#include<reg52.h>
#include <intrins.h>
uchar old1,old2,old3,old4,old5,old6; //原始密碼000000
uchar new1,new2,new3,new4,new5,new6; //每次MCU采集到的密碼輸入
uchar a=16,b=16,c=16,d=16,e=16,f=16; //送入數(shù)碼管顯示的變量
uchar wei,key,temp;
bit allow,genggai,ok,wanbi,retry,close; //各個狀態(tài)位
sbit dula=P2^6;
sbit wela=P2^7;
sbit beep=P2^3;
sbit sda=P2^0; //IO口定義
sbit scl=P2^1;
unsigned char code table[]=
{0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,
0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00,0x40};
/*****************IIC芯片24C02存儲器驅(qū)動程序************************************/
void nop()
_nop_();
_nop_();
/////////24C02讀寫驅(qū)動程序////////////////////
void delay1(unsigned int m)
{ unsigned int n;
for(n=0;n<m;n++);
void init() //24c02初始化子程序
scl=1;
nop();
sda=1;
nop();
void start() //啟動I2C總線
sda=1;
nop();
scl=1;
nop();
sda=0;
nop();
scl=0;
nop();
void stop() //停止I2C總線
sda=0;
nop();
scl=1;
nop();
sda=1;
nop();
void writebyte(unsigned char j) //寫一個字節(jié)
unsigned char i,temp;
temp=j;
for (i=0;i<8;i++)
temp=temp<<1;
scl=0;
nop();
sda=CY; //temp左移時,移出的值放入了CY中
nop();
scl=1; //待sda線上的數(shù)據(jù)穩(wěn)定后,將scl拉高
nop();
scl=0;
nop();
sda=1;
nop();
unsigned char readbyte() //讀一個字節(jié)
unsigned char i,j,k=0;
scl=0; nop(); sda=1;
for (i=0;i<8;i++)
nop(); scl=1; nop();
if(sda==1)
j=1;
j=0;
k=(k<<1)|j;
scl=0;
nop();
return(k);
void clock() //I2C總線時鐘
unsigned char i=0;
scl=1;
nop();
while((sda==1)&&(i<255))
i++;
scl=0;
nop();
////////從24c02的地址address中讀取一個字節(jié)數(shù)據(jù)/////
unsigned char read24c02(unsigned char address)
unsigned char i;
start();
writebyte(0xa0);
clock();
writebyte(address);
clock();
start();
writebyte(0xa1);
clock();
i=readbyte();
stop();
delay1(100);
return(i);
//////向24c02的address地址中寫入一字節(jié)數(shù)據(jù)info/////
void write24c02(unsigned char address,unsigned char info)
start();
writebyte(0xa0);
clock();
writebyte(address);
clock();
writebyte(info);
clock();
stop();
delay1(5000); //這個延時一定要足夠長,否則會出錯。因為24c02在從sda上取得數(shù)據(jù)后,還需要一定時間的燒錄過程。
/****************************密碼鎖程序模塊********************************************************/
void delay(unsigned char i)
uchar j,k;
for(j=i;j>0;j--)
for(k=125;k>0;k--);
void display(uchar a,uchar b,uchar c,uchar d,uchar e,uchar f)
dula=0;
P0=table[a];
dula=1;
dula=0;
wela=0;
P0=0xfe;
wela=1;
wela=0;
delay(5);
P0=table[b];
dula=1;
dula=0;
P0=0xfd;
wela=1;
wela=0;
delay(5);
P0=table[c];
dula=1;
dula=0;
P0=0xfb;
wela=1;
wela=0;
delay(5);
P0=table[d];
dula=1;
dula=0;
P0=0xf7;
wela=1;
wela=0;
delay(5);
P0=table[e];
dula=1;
dula=0;
P0=0xef;
wela=1;
wela=0;
delay(5);
P0=table[f];
dula=1;
dula=0;
P0=0xdf;
wela=1;
wela=0;
delay(5);
void keyscan()
P3=0xfe;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delay(10);
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xee:
key=0;
wei++;
break;
case 0xde:
key=1;
wei++;
break;
case 0xbe:
key=2;
wei++;
break;
case 0x7e:
key=3;
wei++;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
beep=0;
beep=1;
P3=0xfd;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delay(10);
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xed:
key=4;
wei++;
break;
case 0xdd:
key=5;
wei++;
break;
case 0xbd:
key=6;
wei++;
break;
case 0x7d:
key=7;
wei++;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
beep=0;
beep=1;
P3=0xfb;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delay(10);
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xeb:
key=8;
wei++;
break;
case 0xdb:
key=9;
wei++;
break;
case 0xbb:
genggai=1;
wei=0;
break;
case 0x7b:
if(allow)
ok=1;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
beep=0;
beep=1;
P3=0xf7;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delay(10);
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xe7:
retry=1;
break;
case 0xd7:
close=1;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
beep=0;
beep=1;
void shumima() //對按鍵采集來的數(shù)據(jù)進行分配
if(!wanbi)
switch(wei)
case 1:new1=key;
if(!allow) a=17;
else a=key; break;
case 2:new2=key;
if(a==17) b=17;
else b=key; break;
case 3:new3=key;
if(a==17) c=17;
else c=key; break;
case 4:new4=key;
if(a==17) d=17;
else d=key; break;
case 5:new5=key;
if(a==17) e=17;
else e=key; break;
case 6:new6=key;
if(a==17) f=17;
else f=key;
wanbi=1; break;
void yanzheng() //驗證密碼是否正確
if(wanbi) //只有當六位密碼均輸入完畢后方進行驗證
if((new1==old1)&(new2==old2)&(new3==old3)&(new4==old4)&(new5==old5)&(new6==old6))
allow=1; //當輸入的密碼正確,會得到allowe置一
init(); //初始化24C02
/*********下面的一小段程序的功能為格式化密碼存儲區(qū)。************
******當24c02中這些存儲區(qū)由于其他程序的運行而導致***************
*******所存數(shù)據(jù)發(fā)生了變化,或者密碼遺忘時, ********************
******可以刪掉其前面的注釋線,然后重新編譯下載。****************
******而將密碼還原為000000后,請將下面的程序用******************
******注釋屏蔽掉,重新編譯、下載,方可正常使用****************/
// write24c02(110,0x00);
// write24c02(111,0x00);//24c02的第110到115地址單元作為密碼存儲區(qū)
// write24c02(112,0x00);
// write24c02(113,0x00);
// write24c02(114,0x00);
// write24c02(115,0x00);
old1=read24c02(110);
old2=read24c02(111);
old3=read24c02(112);
old4=read24c02(113);
old5=read24c02(114);
old6=read24c02(115);
keyscan();
shumima();
yanzheng();
if(allow) //驗證完后,若allow為1,則開鎖
P1=0x00;
if(!genggai)
wanbi=0;
if(genggai) //當S16更改密碼鍵被按下,genggai會被置一
if(allow) //若已經(jīng)把鎖打開,才有更改密碼的權限
while(!wanbi) //當新的六位密碼沒有設定完,則一直在這里循環(huán)
keyscan();
shumima();
if(retry|close) //而當探測到重試鍵S18或者關閉密碼鎖鍵S19被按下時,則跳出
{ wanbi=1;
break;
display(a,b,c,d,e,f);
if(ok) //更改密碼時,當所有六位新密碼均被按下時,可以按下此鍵,結(jié)束密碼更改
{ //其他時間按下此鍵無效
ok=0; wei=0;
genggai=0;
old1=new1;old2=new2;old3=new3; //此時,舊的密碼將被代替
old4=new4;old5=new5;old6=new6;
//新密碼寫入存儲區(qū)。
write24c02(110,old1);
write24c02(111,old2);
write24c02(112,old3);
write24c02(113,old4);
write24c02(114,old5);
write24c02(115,old6);
a=16;b=16;c=16;d=16;e=16;f=16;
if(retry) //當重試按鍵S18被按下,retry會被置位
retry=0; wei=0;wanbi=0;
new1=0;new2=0;new3=0;new4=0;new5=0;new6=0;
if(close) //當關閉密碼鎖按鍵被按下,close會被置位
close=0;genggai=0;//所有變量均被清零。
wei=0; wanbi=0;
allow=0;
P1=0xff;
display(a,b,c,d,e,f); //實時顯示
