沒有人回答,我自己改進(jìn)了一下,效果不很理想。有時(shí)1602液晶顯示跑掉,通道號(hào)不變,繼電器反應(yīng)快了
這是STC12C5A60S2單片機(jī)的
#include"STC12C5A60S2.h" //頭文件在STC公司主頁上下載
#include"intrins.h"
unsigned char code LedChar[]={ 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f };
unsigned char LedBuff[ ]={ 0x3f, 0x3f, 0x3f, 0x3f , 0x3f };
unsigned int g, a = 0, n=0 ;
unsigned char d , m=0;
float AD_val = 0;
void AD_init();
void serial_init();
void delay(unsigned int b);
float AD_work(unsigned char channel);
unsigned int AD_get(unsigned char channel);
void display(unsigned int g );
unsigned char j, e=0 ;
float b;
unsigned int Led[]={ 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff };
TMOD = 0x01;
TH0 = 0xFC;
TL0 = 0x67;
TR0 = 1;
EA = 1;
ET0 = 1;
AD_init(); //A/D轉(zhuǎn)換初始化
serial_init(); //串口初始化
for(d =0;d <8;d++) //循環(huán)發(fā)送P1.0-P1.7的轉(zhuǎn)換數(shù)值
{ b=AD_work(d );
a=(unsigned int)b ;
Led[d] = a;
if(j==0) { SBUF = d; while(!TI); TI=0; j++;}
if(j==1) { SBUF = a; while(!TI); TI=0; j++;}
if(j==2) { e = a>>8; SBUF = e; while(!TI); TI=0; j=0; n++;}
if(n>=640) { n=0; m=0; }
switch(m=n/80)
case 0:
g= Led[0] ;
display( g ) ;
break;
case 1:
g= Led[1] ;
display( g ) ;
break;
case 2:
g= Led[2] ;
display( g ) ;
break;
case 3:
g= Led[3] ;
display( g ) ;
break;
case 4:
g= Led[4] ;
display( g ) ;
break;
case 5:
g= Led[5] ;
display( g ) ;
break;
case 6:
g= Led[6] ;
display( g );
break;
case 7:
g= Led[7] ;
display( g ) ;
break;
LedBuff[0] = LedChar[g%10];
LedBuff[1] = LedChar[g/10%10];
LedBuff[2] = LedChar[g/100%10];
LedBuff[3] = LedChar[g/1000%10];
LedBuff[4] = LedChar[m];
ADC_CONTR=0x88|channel; //開啟AD轉(zhuǎn)換1000 1000 即POWER SPEED1 SPEED0 ADC_FLAG ADC_START CHS2 CHS1 CHS0
_nop_(); _nop_(); _nop_(); _nop_();//要經(jīng)過4個(gè)CPU時(shí)鐘的延時(shí),其值才能夠保證被設(shè)置進(jìn)ADC_CONTR 寄存器
while(!(ADC_CONTR&0x10)); //等待轉(zhuǎn)換完成
ADC_CONTR&=0xe7; //關(guān)閉AD轉(zhuǎn)換,ADC_FLAG位由軟件清0
return(ADC_RES*4+ADC_RESL); //返回AD轉(zhuǎn)換完成的10位數(shù)據(jù)(16進(jìn)制)
float AD_val; //定義處理后的數(shù)值A(chǔ)D_val為浮點(diǎn)數(shù)
unsigned char i;
for(i=0;i<50;i++)
AD_val+=AD_get(channel); //轉(zhuǎn)換100次求平均值(提高精度)
AD_val/=50;
//AD_val=(AD_val*5)/1024; //AD的參考電壓是單片機(jī)上的5v,所以乘5即為實(shí)際電壓值
return AD_val;
void delay(unsigned int b) //延時(shí)約1ms
unsigned int i;
while (--b!=0)
for(i=600;i>0;i--); //1T單片機(jī)i=600,若是12T單片機(jī)i=125
void AD_init()
P1ASF=0xff; //P1口全部作為模擬功能AD使用
ADC_RES=0; //清零轉(zhuǎn)換結(jié)果寄存器高8位
ADC_RESL=0; //清零轉(zhuǎn)換結(jié)果寄存器低2位
ADC_CONTR=0x80;//開啟AD電源
delay(2); //等待1ms,讓AD電源穩(wěn)定
unsigned char j = 0 ;
void InterruptTimer0() interrupt 1
TH0 = 0xFC;
TL0 = 0x67;
P0 = 0xFF;
if(j == 0)
{P2=7; j++; P0=LedBuff[0];}
else if(j == 1)
{P2=6; j++; P0=LedBuff[1];}
else if(j == 2)
{P2=5; j++; P0=LedBuff[2];}
else if(j == 3)
{P2=4; j++; P0=LedBuff[3];}
else if(j == 4)
{P2=0; j=0; P0=LedBuff[4];}
void serial_init()
TMOD=0x20;
TH1=0xfd;
TL1=0xfd; //設(shè)置9600波特率
SCON=0x50; //串口方式1,允許接收
TR1=1;
void InterruptUART() interrupt 4 {}
