x20,0x10,0x10,0x10,0x20,0x70,0x00,0x10,0xF0,0x10,0x10,0x10,0x10,0xE0,0x00,0x00,
  69. 0x10,0xF0,0x10,0x10,0x10,0x10,0xE0,0x00,0x00,0x00,0xF0,0x10,0x10,0x10,0x10,0x10,
  70. 0x10,0x00,0x00,0x00,0x20,0x20,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  71. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x20,0x19,0x06,0x05,0x08,0xB0,0x40,0x20,
  72. 0x18,0x07,0x18,0x20,0x40,0x80,0x80,0x00,0x00,0x80,0x40,0x20,0x1F,0x20,0x40,0x8F,
  73. 0x84,0x84,0x82,0xFF,0x80,0x88,0x90,0x8F,0x80,0x00,0x00,0x01,0x00,0x00,0xFF,0x00,
  74. 0x00,0x07,0x8C,0x54,0x24,0x5F,0x84,0x84,0x04,0x07,0x00,0x00,0x00,0x00,0xC0,0x3F,
  75. 0x04,0x04,0x04,0x04,0x04,0xFF,0x04,0x04,0x84,0x04,0xFF,0x00,0x00,0x00,0x1F,0x60,
  76. 0x80,0x80,0x80,0x80,0x40,0x30,0x00,0x80,0xFF,0x82,0x02,0x0E,0x32,0xC1,0x80,0x00,
  77. 0x80,0xFF,0x82,0x82,0x82,0x83,0x44,0x38,0x00,0x00,0x73,0x82,0x81,0x81,0x81,0x42,
  78. 0x3C,0x00,0x00,0x00,0x80,0x80,0xFF,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  79. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x10,0x91,0x51,0x30,0x10,0x10,
  80. 0x90,0x50,0x10,0x10,0x00,0x01,0x10,0x10,0xF0,0x90,0x90,0x90,0x90,0x10,0xE0,0x00,
  81. 0x00,0xF0,0x00,0x00,0x00,0xC0,0x50,0x50,0x60,0x40,0xC0,0x40,0x60,0x50,0x51,0xC0,
  82. 0x01,0x01,0x00,0x00,0xE0,0x00,0x00,0x00,0x01,0xF1,0x01,0x00,0x00,0x01,0x00,0x00,
  83. 0x80,0x80,0xF0,0x80,0x80,0x01,0xE0,0x20,0x20,0xE1,0x00,0x00,0x00,0x00,0xE0,0x20,
  84. 0x20,0xA0,0x20,0x20,0x30,0xA0,0x20,0x20,0x20,0x20,0xE0,0x00,0xD0,0x10,0x10,0xF0,
  85. 0x00,0x00,0x80,0x40,0x30,0x40,0x80,0x00,0x00,0x00,0x80,0x80,0xF0,0x80,0x80,0xE0,
  86. 0x20,0x20,0x20,0x10,0x10,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  87. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x89,0x49,0x2D,0x8D,0x0B,0xF9,0x09,
  88. 0x08,0x2A,0x4C,0x98,0x00,0x00,0x04,0x03,0x84,0x48,0x30,0x0C,0x03,0x00,0x3F,0x00,
  89. 0x00,0xFF,0x00,0x00,0x40,0x5F,0x52,0x52,0x52,0x52,0xFF,0x52,0x52,0x52,0x52,0x5F,
  90. 0x40,0x00,0x00,0x80,0x7F,0x09,0x09,0x09,0x09,0x09,0x09,0xF9,0x01,0x01,0x00,0x00,
  91. 0x18,0x06,0xFF,0x04,0x08,0x80,0x7F,0x00,0x00,0xFF,0x00,0x00,0xC0,0x00,0x10,0x10,
  92. 0x12,0x94,0x99,0x52,0x30,0x1F,0x30,0x50,0x90,0x10,0x10,0x00,0x47,0x44,0x24,0x27,
  93. 0xFE,0x09,0x72,0x0A,0x72,0x82,0x60,0x1B,0x01,0x00,0x18,0x06,0xFF,0x04,0x88,0x7F,
  94. 0x05,0x89,0x51,0x71,0x8D,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  95. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x08,0x08,0xF9,0x08,0x08,
  96. 0x08,0xF8,0x08,0x08,0x00,0x00,0x01,0x01,0x30,0x28,0x20,0xE0,0x3C,0x20,0x20,0x35,
  97. 0x29,0x20,0x20,0x00,0x00,0x40,0x40,0x50,0x50,0x50,0xFD,0xD0,0x50,0x70,0x50,0x48,
  98. 0x40,0x00,0x01,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x81,0x80,0x80,0x80,0x00,
  99. 0x80,0x80,0x81,0x01,0x81,0x80,0x00,0x00,0x00,0x80,0x81,0x81,0x00,0x00,0x01,0x01,
  100. 0x81,0x80,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x81,0x81,0x80,0x10,0xF0,0x81,0x81,
  101. 0x80,0x01,0x01,0x01,0x01,0x81,0x81,0x81,0x01,0x00,0x80,0x80,0x81,0x01,0x80,0x81,
  102. 0x81,0x00,0x00,0x80,0x80,0x81,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  103. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x21,0x11,0x0D,0x07,0x01,0x01,
  104. 0x01,0x3F,0x01,0x01,0x01,0x00,0x00,0x08,0x0C,0x26,0x23,0x30,0x17,0x1D,0x19,0x17,
  105. 0x31,0x20,0x20,0x00,0x00,0x04,0x04,0x02,0x3E,0x29,0x29,0x2A,0x2A,0x2A,0x3E,0x00,
  106. 0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x0F,0x10,0x10,0x10,0x09,0x00,
  107. 0x10,0x10,0x1F,0x11,0x10,0x00,0x00,0x00,0x09,0x14,0x12,0x12,0x1F,0x10,0x00,0x19,
  108. 0x12,0x12,0x14,0x09,0x00,0x40,0x41,0x66,0x18,0x06,0x01,0x00,0x00,0x1F,0x10,0x10,
  109. 0x10,0x0F,0x00,0x00,0x0F,0x10,0x10,0x10,0x0F,0x00,0x40,0x41,0x66,0x18,0x06,0x01,
  110. 0x00,0x00,0x0F,0x12,0x12,0x12,0x0B,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  111. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  112. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  113. 0x00,0x00,0x00,0x00,0x00,0x02,0x0E,0xF2,0x00,0xF2,0x0E,0x02,0x02,0xFE,0x22,0x22,
  114. 0x72,0x06,0x00,0x02,0xFE,0x12,0x32,0xD2,0x0C,0x00,0x00,0x00,0x18,0x18,0x00,0x00,
  115. 0x00,0x00,0x04,0x04,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,
  116. 0x04,0x02,0x02,0x04,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  117. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  118. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  119. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  120. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  121. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x00,0x00,0x00,0x02,0x03,0x02,0x02,
  122. 0x02,0x03,0x00,0x02,0x03,0x02,0x00,0x00,0x03,0x02,0x00,0x00,0x03,0x03,0x00,0x00,
  123. 0x00,0x00,0x02,0x02,0x03,0x02,0x02,0x00,0x00,0x03,0x03,0x00,0x00,0x00,0x00,0x00,
  124. 0x01,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  125. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  126. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  127. };
  128. /*------------------延時(shí)子程序-----------------------------*/
  129. void delay(unsigned int t)
  130. {
  131. unsigned int i,j;
  132. for(i=0;i<t;i++)
  133. for(j=0;j<10;j++)
  134. ;
  135. }
  136. /*------------------寫命令到LCD------------------------------*/
  137. void write_com(unsigned char cmdcode)
  138. {
  139. Di=0;
  140. RW=0;
  141. Lcd_Bus=cmdcode;
  142. delay(0);
  143. Enable=1;
  144. delay(0);
  145. Enable=0;
  146. }
  147. /*-------------------寫數(shù)據(jù)到LCD----------------------------*/
  148. void write_data(unsigned char Dispdata)
  149. {
  150. Di=1;
  151. RW=0;
  152. Lcd_Bus=Dispdata;
  153. delay(0);
  154. Enable=1;
  155. delay(0);
  156. Enable=0;
  157. }
  158. /*------------------顯示邊框-------------------------------*/
  159. void frame()
  160. {
  161. unsigned char i;
  162. Mcs=1;
  163. Scs=1;
  164. write_com(Page_Add+0);
  165. write_com(Col_Add+0);
  166. for(i=0;i<64;i++) write_data(0x01);
  167. write_com(Page_Add+7);
  168. write_com(Col_Add+0);
  169. for(i=0;i<64;i++) write_data(0x80);
  170. for(i=0;i<8;i++)
  171. {
  172. Mcs=0;
  173. Scs=1;
  174. write_com(Page_Add+i);
  175. write_com(Col_Add+63);
  176. write_data(0xff);
  177. Mcs=1;
  178. Scs=0;
  179. write_com(Page_Add+i);
  180. write_com(Col_Add+0);
  181. write_data(0xff);
  182. }
  183. }
  184. /*------------------清除內(nèi)存---------------*/
  185. void Clr_Scr()
  186. {
  187. unsigned char j,k;
  188. Mcs=1;Scs=1;
  189. write_com(Page_Add+0);
  190. write_com(Col_Add+0);
  191. for(k=0;k<8;k++){
  192. write_com(Page_Add+k);
  193. for(j=0;j<64;j++)write_data(0x00);
  194. }
  195. }
  196. /*------------------顯示12864圖片---------------------------*/
  197. void Disp_Img(unsigned char code *img)
  198. {
  199. unsigned char j,k;
  200. for(k=0;k<8;k++){
  201. Mcs=1;Scs=0;delay(10);
  202. write_com(Page_Add+k);
  203. write_com(Col_Add+0);
  204. for(j=0;j<64;j++) write_data(img[k*128+j]);
  205. Mcs=0;Scs=1; delay(10);
  206. write_com(Page_Add+k);
  207. write_com(Col_Add+0);
  208. for(j=64;j<128;j++) write_data(img[k*128+j]);
  209. }
  210. }
  211. /*------------------顯示橫---------------------------*/
  212. void Disp_H_Line()
  213. {
  214. unsigned char i,j;
  215. Mcs=1;
  216. Scs=1;
  217. write_com(Disp_On);
  218. write_com(Page_Add);
  219. write_com(Start_Line);
  220. write_com(Col_Add);
  221. for(j=0;j<8;j++)
  222. {
  223. write_com(Page_Add+j);
  224. write_com(Col_Add+0);
  225. // write_com(Start_Line+0);
  226. for(i=0;i<64;i++)write_data(0x55);
  227. }
  228. }
  229. /*------------------顯示列-----------------------------*/
  230. void Disp_V_Line()
  231. {
  232. unsigned char i,j;
  233. write_com(Disp_On);
  234. write_com(Page_Add);
  235. write_com(Start_Line);
  236. write_com(Col_Add);
  237. for(j=0;j<8;j++)
  238. {
  239. write_com(Page_Add+j);
  240. write_com(Col_Add+0);
  241. write_com(Start_Line+0);
  242. for(i=0;i<32;i++)
  243. {
  244. write_data(0x00);
  245. write_data(0xff);
  246. }
  247. }
  248. }
  249. /*---------------------指定位置顯示漢字16*16-----------------------*/
  250. void hz_disp16(unsigned char pag,unsigned char col, unsigned char code *hzk)
  251. {
  252. unsigned char j=0,i=0;
  253. for(j=0;j<2;j++){
  254. write_com(Page_Add+pag+j);
  255. write_com(Col_Add+col);
  256. for(i=0;i<16;i++) write_data(hzk[16*j+i]);
  257. }
  258. }
  259. /*------------------初始化LCD屏--------------------------*/
  260. void init_lcd()
  261. {
  262. Lcd_Rst=0;
  263. delay(100);
  264. Lcd_Rst=1;
  265. delay(100);
  266. Mcs=1;
  267. Scs=1;
  268. delay(100);
  269. write_com(Disp_Off);
  270. write_com(Page_Add+0);
  271. write_com(Start_Line+0);
  272. write_com(Col_Add+0);
  273. write_com(Disp_On);
  274. }
  275. /*------------------------------信息顯示------------------------*/
  276. void Msg(int flg)
  277. {
  278. Clr_Scr();
  279. frame();
  280. if(flg==0){ //顯示“測試開始”
  281. Mcs=1;Scs=0;
  282. hz_disp16(3,32,ce);
  283. delay(2000);
  284. hz_disp16(3,48,shi);
  285. delay(2000);
  286. Mcs=0;Scs=1;
  287. hz_disp16(3,0,kai);
  288. delay(2000);
  289. hz_disp16(3,16,shi3);
  290. delay(2000);
  291. }
  292. else if(flg==1){ //顯示“測試完畢”
  293. Mcs=1;Scs=0;
  294. hz_disp16(3,32,ce);
  295. hz_disp16(3,48,shi);
  296. Mcs=0;Scs=1;
  297. hz_disp16(3,0,wan);
  298. hz_disp16(3,16,bi);
  299. }
  300. }
  301. /*--------------------主程序---------------------------------*/
  302. main()
  303. {
  304. unsigned char i=0;
  305. while(1){
  306. init_lcd();
  307. Disp_Img(FirstPage);
  308. delay(30000);
  309. Msg(0);
  310. delay(10000);
  311. Disp_H_Line();
  312. delay(10000);
  313. Disp_V_Line();
  314. delay(10000);
  315. Msg(1);
  316. delay(10000);
  317. }
  318. }
相關(guān)帖子
