#include <REG51.H>
#include <intrins.h>
//#include "LCD1602.h"
//#include "DS1302.h"
sbit DS1302_CLK = P1^5; //實(shí)時(shí)時(shí)鐘時(shí)鐘線引腳
sbit DS1302_IO = P1^6; //實(shí)時(shí)時(shí)鐘數(shù)據(jù)線引腳
sbit DS1302_RST = P1^7; //實(shí)時(shí)時(shí)鐘復(fù)位線引腳
sbit wireless_1 = P3^0;
sbit wireless_2 = P3^1;
sbit wireless_3 = P3^2;
sbit wireless_4 = P3^3;
sbit ACC0 = ACC^0;
sbit ACC7 = ACC^7;
char hide_sec,hide_min,hide_hour,hide_day,hide_week,hide_month,hide_year; //秒,分,時(shí)到日,月,年位閃的計(jì)數(shù)
sbit Set = P3^4; //模式切換鍵
sbit Up = P3^5; //加法按鈕
sbit Down = P3^6; //減法按鈕
sbit out = P3^7; //立刻跳出調(diào)整模式按鈕
sbit DQ = P1^0; //溫度傳送數(shù)據(jù)IO口
char done,count,temp,flag,up_flag,down_flag;
uchar temp_value; //溫度值
uchar TempBuffer[5],week_value[2];
void show_time(); //液晶顯示程序
/***********1602液晶顯示部分子程序****************/
//Port Definitions**********************************************************
sbit LcdRs = P0^5;
sbit LcdRw = P0^6;
sbit LcdEn = P0^7;
sfr DBPort = 0xA0; //P0=0x80,P1=0x90,P2=0xA0,P3=0xB0.數(shù)據(jù)端口
//內(nèi)部等待函數(shù)**************************************************************************
unsigned char LCD_Wait(void)
LcdRs=0;
LcdRw=1; _nop_();
LcdEn=1; _nop_();
LcdEn=0;
return DBPort;
//向LCD寫入命令或數(shù)據(jù)************************************************************
#define LCD_COMMAND 0 // Command
#define LCD_DATA 1 // Data
#define LCD_CLEAR_SCREEN 0x01 // 清屏
#define LCD_HOMING 0x02 // 光標(biāo)返回原點(diǎn)
void LCD_Write(bit style, unsigned char input)
LcdEn=0;
LcdRs=style;
LcdRw=0; _nop_();
DBPort=input; _nop_();//注意順序
LcdEn=1; _nop_();//注意順序
LcdEn=0; _nop_();
LCD_Wait();
//設(shè)置顯示模式************************************************************
#define LCD_SHOW 0x04 //顯示開
#define LCD_HIDE 0x00 //顯示關(guān)
#define LCD_CURSOR 0x02 //顯示光標(biāo)
#define LCD_NO_CURSOR 0x00 //無光標(biāo)
#define LCD_FLASH 0x01 //光標(biāo)閃動(dòng)
#define LCD_NO_FLASH 0x00 //光標(biāo)不閃動(dòng)
void LCD_SetDisplay(unsigned char DisplayMode)
LCD_Write(LCD_COMMAND, 0x08|DisplayMode);
//設(shè)置輸入模式************************************************************
#define LCD_AC_UP 0x02
#define LCD_AC_DOWN 0x00 // default
#define LCD_MOVE 0x01 // 畫面可平移
#define LCD_NO_MOVE 0x00 //default
void LCD_SetInput(unsigned char InputMode)
LCD_Write(LCD_COMMAND, 0x04|InputMode);
//初始化LCD************************************************************
void LCD_Initial()
LcdEn=0;
LCD_Write(LCD_COMMAND,0x38); //8位數(shù)據(jù)端口,2行顯示,5*7點(diǎn)陣
LCD_SetDisplay(LCD_SHOW|LCD_NO_CURSOR); //開啟顯示, 無光標(biāo)
LCD_Write(LCD_COMMAND,LCD_CLEAR_SCREEN); //清屏
LCD_SetInput(LCD_AC_UP|LCD_NO_MOVE); //AC遞增, 畫面不動(dòng)
//液晶字符輸入的位置************************
void GotoXY(unsigned char x, unsigned char y)
if(y==0)
LCD_Write(LCD_COMMAND,0x80|x);
if(y==1)
LCD_Write(LCD_COMMAND,0x80|(x-0x40));
//將字符輸出到液晶顯示
void Print(unsigned char *str)
while(*str!='\0')
LCD_Write(LCD_DATA,*str);
str++;
/***********DS1302時(shí)鐘部分子程序******************/
typedef struct __SYSTEMTIME__
unsigned char Second;
unsigned char Minute;
unsigned char Hour;
unsigned char Week;
unsigned char Day;
unsigned char Month;
unsigned char Year;
unsigned char DateString[11];
unsigned char TimeString[9];
}SYSTEMTIME; //定義的時(shí)間類型
SYSTEMTIME CurrentTime;
#define AM(X) X
#define PM(X) (X+12) // 轉(zhuǎn)成24小時(shí)制
#define DS1302_SECOND 0x80 //時(shí)鐘芯片的寄存器位置,存放時(shí)間
#define DS1302_MINUTE 0x82
#define DS1302_HOUR 0x84
#define DS1302_WEEK 0x8A
#define DS1302_DAY 0x86
#define DS1302_MONTH 0x88
#define DS1302_YEAR 0x8C
void DS1302InputByte(unsigned char d) //實(shí)時(shí)時(shí)鐘寫入一字節(jié)(內(nèi)部函數(shù))
unsigned char i;
ACC = d;
for(i=8; i>0; i--)
DS1302_IO = ACC0; //相當(dāng)于匯編中的 RRC
DS1302_CLK = 1;
DS1302_CLK = 0;
ACC = ACC >> 1;
unsigned char DS1302OutputByte(void) //實(shí)時(shí)時(shí)鐘讀取一字節(jié)(內(nèi)部函數(shù))
unsigned char i;
for(i=8; i>0; i--)
ACC = ACC >>1; //相當(dāng)于匯編中的 RRC
ACC7 = DS1302_IO;
DS1302_CLK = 1;
DS1302_CLK = 0;
return(ACC);
void Write1302(unsigned char ucAddr, unsigned char ucDa) //ucAddr: DS1302地址, ucData: 要寫的數(shù)據(jù)
DS1302_RST = 0;
DS1302_CLK = 0;
DS1302_RST = 1;
DS1302InputByte(ucAddr); // 地址,命令
DS1302InputByte(ucDa); // 寫1Byte數(shù)據(jù)
DS1302_CLK = 1;
DS1302_RST = 0;
unsigned char Read1302(unsigned char ucAddr) //讀取DS1302某地址的數(shù)據(jù)
unsigned char ucData;
DS1302_RST = 0;
DS1302_CLK = 0;
DS1302_RST = 1;
DS1302InputByte(ucAddr|0x01); // 地址,命令
ucData = DS1302OutputByte(); // 讀1Byte數(shù)據(jù)
DS1302_CLK = 1;
DS1302_RST = 0;
return(ucData);
void DS1302_GetTime(SYSTEMTIME *Time) //獲取時(shí)鐘芯片的時(shí)鐘數(shù)據(jù)到自定義的結(jié)構(gòu)型數(shù)組
unsigned char ReadValue;
ReadValue = Read1302(DS1302_SECOND);
Time->Second = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
ReadValue = Read1302(DS1302_MINUTE);
Time->Minute = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
ReadValue = Read1302(DS1302_HOUR);
Time->Hour = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
ReadValue = Read1302(DS1302_DAY);
Time->Day = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
ReadValue = Read1302(DS1302_WEEK);
Time->Week = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
ReadValue = Read1302(DS1302_MONTH);
Time->Month = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
ReadValue = Read1302(DS1302_YEAR);
Time->Year = ((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
void DateToStr(SYSTEMTIME *Time) //將時(shí)間年,月,日,星期數(shù)據(jù)轉(zhuǎn)換成液晶顯示字符串,放到數(shù)組里DateString[]
{ if(hide_year<2) //這里的if,else語句都是判斷位閃爍,<2顯示數(shù)據(jù),>2就不顯示,輸出字符串為 2007/07/22
Time->DateString[0] = '2';
Time->DateString[1] = '0';
Time->DateString[2] = Time->Year/10 + '0';
Time->DateString[3] = Time->Year%10 + '0';
Time->DateString[0] = ' ';
Time->DateString[1] = ' ';
Time->DateString[2] = ' ';
Time->DateString[3] = ' ';
Time->DateString[4] = '/';
if(hide_month<2)
Time->DateString[5] = Time->Month/10 + '0';
Time->DateString[6] = Time->Month%10 + '0';
Time->DateString[5] = ' ';
Time->DateString[6] = ' ';
Time->DateString[7] = '/';
if(hide_day<2)
Time->DateString[8] = Time->Day/10 + '0';
Time->DateString[9] = Time->Day%10 + '0';
Time->DateString[8] = ' ';
Time->DateString[9] = ' ';
if(hide_week<2)
week_value[0] = Time->Week%10 + '0'; //星期的數(shù)據(jù)另外放到 week_value[]數(shù)組里,跟年,月,日的分開存放,因?yàn)榈纫幌乱谧詈箫@示
week_value[0] = ' ';
week_value[1] = '\0';
Time->DateString[10] = '\0'; //字符串末尾加 '\0' ,判斷結(jié)束字符
void TimeToStr(SYSTEMTIME *Time) //將時(shí),分,秒數(shù)據(jù)轉(zhuǎn)換成液晶顯示字符放到數(shù)組 TimeString[];
{ if(hide_hour<2)
Time->TimeString[0] = Time->Hour/10 + '0';
Time->TimeString[1] = Time->Hour%10 + '0';
Time->TimeString[0] = ' ';
Time->TimeString[1] = ' ';
Time->TimeString[2] = ':';
if(hide_min<2)
Time->TimeString[3] = Time->Minute/10 + '0';
Time->TimeString[4] = Time->Minute%10 + '0';
Time->TimeString[3] = ' ';
Time->TimeString[4] = ' ';
Time->TimeString[5] = ':';
if(hide_sec<2)
Time->TimeString[6] = Time->Second/10 + '0';
Time->TimeString[7] = Time->Second%10 + '0';
Time->TimeString[6] = ' ';
Time->TimeString[7] = ' ';
Time->DateString[8] = '\0';
void Initial_DS1302(void) //時(shí)鐘芯片初始化
unsigned char Second=Read1302(DS1302_SECOND);
if(Second&0x80) //判斷時(shí)鐘芯片是否關(guān)閉
Write1302(0x8e,0x00); //寫入允許
Write1302(0x8c,0x07); //以下寫入初始化時(shí)間 日期:07/07/25.星期: 3. 時(shí)間: 23:59:55
Write1302(0x88,0x07);
Write1302(0x86,0x25);
Write1302(0x8a,0x07);
Write1302(0x84,0x23);
Write1302(0x82,0x59);
Write1302(0x80,0x55);
Write1302(0x8e,0x80); //禁止寫入
/***********ds18b20子程序*************************/
/***********ds18b20延遲子函數(shù)(晶振12MHz )*******/
void delay_18B20(unsigned int i)
while(i--);
/**********ds18b20初始化函數(shù)**********************/
void Init_DS18B20(void)
unsigned char x=0;
DQ = 1; //DQ復(fù)位
delay_18B20(8); //稍做延時(shí)
DQ = 0; //單片機(jī)將DQ拉低
delay_18B20(80); //精確延時(shí) 大于 480us
DQ = 1; //拉高總線
delay_18B20(14);
x=DQ; //稍做延時(shí)后 如果x=0則初始化成功 x=1則初始化失敗
delay_18B20(20);
/***********ds18b20讀一個(gè)字節(jié)**************/
unsigned char ReadOneChar(void)
uchar i=0;
uchar dat = 0;
for (i=8;i>0;i--)
DQ = 0; // 給脈沖信號(hào)
dat>>=1;
DQ = 1; // 給脈沖信號(hào)
if(DQ)
dat|=0x80;
delay_18B20(4);
return(dat);
/*************ds18b20寫一個(gè)字節(jié)****************/
void WriteOneChar(uchar dat)
unsigned char i=0;
for (i=8; i>0; i--)
DQ = 0;
DQ = dat&0x01;
delay_18B20(5);
DQ = 1;
dat>>=1;
/**************讀取ds18b20當(dāng)前溫度************/
void ReadTemp(void)
unsigned char a=0;
unsigned char b=0;
unsigned char t=0;
Init_DS18B20();
WriteOneChar(0xCC); // 跳過讀序號(hào)列號(hào)的操作
WriteOneChar(0x44); // 啟動(dòng)溫度轉(zhuǎn)換
delay_18B20(100); // this message is wery important
Init_DS18B20();
WriteOneChar(0xCC); //跳過讀序號(hào)列號(hào)的操作
WriteOneChar(0xBE); //讀取溫度寄存器等(共可讀9個(gè)寄存器) 前兩個(gè)就是溫度
delay_18B20(100);
a=ReadOneChar(); //讀取溫度值低位
b=ReadOneChar(); //讀取溫度值高位
temp_value=b<<4;
temp_value+=(a&0xf0)>>4;
void temp_to_str() //溫度數(shù)據(jù)轉(zhuǎn)換成液晶字符顯示
TempBuffer[0]=temp_value/10+'0'; //十位
TempBuffer[1]=temp_value%10+'0'; //個(gè)位
TempBuffer[2]=0xdf; //溫度符號(hào)
TempBuffer[3]='C';
TempBuffer[4]='\0';
void Delay1ms(unsigned int count)
unsigned int i,j;
for(i=0;i<count;i++)
for(j=0;j<120;j++);
/*延時(shí)子程序*/
void mdelay(uint delay)
{ uint i;
for(;delay>0;delay--)
{for(i=0;i<62;i++) //1ms延時(shí).
void outkey() //跳出調(diào)整模式,返回默認(rèn)顯示
{ uchar Second;
if(out==0||wireless_1==1)
{ mdelay(8);
count=0;
hide_sec=0,hide_min=0,hide_hour=0,hide_day=0,hide_week=0,hide_month=0,hide_year=0;
Write1302(0x80,Second&0x7f);
Write1302(0x8E,0x80); //禁止寫入
done=0;
while(out==0);
while(wireless_1==1);
void Upkey()//升序按鍵
Up=1;
if(Up==0||wireless_2==1)
mdelay(8);
switch(count)
{case 1:
temp=Read1302(DS1302_SECOND); //讀取秒數(shù)
temp=temp+1; //秒數(shù)加1
up_flag=1; //數(shù)據(jù)調(diào)整后更新標(biāo)志
if((temp&0x7f)>0x59) //超過59秒,清零
temp=0;
break;
case 2:
temp=Read1302(DS1302_MINUTE); //讀取分?jǐn)?shù)
temp=temp+1; //分?jǐn)?shù)加1
up_flag=1;
if(temp>0x59) //超過59分,清零
temp=0;
break;
case 3:
temp=Read1302(DS1302_HOUR); //讀取小時(shí)數(shù)
temp=temp+1; //小時(shí)數(shù)加1
up_flag=1;
if(temp>0x23) //超過23小時(shí),清零
temp=0;
break;
case 4:
temp=Read1302(DS1302_WEEK); //讀取星期數(shù)
temp=temp+1; //星期數(shù)加1
up_flag=1;
if(temp>0x7)
temp=1;
break;
case 5:
temp=Read1302(DS1302_DAY); //讀取日數(shù)
temp=temp+1; //日數(shù)加1
up_flag=1;
if(temp>0x31)
temp=1;
break;
case 6:
temp=Read1302(DS1302_MONTH); //讀取月數(shù)
temp=temp+1; //月數(shù)加1
up_flag=1;
if(temp>0x12)
temp=1;
break;
case 7:
temp=Read1302(DS1302_YEAR); //讀取年數(shù)
temp=temp+1; //年數(shù)加1
up_flag=1;
if(temp>0x85)
temp=0;
break;
default:break;
while(Up==0);
while(wireless_2==1);
void Downkey()//降序按鍵
Down=1;
if(Down==0||wireless_3==1)
mdelay(8);
switch(count)
{case 1:
temp=temp-1; //秒數(shù)減1
down_flag=1; //數(shù)據(jù)調(diào)整后更新標(biāo)志
if(temp==0x7f) //小于0秒,返回59秒
temp=0x59;
break;
case 2:
temp=temp-1; //分?jǐn)?shù)減1
down_flag=1;
if(temp==-1)
temp=0x59; //小于0秒,返回59秒
break;
case 3:
temp=temp-1; //小時(shí)數(shù)減1
down_flag=1;
if(temp==-1)
temp=0x23;
break;
case 4:
temp=temp-1; //星期數(shù)減1
down_flag=1;
if(temp==0)
temp=0x7;;
break;
case 5:
temp=temp-1; //日數(shù)減1
down_flag=1;
if(temp==0)
temp=31;
break;
case 6:
temp=temp-1; //月數(shù)減1
down_flag=1;
if(temp==0)
temp=12;
break;
case 7:
temp=temp-1; //年數(shù)減1
down_flag=1;
if(temp==-1)
temp=0x85;
break;
default:break;
while(Down==0);
while(wireless_3==1);
void Setkey()//模式選擇按鍵
Set=1;
if(Set==0||wireless_4==1)
mdelay(8);
count=count+1; //Setkey按一次,count就加1
done=1; //進(jìn)入調(diào)整模式
while(Set==0);
while(wireless_4==1);
void keydone()//按鍵功能執(zhí)行
{ uchar Second;
if(flag==0) //關(guān)閉時(shí)鐘,停止計(jì)時(shí)
{ Write1302(0x8e,0x00); //寫入允許
temp=Read1302(0x80);
Write1302(0x80,temp|0x80);
flag=1;
Setkey(); //掃描模式切換按鍵
switch(count)
{case 1:do //count=1,調(diào)整秒
outkey(); //掃描跳出按鈕
Upkey(); //掃描加按鈕
Downkey(); //掃描減按鈕
if(up_flag==1||down_flag==1) //數(shù)據(jù)更新,重新寫入新的數(shù)據(jù)
Write1302(0x80,temp|0x80); //寫入新的秒數(shù)
up_flag=0;
down_flag=0;
hide_sec++; //位閃計(jì)數(shù)
if(hide_sec>3)
hide_sec=0;
show_time(); //液晶顯示數(shù)據(jù)
}while(count==2);break;
case 2:do //count=2,調(diào)整分
hide_sec=0;
outkey();
Upkey();
Downkey();
if(temp>0x60)
temp=0;
Write1302(0x82,temp); //寫入新的分?jǐn)?shù)
up_flag=0;
down_flag=0;
hide_min++;
if(hide_min>3)
hide_min=0;
show_time();
}while(count==3);break;
case 3:do //count=3,調(diào)整小時(shí)
hide_min=0;
outkey();
Upkey();
Downkey();
Write1302(0x84,temp); //寫入新的小時(shí)數(shù)
up_flag=0;
down_flag=0;
hide_hour++;
if(hide_hour>3)
hide_hour=0;
show_time();
}while(count==4);break;
case 4:do //count=4,調(diào)整星期
hide_hour=0;
outkey();
Upkey();
Downkey();
Write1302(0x8a,temp); //寫入新的星期數(shù)
up_flag=0;
down_flag=0;
hide_week++;
if(hide_week>3)
hide_week=0;
show_time();
}while(count==5);break;
case 5:do //count=5,調(diào)整日
hide_week=0;
outkey();
Upkey();
Downkey();
Write1302(0x86,temp); //寫入新的日數(shù)
up_flag=0;
down_flag=0;
hide_day++;
if(hide_day>3)
hide_day=0;
show_time();
}while(count==6);break;
case 6:do //count=6,調(diào)整月
hide_day=0;
outkey();
Upkey();
Downkey();
Write1302(0x88,temp); //寫入新的月數(shù)
up_flag=0;
down_flag=0;
hide_month++;
if(hide_month>3)
hide_month=0;
show_time();
}while(count==7);break;
case 7:do //count=7,調(diào)整年
hide_month=0;
outkey();
Upkey();
Downkey();
Write1302(0x8c,temp); //寫入新的年數(shù)
up_flag=0;
down_flag=0;
hide_year++;
if(hide_year>3)
hide_year=0;
show_time();
}while(count==8);break;
case 8: count=0;hide_year=0; //count8, 跳出調(diào)整模式,返回默認(rèn)顯示狀態(tài)
done=0;
break; //count=7,開啟中斷,標(biāo)志位置0并退出
default:break;
void show_time() //液晶顯示程序
DS1302_GetTime(&CurrentTime); //獲取時(shí)鐘芯片的時(shí)間數(shù)據(jù)
TimeToStr(&CurrentTime); //時(shí)間數(shù)據(jù)轉(zhuǎn)換液晶字符
DateToStr(&CurrentTime); //日期數(shù)據(jù)轉(zhuǎn)換液晶字符
ReadTemp(); //開啟溫度采集程序
temp_to_str(); //溫度數(shù)據(jù)轉(zhuǎn)換成液晶字符
GotoXY(12,1); //液晶字符顯示位置
Print(TempBuffer); //顯示溫度
GotoXY(0,1);
Print(CurrentTime.TimeString); //顯示時(shí)間
GotoXY(0,0);
Print(CurrentTime.DateString); //顯示日期
GotoXY(15,0);
Print(week_value); //顯示星期
GotoXY(11,0);
Print("Week"); //在液晶上顯示 字母 week
Delay1ms(400); //掃描延時(shí)
main()
flag=1; //時(shí)鐘停止標(biāo)志
LCD_Initial(); //液晶初始化
Init_DS18B20( ) ; //DS18B20初始化
Initial_DS1302(); //時(shí)鐘芯片初始化
up_flag=0;
down_flag=0;
done=0; //進(jìn)入默認(rèn)液晶顯示
wireless_1=0;
wireless_2=0;
wireless_3=0;
wireless_4=0;
while(done==1)
keydone(); //進(jìn)入調(diào)整模式
while(done==0)
flag=0;
Setkey(); //掃描各功能鍵
