查看: 2815|回復(fù): 3
秒表開發(fā)程序
ID:91995 發(fā)表于 2015-10-9 17:29 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
uchar code du[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};  //0-9
uchar code se[]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10};  //0.-9.
char Min,Sec;    //定義十位和個(gè)位
void delayms(uint z)    //延時(shí)1秒鐘
  uint x;
  for(;z>0;z--)
   for(x=110; x>0; x--);
void Time_Init()       //時(shí)間初始化
   EA = 1;
  TMOD |= 0X01;
  TH0 = (65536 - 2000)/256;
  TL0 = (65536 - 2000)%256;
  ET0 = 1;
void display()      //顯示程序
   P2 = 0xfe;
  P0 = du[Sec];
  delayms(2);
  P0 = 0xff;
  P2 = 0xfd;
  P0 = se[Min];
  delayms(2);
  P0 = 0xff;
void keyboradscan()
    uchar key;
static uchar key_on = 0;
key = P3 & 0x0f;
if(key != 0x0f)
    if(key_on ==0)
     key_on = 1;
      switch (key)
     case 0x0e:TR0 = 1;break;
      case 0x0d:TR0 = 0;break;
      case 0x0b:TR0 = 0;Sec = 0;Min = 0;break;
     key_on = 0;
    Time_Init();         //時(shí)間初始化
   display();        //顯示掃描
   keyboradscan();     //鍵盤掃描
   if(Min == 9 && Sec == 9)
     TR0  = 0;
      Min = 9;Sec = 9;
void Timer0() interrupt 1
static int count;
count++;
    if(count >= 50)      //1毫秒加1
    count = 0;
    Sec++;
      if(Sec > 9)       //加到9后
     Sec = 0;         //毫秒清零
     Min++;           //秒加1
     if(Min > 9)
      Min = 0;       //秒清零
ID:1 發(fā)表于 2015-10-9 17:59 來自觸屏版 | 顯示全部樓層
謝謝分享,能共享一下電路圖嗎
ID:88707 發(fā)表于 2015-10-10 22:14 | 顯示全部樓層
感謝分享,研究一下
ID:120571 發(fā)表于 2016-5-13 17:16 | 顯示全部樓層
有電路嗎?
