查看: 3851|回復(fù): 2
51單片機(jī)的紅外發(fā)射程序
ID:73526 發(fā)表于 2015-2-11 15:25 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
  1. #include<reg52.h>
  2. static bit OP;
  3. #define uint unsigned int
  5. uchar qishiok,count,key,flag,temp1;
  6. uchar xinhaook,ding,qishiflag,temp2;
  7. uchar temp;endcount,temp3,temp4;
  8. uchar kaiok;
  9. int c=0,d=0,e=0;
  10. sbit key1=P2^7;
  11. sbit key2=P2^6;
  12. sbit key3=P2^5;
  13. uchar shu;
  14. sbit P3_5=P3^5;
  15. void init()
  16. {
  17.     TMOD=0x02;
  18.     TH0=0xe6;
  19.     TL0=0xe6;
  20.     EA=1;
  21.     ET0=1;
  22.     TR0=1;
  23.     flag=0;
  24.     qishiok=0;
  25. }
  26. void time0() interrupt 1
  27. {
  28.         count++;
  29.      if(flag)
  30.       {P3_5=~P3_5;}
  31.      else
  32.       {P3_5=1;}
  33. }
  34. void qishi()
  35. {
  36.         int a;
  37.               count=0;
  38.         flag=1;
  39.               for(a=0;a<2;a++)
  40.               {
  41.                      endcount=173;
  42.                do{}
  43.                  while(count<endcount);
  44.                        count=0;
  45.               }
  46.         flag=0;
  47.         count=0;
  48.               endcount=173;
  49.         do{}
  50.           while(count<endcount);
  51.         count=0;
  52.         qishiok=1;
  53. }
  54. void jieshu()
  55. {
  56.            int b;
  57.               shu=0x02;
  58.            count=0;
  59.            for(b=0;b<4;b++)
  60.         {
  61.           flag=1;
  62.           do{}while(count<35);
  63.           if(shu-(shu/2)*2)
  64.               {
  65.                   ding=45;
  66.               }
  67.               else
  68.               {
  69.                   ding=15;
  70.               }
  71.               flag=0;
  72.               count=0;
  73.           do{}while(ding>count);
  74.               count=0;
  75.           shu=shu>>1;
  76.         }
  77. }
  78. void xinhao(uchar temp)
  79. {
  80.     int i;
  81.     shu=temp;
  82.     count=0;
  83.     for(i=0;i<8;i++)
  84.         {
  85.               flag=1;
  86.               do{}while(count<35);
  87.               if(shu-(shu/2)*2)
  88.               {
  89.                   ding=45;
  90.               }
  91.               else
  92.               {
  93.                   ding=15;
  94.               }
  95.               flag=0;
  96.               count=0;
  97.           do{}while(ding>count);
  98.               count=0;
  99.           shu=shu>>1;
  100.         }
  101.           xinhaook=1;
  102. }
  103. void delay()
  104. {
  105.   int i,j;
  106.   for(i=0;i<400;i++)
  107.   {
  108.     for(j=0;j<100;j++)
  109.     {
  110.     }
  111.   }
  112. }
  113. void fashe(temp1,temp2,temp3,temp4)
  114. {
  115.         init();
  116.         qishi();
  117.               xinhao(temp1);
  118.         xinhao(temp2);
  119.               xinhao(temp3);
  120.               xinhao(temp4);
  121.               jieshu();
  122.            delay();
  123. }
  124. void kaiguan()
  125. {
  126.        if(c)
  127.               {
  128.                      fashe(0x09,0x00,0x00,0x50);//開
  129.                      kaiok=1;
  130.               }
  131.        else
  132.               {
  133.                      fashe(0x01,0x00,0x00,0x50);//關(guān)
  134.                      kaiok=0;
  135.               }
  136. }
  137. void saofeng()
  138. {
  139.               switch(e)
  140.               {
  141.                      case 0:
  142.                             {
  143.                                    if(d)
  144.                                           fashe(0x49,0x00,0x00,0x50);//風(fēng)速關(guān)時(shí)掃風(fēng)開
  145.                                    else
  146.                                           fashe(0x09,0x00,0x00,0x50);//風(fēng)速關(guān)時(shí)掃風(fēng)關(guān)
  147.                             };break;
  148.                      case 1:
  149.                             {
  150.                                    if(d)
  151.                                           fashe(0x59,0x00,0x00,0x50);//風(fēng)速一時(shí)掃風(fēng)開
  152.                                    else
  153.                                           fashe(0x19,0x00,0x00,0x50);//風(fēng)速一時(shí)掃風(fēng)關(guān)
  154.                             };break;
  155.                      case 2:
  156.                             {
  157.                                    if(d)
  158.                                           fashe(0x69,0x00,0x00,0x50);//風(fēng)速二時(shí)掃風(fēng)開
  159.                                    else
  160.                                           fashe(0x29,0x00,0x00,0x50);//風(fēng)速二時(shí)掃風(fēng)關(guān)
  161.                             };break;
  162.                      case 3:
  163.                             {
  164.                                    if(d)
  165.                                           fashe(0x79,0x00,0x00,0x50);//風(fēng)速三時(shí)掃風(fēng)開
  166.                                  else
  167.                                           fashe(0x39,0x00,0x00,0x50);//風(fēng)速三時(shí)掃風(fēng)關(guān)
  168.                             }
  169.               }
  170. }
  171. void fengsu()
  172. {
  173.        if(d)//掃風(fēng)開時(shí)
  174.        {
  175.               switch(e)
  176.                      {
  177.                      case 0:
  178.                             fashe(0x49,0x00,0x00,0x50);break;//風(fēng)速關(guān)
  179.                      case 1:
  180.                             fashe(0x59,0x00,0x00,0x50);break;//風(fēng)速一
  181.                      case 2:
  182.                             fashe(0x69,0x00,0x00,0x50);break;//風(fēng)速二
  183.                      case 3:
  184.                             fashe(0x79,0x00,0x00,0x50);break;//風(fēng)速三
  185.                      }
  186.        }
  187.        else//掃風(fēng)關(guān)時(shí)
  188.        {
  189.               switch(e)
  190.                      {
  191.                      case 0:
  192.                             fashe(0x09,0x00,0x00,0x50);break;//風(fēng)速關(guān)
  193.                      case 1:
  194.                             fashe(0x19,0x00,0x00,0x50);break;//風(fēng)速一
  195.                      case 2:
  196.                             fashe(0x29,0x00,0x00,0x50);break;//風(fēng)速二
  197.                      case 3:
  198.                             fashe(0x39,0x00,0x00,0x50);break;//風(fēng)速三
  199.                      }
  200.        }
  201. }
  202. void main()
  203. {
  204.     while(1)
  205.    {
  206.               if(key1==0)
  207.               {
  208.                      while(key1==0);
  209.                      kaiguan();//開關(guān)
  210.                      c++;
  211.                      if(c>1)
  212.                      c=0;
  213.               }
  214.               else if(key2==0)
  215.               {
  216.                      while(key2==0);
  217.                      if(kaiok)
  218.                      {
  219.                             saofeng();
  220.                             d++;
  221.                             if(d>1)
  222.                             d=0;
  223.                      }
  224.               }
  225.               else if(key3==0)
  226.               {
  227.                      while(key3==0)
  228.                      if(kaiok)
  229.                      {
  230.                             fengsu();
  231.                             e++;
  232.                             if(e>3)
  233.                             e=0;
  234.                      }
  235.               }
  236.    }
  237. }
相關(guān)帖子
ID:73187 發(fā)表于 2015-2-12 10:12 | 只看該作者
不知道樓主這段代碼 什么功能
ID:60435 發(fā)表于 2015-2-12 20:54 來(lái)自觸屏版 | 只看該作者
樓主能把原理圖共享一下嗎
