- Attribute VB_Name = "Module1"
- Option Explicit
- Global Const ZERO = 0
- Global Const ASCENDING_ORDER = 0
- Global Const DESCENDING_ORDER = 1
- Global gIterations
- Sub BubbleSort(MyArray(), ByVal nOrder As Integer)
- Dim Index
- Dim TEMP
- Dim NextElement
- NextElement = ZERO
- Do While (NextElement < UBound(MyArray))
- Index = UBound(MyArray)
- Do While (Index > NextElement)
- If nOrder = ASCENDING_ORDER Then
- If MyArray(Index) < MyArray(Index - 1) Then
- TEMP = MyArray(Index)
- MyArray(Index) = MyArray(Index - 1)
- MyArray(Index - 1) = TEMP
- End If
- ElseIf nOrder = DESCENDING_ORDER Then
- If MyArray(Index) >= MyArray(Index - 1) Then
- End If
- End If
- Index = Index - 1
- gIterations = gIterations + 1
- Loop
- NextElement = NextElement + 1
- Loop
- End Sub
- Sub Bucket(MyArray(), ByVal nOrder As Integer)
- Dim Index
- Dim NextElement
- Dim TheBucket
- NextElement = LBound(MyArray) + 1
- While (NextElement <= UBound(MyArray))
- TheBucket = MyArray(NextElement)
- Index = NextElement
- Do
- If Index > LBound(MyArray) Then
- If TheBucket < MyArray(Index - 1) Then
- Index = Index - 1
- Else
- Exit Do
- End If
- If TheBucket >= MyArray(Index - 1) Then
- Index = Index - 1
- Else
- Exit Do
- End If
- End If
- Else
- Exit Do
- End If
- Loop
- MyArray(Index) = TheBucket
- Wend
- End Sub
- Sub Heap(MyArray())
- Dim Index
- Dim Size
- Dim TEMP
- Size = UBound(MyArray)
- Index = 1
- While (Index <= Size)
- Call HeapSiftup(MyArray(), Index)
- Index = Index + 1
- Wend
- Index = Size
- While (Index > 0)
- TEMP = MyArray(0)
- MyArray(0) = MyArray(Index)
- MyArray(Index) = TEMP
- Call HeapSiftdown(MyArray(), Index - 1)
- Index = Index - 1
- Wend
- End Sub
- Sub HeapSiftdown(MyArray(), M)
- Dim Index
- Dim Parent
- Dim TEMP
- Index = 0
- Parent = 2 * Index
- Do While (Parent <= M)
- If (Parent < M And MyArray(Parent) < MyArray(Parent + 1)) Then
- Parent = Parent + 1
- End If
- If MyArray(Index) >= MyArray(Parent) Then
- Exit Do
- End If
- MyArray(Index) = MyArray(Parent)
- MyArray(Parent) = TEMP
- Index = Parent
- Loop
- End Sub
- Sub HeapSiftup(MyArray(), M)
- Dim Index
- Dim Parent
- Dim TEMP
- Index = M
- Do While (Index > 0)
- Parent = Int(Index / 2)
- If MyArray(Parent) >= MyArray(Index) Then
- Exit Do
- End If
- Index = Parent
- Loop
- End Sub
- Sub Insertion(MyArray(), ByVal nOrder As Integer)
- Dim Index
- Dim TEMP
- Dim NextElement
- Do
- Index = Index - 1
- Else
- Exit Do
- End If
- Index = Index - 1
- Else
- Exit Do
- End If
- End If
- Else
- Exit Do
- End If
- Loop
- Wend
- End Sub
- Sub QuickSort(MyArray(), L, R)
- Dim I, J, X, Y
- I = L
- J = R
- X = MyArray((L + R) / 2)
- While (I <= J)
- While (MyArray(I) < X And I < R)
- I = I + 1
- Wend
- While (X < MyArray(J) And J > L)
- J = J - 1
- Wend
- If (I <= J) Then
- Y = MyArray(I)
- MyArray(I) = MyArray(J)
- MyArray(J) = Y
- I = I + 1
- J = J - 1
- End If
- Wend
- If (L < J) Then Call QuickSort(MyArray(), L, J)
- If (I < R) Then Call QuickSort(MyArray(), I, R)
- End Sub
- Sub Selection(MyArray(), ByVal nOrder As Integer)
- Dim Index
- Dim Min
- Dim NextElement
- Dim TEMP
- NextElement = 0
- While (NextElement < UBound(MyArray))
- Min = UBound(MyArray)
- Index = Min - 1
- While (Index >= NextElement)
- If MyArray(Index) < MyArray(Min) Then
- Min = Index
- End If
- If MyArray(Index) >= MyArray(Min) Then
- Min = Index
- End If
- End If
- Index = Index - 1
- Wend
- TEMP = MyArray(Min)
- MyArray(Min) = MyArray(NextElement)
- MyArray(NextElement) = TEMP
- gIterations = gIterations - 1
- Wend
- End Sub
- Sub ShellSort(MyArray(), ByVal nOrder As Integer)
- Dim Distance
- Dim Size
- Dim Index
- Dim NextElement
- Dim TEMP
- Size = UBound(MyArray) - LBound(MyArray) + 1
- Distance = 1
- While (Distance <= Size)
- Distance = 2 * Distance
- Wend
- Distance = (Distance / 2) - 1
- While (Distance > 0)
- NextElement = LBound(MyArray) + Distance
- Do
- If Index >= (LBound(MyArray) + Distance) Then
- If MyArray(Index) < MyArray(Index - Distance) Then
- MyArray(Index) = MyArray(Index - Distance)
- MyArray(Index - Distance) = TEMP
- Index = Index - Distance
- Else
- Exit Do
- End If
- If MyArray(Index) >= MyArray(Index - Distance) Then
- Else
- Exit Do
- End If
- End If
- Else
- Exit Do
- End If
- Loop
- Wend
- Distance = (Distance - 1) / 2
- Wend
- End Sub
