查看: 4121|回復(fù): 3
數(shù)字時(shí)鐘 51單片機(jī)
ID:96742 發(fā)表于 2015-11-23 07:49 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#include<intrins.h>
sbit lcdrs=P1^0;
sbit lcdrw=P1^1;
sbit lcden=P2^5;
sbit s1=P3^0;//功能鍵
sbit s2=P3^1; //增大鍵
sbit s3=P3^2;//減小鍵
sbit rd=P3^7;
sbit beep=P2^3;
uchar count,s1num;
uchar miao,shi,fen;
uchar code table[]=" 2015-10-24 sat";
uchar code table1[]="    00:00:00";
void delay(uint z)         //延時(shí)函數(shù)
uint y;
for(;z>0;z--)
for(y=110;y>0;y--)
void di()        //蜂鳴器發(fā)聲函數(shù)
beep=0;
delay(100);
beep=1;
  uchar busy_check(void)//判忙
        uchar lcd_status;
        lcdrs=0;
        lcdrw=1;
        lcden=1;
         delay(5);
         lcd_status=P0&0x80;
         lcden=0;
         return  lcd_status;
void write_com(uchar com)//寫指令
while(busy_check());//判忙
lcdrs=0;
lcdrw=0;
  lcden=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date) //寫數(shù)據(jù)
lcdrs=1;
lcdrw=0;
  lcden=0;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
  void init()
        uchar num;
        lcden=0;
    lcdrw=0;
        write_com(0x38); //初始化1602液晶
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);//設(shè)置顯示初始目標(biāo)
        for(num=0;num<15;num++)        // 顯示年月日星期
                        write_date(table[num]);
                        delay(5);
        write_com(0x80+0x40);
        for(num=0;num<12;num++)
                        write_date(table1[num]);
                        delay(5);
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
void write_sfm(uchar add,uchar date) //寫時(shí)分秒函數(shù)
        uchar shi,ge;
        shi=date/10; //十位數(shù)的分離
        ge=date%10;
        write_com(0x80+0x40+add);//設(shè)置顯示位置
        write_date(0x30+shi);        //送去液晶顯示十位
        write_date(0x30+ge);        //送去液晶顯示個(gè)位
void keyscan()        //按鍵掃描函數(shù)
        rd=0;
        if(s1==0)
                delay(5);
                if(s1==0) //確認(rèn)功能鍵被按下
                {        s1num++;//功能鍵按下次數(shù)記錄
                        while(!s1);//釋放確認(rèn)
                        if(s1num==1) //第一次被按下時(shí)
                                TR0=0; //關(guān)閉定時(shí)器
                                write_com(0x80+0x40+11);        //光標(biāo)定位到秒處
                                write_com(0x0f); //光標(biāo)開始閃爍
                        if(s1num==2)   //第二次按下光標(biāo)閃爍定位到分鐘位置
                                write_com(0x80+0x40+8);//光標(biāo)定位到分處
                        if(s1num==3)  //第二次按下光標(biāo)閃爍定位到小時(shí)位置
                                write_com(0x80+0x40+5);//光標(biāo)定位到小時(shí)處
                        if(s1num==4) //
                                s1num=0;         //記錄按鍵數(shù)清零
                                write_com(0x0c); //光標(biāo)取消閃爍
                                TR0=1;         //啟動(dòng)定時(shí)器使時(shí)鐘走起
                if(s1num!=0)  //
                        if(s2==0)//增大鍵按下
                                delay(5);
                                if(s2==0)
                                        while(!s2);
                                        if(s1num==1)
                                                miao++;//秒加1
                                                if(miao==60)//秒到了60,重新設(shè)置為0
                                                        miao=0;
                                                write_sfm(10,miao);          //每調(diào)節(jié)一次送液晶顯示一下
                                                write_com(0x80+0x40+10);//顯示位置
                                        if(s1num==2)
                                                fen++;
                                                if(fen==60)
                                                        fen=0;
                                                write_sfm(7,fen);
                                                write_com(0x80+0x40+7);
                                        if(s1num==3)
                                                shi++;
                                                if(shi==24)
                                                        shi=0;
                                                write_sfm(4,shi);
                                                write_com(0x80+0x40+4);
                        if(s3==0)
                                delay(5);
                                if(s3==0) //確認(rèn)減小鍵被按下
                                        while(!s3);//按鍵釋放
                                        di();
                                        if(s1num==1)
                                        /*        if(miao==0)
                                                        miao=59;
                                                        write_sfm(10,miao);
                                                miao--;        //則調(diào)整秒減1
                                                if(miao==-1)
                                                        miao=59;//若減到負(fù)數(shù)時(shí),重新設(shè)置為59
                                                write_sfm(10,miao);        //每調(diào)節(jié)一次,重新送回液晶顯示
                                                write_com(0x80+0x40+7);  //顯示位置重新回到調(diào)節(jié)處
                                        if(s1num==2)
                                                fen--;
                                                if(fen==-1)
                                                        fen=59;
                                                write_sfm(7,fen);
                                        if(s1num==3)
                                                shi--;
                                                if(shi==-1)
                                                        shi=23;
                                                write_sfm(4,shi);
                                                write_com(0x80+0x40+2);
        init();
                keyscan();
void timer0() interrupt 1
        count++;
if(count==20)  //1秒
                        count=0;
                        miao++;
                        if(miao==60)
                                miao=0;
                                fen++;
                                if(fen==60)
                                        fen=0;
                                        shi++;
                                        if(shi==24)
                                                shi=0;
                                        write_sfm(4,shi);  //小時(shí)變化重新寫入
                                write_sfm(7,fen); //分變化重新寫入
                        write_sfm(10,miao);        //秒變化重新寫入
相關(guān)帖子
ID:91165 發(fā)表于 2015-12-5 15:23 | 顯示全部樓層
咋跑 程序設(shè)計(jì)/上位機(jī) 板塊了
ID:260199 發(fā)表于 2017-12-12 10:10 | 顯示全部樓層
有沒有仿真電路圖
ID:96218 發(fā)表于 2018-1-16 15:24 | 顯示全部樓層
沒有圖,沒有真相
