LCD貌似很少用了 太小 這個(gè)作為串入并出的一個(gè)小實(shí)驗(yàn)罷LCD1602的數(shù)據(jù)線有8個(gè)直接用單片機(jī)驅(qū)動(dòng)很費(fèi)IO口,所以用74hc595(3位控制線串入8位并出)芯片的輸出端連接到LCD1602的數(shù)據(jù)線上
之前試了幾次都沒(méi)有弄好 主要是對(duì)數(shù)據(jù)手冊(cè)理解有誤
代碼(電路連接方式很簡(jiǎn)單,包含在其中):
- #include"Display.h"
- #include<avr/pgmspace.h>
- //unsigned char dpins[8]={A0,A1,A2,A3,A4,A5,8,9};
- void InitLCD1602();
- void WriteLCD1602Cmd(unsigned char cmd);
- void AllowInput74HC595();
- void WriteByte74HC595(byte data);
- void AllowOutput74HC595();
- void InitDisplay()
- pinMode(_74HC595_RCK,OUTPUT);
- pinMode(_74HC595_SCK,OUTPUT);
- pinMode(_74HC595_SI,OUTPUT);
- AllowInput74HC595();
- WriteByte74HC595(0x00);
- AllowOutput74HC595();
- InitLCD1602();
- pinMode(LCD1602_RS,OUTPUT);
- pinMode(LCD1602_RW,OUTPUT);
- pinMode(LCD1602_EN,OUTPUT);
- digitalWrite(LCD1602_EN,HIGH);
- digitalWrite(LCD1602_RW,HIGH);
- digitalWrite(LCD1602_RS,HIGH);
- for(int i=0;i<8;i++)
- pinMode(dpins[i],OUTPUT);
- digitalWrite(dpins[i],LOW);
- LCD1602_ENABLE;
- delayMicroseconds(100);
- WriteLCD1602Cmd(0x3c);//16*2行顯示,5*10點(diǎn)陣,8數(shù)據(jù)接口
- delayMicroseconds(64);
- delayMicroseconds(50);
- delay(20);
- WriteLCD1602Cmd(0x06);//顯示模式,屏幕不動(dòng),字符后移
- delayMicroseconds(20);
- WriteLCD1602Cmd(0x0c); //屏幕開,光標(biāo)關(guān)
- WriteLCD1602Cmd(0x01);//清屏
- LCD1602_RS_LOW; //rs=0:讀取/寫入指令模式
- LCD1602_RW_WRITE;
- delayMicroseconds(1);
- LCD1602_ENABLE;
- WriteByte74HC595(cmd);
- //WriteDpins(cmd);
- LCD1602_DISABLE;
- LCD1602_ENABLE;
- void WriteLCD1602Data(unsigned char data)
- LCD1602_RS_HIGH;
- LCD1602_RW_WRITE;
- LCD1602_ENABLE;
- WriteByte74HC595(data);
- //WriteDpins(data);
- LCD1602_DISABLE;
- LCD1602_ENABLE;
- void ClearLCD1602()
- int i;
- WriteLCD1602Cmd(0x80); //寫數(shù)據(jù)指針地址,0位置顯示
- for(i=0;i<16;i++)
- WriteLCD1602Data(' ');
- delay(5);
- WriteLCD1602Cmd(0xC0); //第二行顯示
- for(i=0;i<16;i++)
- delay(5);
- void Display(unsigned char row,char str[])
- int i;
- if(row==1)
- else
- int len=strlen(str);
- for(i=0;i<len;i++)
- WriteLCD1602Data(str[i]);
- delay(5);
- digitalWrite(_74HC595_RCK,LOW);//allow input 74HC595
- digitalWrite(_74HC595_RCK,HIGH);//allow output 74HC595
- void WriteByte74HC595(unsigned char data)
- boolean pinState;
- unsigned char i;
- digitalWrite(_74HC595_SI,LOW);
- digitalWrite(_74HC595_SCK,LOW);
- for(i=0;i<=7;i++)
- digitalWrite(_74HC595_SCK,LOW);//before output 1bit must set SCK low
- if(data &(0x01<<i))
- pinState=HIGH;
- else
- pinState=LOW;
- digitalWrite(_74HC595_SI,pinState);//write 1bit
- digitalWrite(_74HC595_SCK,HIGH);//74HC595 receive when rising edge occur
- digitalWrite(_74HC595_SCK,LOW); //stop 74HC595 input
- void WriteDpins(unsigned char d)
- int i;
- for(i=0;i<8;i++)
- if(d &(0x01<<i))
- digitalWrite(dpins[i],HIGH);
- else
BTComm.zip
2015-12-27 03:10 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
2.06 KB, 下載次數(shù): 38, 下載積分: 黑幣 -5
