* @file: system_LPC11xx.c
* @purpose: CMSIS Cortex-M0 Device Peripheral Access Layer Source File
* for the NXP LPC11xx Device Series
* @version: V1.0
* @date: 26. Nov. 2008
* Copyright (C) 2008 ARM Limited. All rights reserved.
* ARM Limited (ARM) is supplying this software for use with Cortex-M3
* processor based microcontrollers. This file can be freely distributed
* within development tools that are supporting such ARM based processors.
* THIS SOFTWARE IS PROVIDED "AS IS". NO WARRANTIES, WHETHER EXPRESS, IMPLIED
* OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED WARRANTIES OF
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE.
* ARM SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR
* CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
#include <stdint.h>
#include "LPC11xx.h"
//-------- <<< Use Configuration Wizard in Context Menu >>> ------------------
/*--------------------- Clock Configuration ----------------------------------
// <e> Clock Configuration
// <h> System Controls and Status Register (SCS)
// <o1.4> OSCRANGE: Main Oscillator Range Select
// <0=> 1 MHz to 20 MHz
// <1=> 15 MHz to 24 MHz
// <e1.5> OSCEN: Main Oscillator Enable
// </e>
// </h>
// <h> Clock Source Select Register (CLKSRCSEL)
// <o2.0..1> CLKSRC: PLL Clock Source Selection
// <0=> Internal RC oscillator
// <1=> Main oscillator
// <2=> RTC oscillator
// </h>
// <e3> PLL0 Configuration (Main PLL)
// <h> PLL0 Configuration Register (PLL0CFG)
// <i> F_cco0 = (2 * M * F_in) / N
// <i> F_in must be in the range of 32 kHz to 50 MHz
// <i> F_cco0 must be in the range of 275 MHz to 550 MHz
// <o4.0..14> MSEL: PLL Multiplier Selection
// <6-32768><#-1>
// <i> M Value
// <o4.16..23> NSEL: PLL Divider Selection
// <1-256><#-1>
// <i> N Value
// </h>
// </e>
// <h> CPU Clock Configuration Register (CCLKCFG)
// <o7.0..7> CCLKSEL: Divide Value for CPU Clock from PLL0
// <0-255>
// <i> Divide is CCLKSEL + 1. Only 0 and odd values are valid.
// </h>
// </e>
#define CLOCK_SETUP 0
#define MAIN_PLL_SETUP 0
#define MAIN_CLKSRCSEL_Val 0x00000001
#define MAIN_PLL_M_Val 0x00000003
#define MAIN_PLL_P_Val 0x00000001
#define SYS_AHB_DIV_Val 1 /* 1 through 255, typical is 1 or 2 or 4 */
//-------- <<< end of configuration section >>> ------------------------------
DEFINES
Define clocks
#define XTAL (12000000UL) /* Oscillator frequency */
#define OSC_CLK ( XTAL) /* Main oscillator frequency */
#define IRC_OSC (12000000UL) /* Internal RC oscillator frequency */
#define WDT_OSC ( 250000UL) /* WDT oscillator frequency */
Clock Variable definitions
uint32_t ClockSource = IRC_OSC;
uint32_t SystemFrequency = IRC_OSC; /*!< System Clock Frequency (Core Clock) */
uint32_t SystemAHBFrequency = IRC_OSC;
* Misc. clock generation modules
* @param none
* @return none
* @brief Setup the microcontroller system.
* Initialize the System and update the SystemFrequency variable.
void Main_PLL_Setup ( void )
uint32_t regVal;
ClockSource = OSC_CLK;
LPC_SYSCON->SYSPLLCLKSEL = MAIN_CLKSRCSEL_Val; /* Select system OSC--PLL時鐘源選中系統(tǒng)振蕩器 */
LPC_SYSCON->SYSPLLCLKUEN = 0x01; /* Update clock source */
LPC_SYSCON->SYSPLLCLKUEN = 0x00; /* toggle Update register once */
while ( !(LPC_SYSCON->SYSPLLCLKUEN & 0x01) ); /* Wait until updated 等待系統(tǒng)振蕩器鎖定*/
regVal = LPC_SYSCON->SYSPLLCTRL;
regVal &= ~0x1FF;
LPC_SYSCON->SYSPLLCTRL = (regVal | (MAIN_PLL_P_Val<<5) | MAIN_PLL_M_Val);/* P=1, M=4 */
/* Enable main system PLL, main system PLL bit 7 in PDRUNCFG. */
LPC_SYSCON->PDRUNCFG &= ~(0x1<<7); /* PDRUNCFG第七位寫0,即系統(tǒng)PLL上電 */
while ( !(LPC_SYSCON->SYSPLLSTAT & 0x01) ); /* Wait until it's locked */
LPC_SYSCON->MAINCLKSEL = 0x01; /* Select PLL clock output--選擇PLL輸出作為主時鐘 */
LPC_SYSCON->MAINCLKUEN = 0x01; /* Update MCLK clock source --允許更新主時鐘*/
LPC_SYSCON->MAINCLKUEN = 0x00; /* Toggle update register once */
while ( !(LPC_SYSCON->MAINCLKUEN & 0x01) ); /* Wait until updated 等待主時鐘鎖定*/
LPC_SYSCON->SYSAHBCLKDIV = SYS_AHB_DIV_Val; /* SYS AHB clock, typical is 1 or 2 or 4 --SYSAHBCLKDIV的值為1,即不分頻 AHB時鐘為12*4=48MHz*/
#if MAIN_PLL_SETUP
SystemFrequency = ClockSource * (MAIN_PLL_M_Val+1); /*系統(tǒng)時鐘=時鐘源*4MHz*/
#else
SystemFrequency = ClockSource;
#endif
SystemAHBFrequency = (uint32_t)(SystemFrequency/SYS_AHB_DIV_Val); /*AHB時鐘=系統(tǒng)時鐘/AHB分頻值*/
return;
* Initialize the system
* @param none
* @return none
void SystemInit (void) /* 復(fù)位之后,LPC111x會根據(jù)內(nèi)部12MHz RC振蕩器的頻率運(yùn)行,直到頻率被軟件切換 */
//uint32_t i;
#ifdef __DEBUG_RAM
LPC_SYSCON->SYSMEMREMAP = 0x1; /* remap to internal RAM */
#else
#ifdef __DEBUG_FLASH
LPC_SYSCON->SYSMEMREMAP = 0x2; /* remap to internal flash */
#endif
#endif
#if (CLOCK_SETUP) /* Clock Setup */
/* bit 0 default is crystal bypass,
bit1 0=0~20Mhz crystal input, 1=15~50Mhz crystal input. */
LPC_SYSCON->SYSOSCCTRL = 0x01;
/* main system OSC run is cleared, bit 5 in PDRUNCFG register */
LPC_SYSCON->PDRUNCFG &= ~(0x1<<5); /* PDRUNCFG的第五位寫0,即系統(tǒng)振蕩器上電 */
/* Wait 200us for OSC to be stablized, no status indication, dummy wait. */
for ( i = 0; i < 0x100; i++ );
#if (MAIN_PLL_SETUP)
Main_PLL_Setup();
#endif
#endif /* endif CLOCK_SETUP */
/* System clock to the IOCON needs to be enabled or most of the I/O related peripherals won't work. */
LPC_SYSCON->SYSAHBCLKCTRL |= (1<<16); //使能IO配置模塊的時鐘
LPC_SYSCON->SYSAHBCLKCTRL |= (1<<8); //開啟定時器Timer16_1時鐘
LPC_SYSCON->SYSAHBCLKCTRL |= (1<<5); //開啟I2C模塊時鐘
SystemAHBFrequency = (uint32_t)(SystemFrequency/SYS_AHB_DIV_Val); /*AHB時鐘=系統(tǒng)時鐘/AHB分頻值 = 3MHz,AHB時鐘對內(nèi)核及存儲器和外設(shè)分配時鐘*/
return;
