黑塊是一閃一閃的,下面是我的程序
#include<intrins.h>
#include<AT89X52.H>
uchar code digit[]={"0123456789"}; //定義字符數(shù)組顯示數(shù)字
uchar code Error[]="Error!Check!"; //說(shuō)明沒有檢測(cè)到DS18B20
uchar code table[]="Alarm Clock";
uchar code table1[]="0123456789";
uchar code table2[]="WEEK";
uchar code table3[]="Today is fine!";
uchar code table4[]="HELLO!";
uchar code table5[]="Made by Kaili";
uchar code table6[]="Happy new year!!";//1.1
//uchar code table7[]="Valentine's Day"; //2.14
以下是對(duì)液晶模塊的操作程序
sbit RS=P2^5; //寄存器選擇位,將RS位定義為P2.0引腳
sbit RW=P2^6; //讀寫選擇位,將RW位定義為P2.1引腳
sbit E=P2^7; //使能信號(hào)位,將E位定義為P2.2引腳
sbit BF=P0^7; //忙碌標(biāo)志位,,將BF位定義為P0.7引腳
sbit ceshi=P1^0;
sbit T_RST=P1^6;
sbit T_CLK=P1^4;
sbit T_IO=P1^5;
sbit beep=P1^7;
sbit key1=P3^0; //調(diào)鬧鐘的小時(shí)即x
sbit key2=P3^1; //調(diào)鬧鐘的分鐘即y
sbit key4=P3^5; //顯示切換
sbit key3=P3^2;
sbit ACC0=ACC^0;
sbit ACC7=ACC^7;
sbit io=P1^1;
uchar time; //設(shè)置全局變量,專門用于嚴(yán)格延時(shí)
static uchar x=0x08,y=30;
uchar t_sec,sec1,sec2;
uchar t_min,min1,min2;
uchar t_hour,hour1,hour2;
uchar t_mon,mon1,mon2;
uchar t_day,day1,day2;
uchar t_year,year1,year2;
uchar week,week1;
uchar com,inf;
/*定義變量*/
uchar data_byte=0,count,SHISHI,SHIGE,WENSHI,WENGE;
uint TH_data,TL_data,RH_data,RL_data,CK_data;
uint TH_temp,TL_temp,RH_temp,RL_temp,CK_temp;
uchar num;
/*10微妙延時(shí)程序*/
void delay1()
unsigned char i;
for(i=0; i<3; i++);
函數(shù)功能:延時(shí)若干微秒
入口參數(shù):n
void delaynus(unsigned char n)
unsigned char i;
for(i=0;i<n;i++)
函數(shù)功能:延時(shí)1ms
(3j+2)*i=(3×33+2)×10=1010(微秒),可以認(rèn)為是1毫秒
void delay1ms()
uchar i,j;
for(i=0;i<10;i++)
for(j=0;j<33;j++)
函數(shù)功能:延時(shí)若干毫秒
入口參數(shù):n
void delaynms(uchar n)
uchar i;
for(i=0;i<n;i++)
delay1ms();
/**********************DHT11模塊**********************/
uchar receive_byte()//接收一個(gè)字節(jié)
uchar i,temp;
for(i=0;i<8; i++)
count = 2;
while((!io)&&count++)//等待50us低電平結(jié)束并防止死循環(huán)
temp = 0;
delay1();
delay1();
delay1();
if (io==1)
temp = 1;
count = 2;
while(io && count++);
temp = 0;
data_byte<<=1;
data_byte|=temp;
return (data_byte);
/*DHT11開始函數(shù)*/
void read_io()//開始信號(hào)讀數(shù)據(jù)并校驗(yàn)
io = 0;
delaynms(18);//主機(jī)拉低18ms
io=1;//DATA總線由上拉電阻拉高 主機(jī)延時(shí)20us
delay1();
delay1();
delay1();
delay1();
io = 1;//主機(jī)設(shè)置為輸入高電平判斷從機(jī)響應(yīng)信號(hào)
if(!io)
count = 2;
while((!io)&&count++);//判斷DHT11發(fā)出80us低電平響應(yīng)信號(hào)是否結(jié)束
count = 2;
while(io && count++);//判斷DHT11拉高總線80us高電平是否結(jié)束
RH_temp = receive_byte();
RL_temp = receive_byte();
TH_temp = receive_byte();
TL_temp = receive_byte();
CK_temp = receive_byte();
io = 1;
num = (RH_temp+RL_temp+TH_temp+TL_temp);//數(shù)據(jù)校驗(yàn)
if(num==CK_temp)
RH_data=RH_temp;
RL_data=RL_temp;
TH_data=TH_temp;
TL_data=TL_temp;
CK_data=CK_temp;
//濕度整數(shù)部分
SHISHI = RH_data/10;
SHIGE = RH_data%10;
//溫度整數(shù)部分
WENSHI =(char) TH_data/10;
WENGE = (char) TH_data%10;
函數(shù)功能:判斷液晶模塊的忙碌狀態(tài)
返回值:result。result=1,忙碌;result=0,不忙
bit BusyTest(void)
bit result;
RS=0; //根據(jù)規(guī)定,RS為低電平,RW為高電平時(shí),可以讀狀態(tài)
RW=1;
E=1; //E=1,才允許讀寫
_nop_(); //空操作
_nop_();
_nop_();
_nop_(); //空操作四個(gè)機(jī)器周期,給硬件反應(yīng)時(shí)間
delaynms(5);
result=BF; //將忙碌標(biāo)志電平賦給result
E=0; //將E恢復(fù)低電平
return result;
函數(shù)功能:將模式設(shè)置指令或顯示地址寫入液晶模塊
入口參數(shù):dictate
void WriteInstruction (uchar dictate)
while(BusyTest()==1); //如果忙就等待
P0=dictate; //將數(shù)據(jù)送入P0口,即寫入指令或地址
RS=0; //根據(jù)規(guī)定,RS和R/W同時(shí)為低電平時(shí),可以寫入指令
RW=0;
E=0; //E置低電平(根據(jù)表8-6,寫指令時(shí),E為高脈沖,
// 就是讓E從0到1發(fā)生正跳變,所以應(yīng)先置"0"
delaynms(5);
_nop_();
_nop_(); //空操作兩個(gè)機(jī)器周期,給硬件反應(yīng)時(shí)間
_nop_();
_nop_();
_nop_();
delaynms(5);
E=1; //E置高電平
_nop_();
_nop_();
_nop_();
delaynms(5);
E=0; //當(dāng)E由高電平跳變成低電平時(shí),液晶模塊開始執(zhí)行命令
delay1ms();
函數(shù)功能:指定字符顯示的實(shí)際地址
入口參數(shù):x
void WriteAddress(unsigned char x)
WriteInstruction(x|0x80); //顯示位置的確定方法規(guī)定為"80H+地址碼x"
函數(shù)功能:將數(shù)據(jù)(字符的標(biāo)準(zhǔn)ASCII碼)寫入液晶模塊
入口參數(shù):y(為字符常量)
void WriteData(uchar y)
P0=y; //將數(shù)據(jù)送入P0口,即將數(shù)據(jù)寫入液晶模塊
RS=1; //RS為高電平,RW為低電平時(shí),可以寫入數(shù)據(jù)
RW=0;
delaynms(5);
delaynms(5);
_nop_();
_nop_();
_nop_();
delaynms(5);
E=1; //E置高電平
_nop_();
_nop_();
_nop_();
函數(shù)功能:對(duì)LCD的顯示模式進(jìn)行初始化設(shè)置
void LcdInitiate(void)
delaynms(15); //延時(shí)15ms,首次寫指令時(shí)應(yīng)給LCD一段較長(zhǎng)的反應(yīng)時(shí)間
WriteInstruction(0x38); //顯示模式設(shè)置:16×2顯示,5×7點(diǎn)陣,8位數(shù)據(jù)接口
delaynms(5); //延時(shí)5ms ,給硬件一點(diǎn)反應(yīng)時(shí)間
WriteInstruction(0x38); //連續(xù)三次,確保初始化成功
WriteInstruction(0x0c); //顯示模式設(shè)置:顯示開,無(wú)光標(biāo),光標(biāo)不閃爍
WriteInstruction(0x06); //顯示模式設(shè)置:光標(biāo)右移,字符不移
WriteInstruction(0x01); //清屏幕指令,將以前的顯示內(nèi)容清除
void write_com(uchar com)//向1602寫指令
P0=com;
delaynms(5);
RS=0;
RW=0;
delaynms(5);
delaynms(10);
E=1;
delaynms(10);
E=0;
函數(shù)功能:顯示溫度的小數(shù)點(diǎn)
void display_dot(void)
WriteAddress(0x80+0x40+0x03); //寫顯示地址,將在第2行第10列開始顯示
WriteData('.'); //將小數(shù)點(diǎn)的字符常量寫入LCD
delaynms(50); //延時(shí)1ms給硬件一點(diǎn)反應(yīng)時(shí)間
函數(shù)功能:顯示溫度的單位(Cent)
void display_cent(void)
WriteAddress(0x80+0x40+0x02); //寫顯示地址,將在第2行第13列開始顯示
WriteData(0xdf);
WriteData('C');
向1302寫一個(gè)字節(jié)
void input_BYTE(uchar dat)
uchar i;
ACC=dat;
for(i=8;i>0;i--)
T_IO=ACC0;
T_CLK=1;
delaynms(5);
T_CLK=0;
ACC=(ACC>>1);
1302讀出一個(gè)字節(jié)
uchar output_BYTE()
uchar i;
for(i=8;i>0;i--)
ACC=(ACC>>1);
ACC7=T_IO;
T_CLK=1;
T_CLK=0;
return (ACC);
寫數(shù)據(jù)
void write_1302(uchar add,uchar dat)
T_RST=0; //禁止數(shù)據(jù)傳輸
T_CLK=0; //確保寫數(shù)據(jù)之前SCLK被拉低
T_RST=1; //啟動(dòng)數(shù)據(jù)傳輸
delaynms(5);
input_BYTE(add); //寫入命令字
input_BYTE(dat); //寫數(shù)據(jù)
delaynms(5);
T_CLK=1; //將時(shí)鐘電平至于已知狀態(tài)
T_RST=0;
讀數(shù)據(jù)
uchar read_1302(uchar add)
uchar inf;
T_RST=0;
T_CLK=0;
T_RST=1;
delaynms(5);
input_BYTE(add);
inf=output_BYTE();
delaynms(5);
T_CLK=1;
T_RST=0;
return (inf);
void init_1302()
write_1302(0x8e,0x00);//關(guān)閉寫保護(hù);
// write_1302(0x90,0xaa);//設(shè)置充電方式;
write_1302(0x80,0x00);//秒寄存器初始化;
write_1302(0x82,0x29);//分.......
write_1302(0x84,0x08);//時(shí).......
write_1302(0x86,0x10);//日........
write_1302(0x88,0x11);//月.......
write_1302(0x8a,0x02);//星期...
write_1302(0x8c,0x15);//年......
write_1302(0x8e,0x80);//打開寫保護(hù);
鬧鐘顯示子程序
void show_naozhong(uchar x,uchar y)
uchar i,x1,x2,y1,y2;
x1=x/10; //十位
x2=x%10;//個(gè)位
WriteAddress(0x80+0x0b); //顯示鬧鐘的小時(shí)部分
WriteData(table1[x1]);
WriteAddress(0x80+0x0c);
WriteData(table1[x2]);
y1=y/10; //十位
y2=y%10;//個(gè)位
WriteAddress(0x80+0x0e); //顯示鬧鐘的分鐘部分
WriteData(table1[y1]);
WriteAddress(0x80+0x0f);
WriteData(table1[y2]);
WriteAddress(0x80+0x0d); //顯示小時(shí)與分鐘之間的那個(gè)冒號(hào)
WriteData(':');
WriteAddress(0x80); //顯示字符串:Alarm Clock
for(i=0;i<11;i++)
WriteData(table[i]);
WriteAddress(0x80+0x40); //顯示字符串:Today is fine!
for(i=0;i<14;i++)
WriteData(table3[i]);
void main(void)
uchar i;
// ceshi=0;
LcdInitiate(); //將液晶初始化
delaynms(5); //延時(shí)5ms給硬件一點(diǎn)反應(yīng)時(shí)間
init_1302();
EA=1;//開總中斷
EX0=1; //開外部中斷1
IT0=0; //下降沿觸發(fā)
WriteAddress(0x80+0x50);
for(i=0;i<13;i++)
WriteData(table5[i]);
for(i=0;i<30;i++)
write_com(0x18);
delaynms(250);
delaynms(250);
write_com(0x01);
{ read_io();
t_sec=read_1302(0x81);//讀秒 ;
sec1=t_sec&0x0f;
sec2=(t_sec>>4);
t_min=read_1302(0x83);//讀分 ;
min1=t_min&0x0f;
min2=(t_min>>4);
t_hour=read_1302(0x85);//讀小時(shí) ;
hour1=t_hour&0x0f;
hour2=(t_hour>>4);
t_day=read_1302(0x87);//讀日;
day1=t_day&0x0f;
day2=(t_day>>4);
t_mon=read_1302(0x89);//讀月 ;
mon1=t_mon&0x0f;
mon2=(t_mon>>4);
week=read_1302(0x8b);//讀星期 ;
week1=week&0x0f;
t_year=read_1302(0x8d);//讀年 ;
year1=t_year&0x0f;
year2=(t_year>>4);
WriteAddress(0x80+0x06);
WriteData('2');
WriteAddress(0x80+0x07);
WriteData('0');
WriteAddress(0x80); //顯示星期(0x80~0x80+0x05)
for(i=0;i<4;i++)
WriteData(table2[i]);
WriteAddress(0x80+0x04);
WriteData(table1[week1]);
WriteAddress(0x80+0x08);//顯示年
WriteData(table1[year2]);
WriteAddress(0x80+0x09);
WriteData(table1[year1]);
WriteAddress(0x80+0x0a); //顯示‘/’
WriteData('/');
WriteAddress(0x80+0x0b);//顯示月
WriteData(table1[mon2]);
WriteData(table1[mon1]);
WriteAddress(0x80+0x0d); //顯示‘/’
WriteData('/');
WriteAddress(0x80+0x0e);//顯示日
WriteData(table1[day2]);
WriteData(table1[day1]);
/*第一行在此顯示完畢*/
// display_dot(); //顯示溫度的小數(shù)點(diǎn)
display_cent(); //顯示溫度的單位
WriteAddress(0x80+0x40); //溫度
WriteData(table1[WENSHI]);
WriteAddress(0x80+0x40+0x01);//
WriteData(table1[WENGE]);
WriteAddress(0x80+0x40+0x05); //溫度
WriteData(table1[SHISHI]);
WriteAddress(0x80+0x40+0x06);//
WriteData(table1[SHIGE]);
WriteAddress(0x80+0x40+0x08); //顯示小時(shí)
WriteData(table1[hour2]);
WriteAddress(0x80+0x40+0x09);
WriteData(table1[hour1]);
WriteAddress(0x80+0x40+0x0a); //顯示':'
WriteData(':');
WriteAddress(0x80+0x40+0x0b); //顯示分鐘
WriteData(table1[min2]);
WriteAddress(0x80+0x40+0x0c);
WriteData(table1[min1]);
WriteAddress(0x80+0x40+0x0d); //顯示':'
WriteData(':');
WriteAddress(0x80+0x40+0x0e); //顯示秒
WriteData(table1[sec2]);
WriteAddress(0x80+0x40+0x0f);
WriteData(table1[sec1]);
/*第二行在此顯示完畢*/
//以下部分是鬧鐘鍵盤檢測(cè)程序
if((x==hour2*10+hour1)&&(y==min2*10+min1))//若時(shí)間到了,則開啟鬧鐘
beep=0;
else //否則,關(guān)閉鬧鐘
beep=1;
delaynms(10);
void exter0()interrupt 0
uint k;
write_com(0x01);
for(k=0;k<2000;k++)
while(key1==0) //鍵盤掃描.當(dāng)key1按下時(shí),
{ //鬧鐘的小時(shí)部分加一
delaynms(10);
if(key1==0) //消抖
delaynms(10);
while(key1==0); //松手檢測(cè)
x++;
if(x==24) //小時(shí)部分加到24后自動(dòng)清零
x=0;
while(key2==0) //鍵盤檢測(cè)。當(dāng)key2按下時(shí),
delaynms(10); //鬧鐘的分鐘部分加一
if(key2==0) //消抖
delaynms(10);
while(key2==0);//松手檢測(cè)
y++;
if(y==60) //若分鐘部分加到60,則自動(dòng)清零
y=0;
show_naozhong(x,y); //調(diào)用鬧鐘顯示程序
write_com(0x01);
