查看: 3496|回復(fù): 0
NRF無(wú)線傳輸實(shí)驗(yàn)
ID:75926 發(fā)表于 2015-4-10 17:21 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
  1. NRF的引腳有               IRQ:中斷引腳 接收到數(shù)據(jù)或者發(fā)射數(shù)據(jù)完成的時(shí)候會(huì)被拉低 可以設(shè)置成引發(fā)中斷
  2.                                        MOSI  :SPI總線的數(shù)據(jù)發(fā)射引腳
  3.                                     MISO :SPI 總線的數(shù)據(jù)接收引腳
  4.                                     CS:低電平有效 SPI的片選引腳
  5.                                     CE:NRF的發(fā)射或者接收選擇引腳
  6.                                     SCK:SPI總線的時(shí)鐘線
  7.     有硬件SPI功能的MCU 可以忽略這部分
  8.     typedef unsigned char uint8_t;
  9. uint8_t SPI_SR(uint8_t Data)
  10. {
  11.     uint8_t i,buff=0;
  12.     SCK_L;
  13.     for(i=0;i<8;i++)
  14.     {
  15.         if(Data&0x80)
  16.             MOSI_H;
  17.         else
  18.             MOSI_L;
  19.         SCK_H;
  20.         Data<<=1;
  21.         buff++;
  22.         if(MISO)
  23.             buff++;
  24.         SCK_L;
  25.     }
  26.     return Status;
  27. }
  28. uint8_t NRF_WriteReg(uint8_t reg,uint8_t data)
  29. {
  30.     uint8_t Status;
  31.     CS_L;
  32.     CE_L;
  33.     Status=SPI_SR(reg);
  34.     SPI_SR(Data);
  35.     CS_H;
  36.     return Status;
  37. }
  38. uint8_t NRF_ReadReg(uint8_t reg)
  39. {
  40.     uint8_t val;
  41.     CS_L;
  42.     CE_L;
  43.     SPI_SR(reg);
  44.     val=SPI_SR(0xff);
  45.     CS_H;
  46.     return val;
  47. }
  48. uint8_t NRF_WriteBuff(uint8_t reg,uint8_t *buff,uint8_t Byte)
  49. {
  50.     uint8_t i,Status;
  51.     CE_L;
  52.     CS_L;
  53.     Status=NRF_SR(reg);
  54.     for(i=0;i<Byte;i++)
  55.         SPI_SR(buff[i]);
  56.     CS_H;
  57.     return Status;
  58. }
  59. uint8_t NRF_ReadReg(uint8_t reg,uint8_t buff,uint8_t Byte)
  60. {
  61.     uint8_t i,Status;
  62.     CE_L;
  63.     CS_L;
  64.     Status=NRF_SR(reg);
  65.     for(i=0;i<Byte,i++)
  66.         buff[i]=SPI_SR(0xff);
  67.     CS_H;
  68.     return Status;
  69. }
  70. void NRF_SetMode(uint8_t flag)  //1:發(fā)射,0接收
  71. {
  72.     if(flag!=0)
  73.     {
  74.         NRF_CE_L;
  75.    NRF_WriteBuff(NRF_WRITE_REG+RX_ADDR_P0,RX_ADDRESS,RX_ADR_WIDTH);//寫RX節(jié)點(diǎn)地址      //寄存器地址               地址          地址寬度
  76.    NRF_WriteReg(NRF_WRITE_REG+EN_AA,0x01);    //使能通道0的自動(dòng)應(yīng)答
  77.    NRF_WriteReg(NRF_WRITE_REG+EN_RXADDR,0x01);//使能通道0的接收地址
  78.    NRF_WriteReg(NRF_WRITE_REG+RF_CH,CHANAL);      //設(shè)置RF通信頻率
  79.    NRF_WriteReg(NRF_WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH);//選擇通道0的有效數(shù)據(jù)寬度
  80.    NRF_WriteReg(NRF_WRITE_REG+RF_SETUP,0x0f); //設(shè)置TX發(fā)射參數(shù),0db增益,2Mbps,低噪聲增益開啟
  81.    NRF_WriteReg(NRF_WRITE_REG+CONFIG, 0x0f);  //配置基本工作模式的參數(shù);PWR_UP,EN_CRC,16BIT_CRC,接收模式
  82. /*CE拉高,進(jìn)入接收模式*/
  83.   NRF_CE_H;
  84.     }
  85.     else
  86.     {
  87.           NRF_CE_L;
  88.    NRF_WriteBuff(NRF_WRITE_REG+TX_ADDR,TX_ADDRESS,TX_ADR_WIDTH);    //寫TX節(jié)點(diǎn)地址
  89.    NRF_WriteBuff(NRF_WRITE_REG+RX_ADDR_P0,RX_ADDRESS,RX_ADR_WIDTH); //設(shè)置TX節(jié)點(diǎn)地址,主要為了使能ACK
  90.    NRF_WriteReg(NRF_WRITE_REG+EN_AA,0x01);     //使能通道0的自動(dòng)應(yīng)答
  91.    NRF_WriteReg(NRF_WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址
  92.    NRF_WriteReg(NRF_WRITE_REG+SETUP_RETR,0x1a);//設(shè)置自動(dòng)重發(fā)間隔時(shí)間:500us + 86us;最大自動(dòng)重發(fā)次數(shù):10次
  93.    NRF_WriteReg(NRF_WRITE_REG+RF_CH,CHANAL);       //設(shè)置RF通道為CHANAL
  94.    NRF_WriteReg(NRF_WRITE_REG+RF_SETUP,0x0f);  //設(shè)置TX發(fā)射參數(shù),0db增益,2Mbps,低噪聲增益開啟
  95.    NRF_WriteReg(NRF_WRITE_REG+CONFIG,0x0e);    //配置基本工作模式的參數(shù);PWR_UP,EN_CRC,16BIT_CRC,發(fā)射模式,開啟所有中斷
  96. /*CE拉高,進(jìn)入發(fā)送模式*/
  97.   NRF_CE_H;
  98.     Delay(0xffff); //CE要拉高一段時(shí)間才進(jìn)入發(fā)送模式
  99.     }
  100. }
  1. /**
  2.   * @brief   用于向NRF的發(fā)送緩沖區(qū)中寫入數(shù)據(jù)
  3.   * @param
  4.   *        @arg txBuf:存儲(chǔ)了將要發(fā)送的數(shù)據(jù)的數(shù)組,外部定義
  5.   * @retval  發(fā)送結(jié)果,成功返回TXDS,失敗返回MAXRT或ERROR
  6.   */
  7. uint8_t NRF_Tx_Data(uint8_t *txbuf)
  8. {
  9. uint8_t State;
  10. /*ce為低,進(jìn)入待機(jī)模式1*/
  11. NRF_CE_L;
  12. /*寫數(shù)據(jù)到TX BUF 最大 32個(gè)字節(jié)*/
  13.    NRF_WriteBuff(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);
  14.       /*CE為高,txbuf非空,發(fā)送數(shù)據(jù)包 */
  15.         NRF_CE_H;
  16.
  17. /*等待發(fā)送完成中斷 */
  18. while(NRF_IRQ!=0);
  19. /*讀取狀態(tài)寄存器的值 */
  20. State = NRF_ReadReg(STATUS);
  21. /*清除TX_DS或MAX_RT中斷標(biāo)志*/
  22. NRF_WriteReg(NRF_WRITE_REG+STATUS,State);
  23. NRF_WriteReg(FLUSH_TX,NOP);    //清除TX FIFO寄存器
  24. /*判斷中斷類型*/
  25. if(State&MAX_RT)                     //達(dá)到最大重發(fā)次數(shù)
  26. return MAX_RT;
  27. else if(State&TX_DS)                  //發(fā)送完成
  28. return TX_DS;
  29. else
  30. return ERROR;                 //其他原因發(fā)送失敗
  31. }
  32. /**
  33.   * @brief   用于從NRF的接收緩沖區(qū)中讀出數(shù)據(jù)
  34.   * @param
  35.   *        @arg rxBuf :用于接收該數(shù)據(jù)的數(shù)組,外部定義
  36.   * @retval
  37.   *        @arg 接收結(jié)果
  38.   */
  39. uint8_t NRF_Rx_Dat(uint8_t *rxbuf)
  40. {
  41. uint8_t State;
  42. NRF_CE_H;        //進(jìn)入接收狀態(tài)
  43. /*等待接收中斷*/
  44. while(NRF_IRQ!=0);
  45. NRF_CE_L;          //進(jìn)入待機(jī)狀態(tài)
  46. /*讀取status寄存器的值  */
  47. State=NRF_ReadReg(STATUS);
  48. /* 清除中斷標(biāo)志*/
  49. NRF_WriteReg(NRF_WRITE_REG+STATUS,State);
  50. /*判斷是否接收到數(shù)據(jù)*/
  51. if(State&RX_DR)                                 //接收到數(shù)據(jù)
  52. {
  53. NRF_ReadBuff(RD_RX_PLOAD,rxbuf,RX_PLOAD_WIDTH);//讀取數(shù)據(jù)
  54.     NRF_WriteReg(FLUSH_RX,NOP);          //清除RX FIFO寄存器
  55. return RX_DR;
  56. }
  57. else
  58. return ERROR;                    //沒(méi)收到任何數(shù)據(jù)
  59. }
  60. #define TX_ADR_WIDTH 5          //發(fā)射地址寬度
  61. #define TX_PLOAD_WIDTH  4   //發(fā)射數(shù)據(jù)通道有效數(shù)據(jù)寬度0~32Byte
  62. #define RX_ADR_WIDTH    5
  63. #define RX_PLOAD_WIDTH  4
  64. #define CHANAL 40        //頻道選擇
  65. // SPI(nRF24L01) commands ,        NRF的SPI命令宏定義,詳見NRF功能使用文檔
  66. #define NRF_READ_REG    0x00  // Define read command to register
  67. #define NRF_WRITE_REG   0x20  // Define write command to register
  68. #define RD_RX_PLOAD 0x61  // Define RX payload register address
  69. #define WR_TX_PLOAD 0xA0  // Define TX payload register address
  70. #define FLUSH_TX    0xE1  // Define flush TX register command
  71. #define FLUSH_RX    0xE2  // Define flush RX register command
  72. #define REUSE_TX_PL 0xE3  // Define reuse TX payload register command
  73. #define NOP         0xFF  // Define No Operation, might be used to read status register
  74. // SPI(nRF24L01) registers(addresses) ,NRF24L01 相關(guān)寄存器地址的宏定義
  75. #define CONFIG      0x00  // 'Config' register address
  76. #define EN_AA       0x01  // 'Enable Auto Acknowledgment' register address
  77. #define EN_RXADDR   0x02  // 'Enabled RX addresses' register address
  78. #define SETUP_AW    0x03  // 'Setup address width' register address
  79. #define SETUP_RETR  0x04  // 'Setup Auto. Retrans' register address
  80. #define RF_CH       0x05  // 'RF channel' register address
  81. #define RF_SETUP    0x06  // 'RF setup' register address
  82. #define STATUS      0x07  // 'Status' register address
  83. #define OBSERVE_TX  0x08  // 'Observe TX' register address
  84. #define CD          0x09  // 'Carrier Detect' register address
  85. #define RX_ADDR_P0  0x0A  // 'RX address pipe0' register address
  86. #define RX_ADDR_P1  0x0B  // 'RX address pipe1' register address
  87. #define RX_ADDR_P2  0x0C  // 'RX address pipe2' register address
  88. #define RX_ADDR_P3  0x0D  // 'RX address pipe3' register address
  89. #define RX_ADDR_P4  0x0E  // 'RX address pipe4' register address
  90. #define RX_ADDR_P5  0x0F  // 'RX address pipe5' register address
  91. #define TX_ADDR     0x10  // 'TX address' register address
  92. #define RX_PW_P0    0x11  // 'RX payload width, pipe0' register address
  93. #define RX_PW_P1    0x12  // 'RX payload width, pipe1' register address
  94. #define RX_PW_P2    0x13  // 'RX payload width, pipe2' register address
  95. #define RX_PW_P3    0x14  // 'RX payload width, pipe3' register address
  96. #define RX_PW_P4    0x15  // 'RX payload width, pipe4' register address
  97. #define RX_PW_P5    0x16  // 'RX payload width, pipe5' register address
  98. #define FIFO_STATUS 0x17  // 'FIFO Status Register' register address
  99. #define MAX_RT      0x10 //達(dá)到最大重發(fā)次數(shù)中斷標(biāo)志位
  100. #define TX_DS        0x20 //發(fā)送完成中斷標(biāo)志位         //
  101. #define RX_DR        0x40 //接收到數(shù)據(jù)中斷標(biāo)志位
相關(guān)帖子
