查看: 6421|回復(fù): 0
lcd1602顯示程序源碼-51單片機(jī)
ID:75263 發(fā)表于 2015-3-24 23:47 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
        #include<reg51.h>
/*************LCD COMMAND*************/
#define Twoline_8bit                 56       //0x38
#define CLEAR                        1       //0000 0001  CURSOR  指針
#define CURSOR_HOME                  2        //0000 0010
#define CURSOR_LEFT                  4       //0000 0100
#define CURSOR_RIGHT                 6       //0000 0110
#define CURSOR_OFF                   12            //0000 1100
#define CURSOR_ON                    14       //0000 1110    BLINK  閃爍
#define CURSOR_BLINK                 15        //0000 1111
#define GOTO_LINE_2                  192     //    GOTO  轉(zhuǎn)到
#define GOTO_LINE_1                  126
/*************LCD CONTROL LINE***********/
#define ENABLE                       1
#define DISABLE                      0
#define READ                         1
#define WRITE                        0
#define COMMAND                      0                   //  COMMAND  指令
#define DATA                         1
#define rs                           P2_6
#define rw                           P2_5
#define enable                       P2_4
sbit              P2_6=P2^6;
sbit              P2_5=P2^5;
sbit              P2_4=P2^4;
void delay100us();
void write_lcd_command(unsigned);       //   輸入指令寄存器
void write_lcd_data(unsigned);        //   輸入數(shù)據(jù)寄存器
void init_lcd(void);          //   初始化LCD
void clear_lcd(void);          //    LCD 清屏
void diplay_lcd_string(char *P);        //    顯示字符串函數(shù)
void gotoxy(unsigned,unsigned);            //    設(shè)置光標(biāo)到第X行第Y列
void display_lcd_number(char);            //    顯示單個(gè)數(shù)字
char code int2charlcd[]="0123456789";
void delay100us()            //延時(shí)函數(shù)
{  unsigned char i,j;
  for(i=0;i<=10;i++)
     for(j=0;j<=10;j++)
void write_lcd_command(unsigned command)       //寫(xiě)入指令寄存器函數(shù)
  rw=WRITE;                //rw為寫(xiě)狀態(tài)
  rs=COMMAND;                //rs指向指令寄存器
  enable=ENABLE;               //使能
  P1=command;               //P1口送指令碼
  delay100us();
  enable= DISABLE;
  rw=1;
void write_lcd_data(unsigned lcddata)
  rs=DATA;                //rs指向數(shù)據(jù)寄存器
  enable=ENABLE;               //使能
  P1=lcddata;
  delay100us();
  enable=DISABLE;
  rw=1;
void init_lcd(void)
  write_lcd_command(Twoline_8bit);                        // 0b00111000
  write_lcd_command(CURSOR_OFF);                             // 0b00001100
  write_lcd_command(CURSOR_RIGHT);                     // 0b00000110
  write_lcd_command(CLEAR);
  write_lcd_command(CURSOR_HOME);
void display_lcd_string(char *P)       //顯示字符串函數(shù)
  while(*P)            //例如display_LCD_string(“Hello")
    write_lcd_data(*P);
P++;
void display_lcd_number(char number)      //顯示數(shù)值變量函數(shù)
  unsigned char x,y;          //例如isplay_LCD_number(變量)
  x=number/10;
  y=number-10*x;           //變量在函數(shù)里進(jìn)行處理在送數(shù)據(jù)寄存器顯示
  write_lcd_data(int2charlcd[x]);
  write_lcd_data(int2charlcd[y]);
void gotoxy(unsigned x,unsigned y)         //光標(biāo)跳轉(zhuǎn)函數(shù)X表示第幾行,Y表示第幾列。
  if(x==1)
    write_lcd_command(GOTO_LINE_1+y);
    write_lcd_command(GOTO_LINE_2+y);
void main(void)
  init_lcd();
  clear_lcd();
  display_lcd_string("jjjtangxiaojin");
  gotoxy(2,1);
  display_lcd_string("jjjjtiancai");
  while(1);
收藏收藏2 分享淘帖 頂 踩
相關(guān)帖子
