- #include <reg52.H>
- #define uint unsigned int
- #define uchar unsigned char
- uchar string1[]={"I LOVE YOU"};
- uchar string2[]={"FOR EVER! "};
- /****delay1ms***/
- /*函數(shù)功能:延時1ms
- 參數(shù):count
- 返回類型:無
- void delay1ms(unsigned int count)
- unsigned int i,j;
- for(i=0;i<count;i++)
- for(j=0;j<120;j++);
- /***lcd_busy***/
- /*函數(shù)功能:判斷p0.7口是否為1,為1則為忙
- 參數(shù):無
- 返回類型:p0.7的值
- sbit rs = P2^7;
- sbit rw = P2^6;
- sbit en = P2^5;
- uchar lcd_busy(void)
- {uchar busy;
- rs=0;
- rw=1;
- en=1;
- delay1ms(1);
- busy=P0&0x80;
- delay1ms(1);
- en=0;
- return (busy);
- /**lcd_write***/
- /*函數(shù)功能:向LCD中寫數(shù)據(jù)和命令
- 參數(shù):s=0 時向lcd寫命令
- s=1 時向lcd寫數(shù)據(jù)
- date 為要向lcd寫入的數(shù)據(jù)
- 返回類型:無
- #define cmd 0
- #define dat 1
- void lcd_write(uchar s,uchar date)
- {while (lcd_busy());
- rs=s;
- rw=0;
- en=1;
- delay1ms(1);
- P0=date;
- delay1ms(1);
- en=0;
- /*****lcd_init****/
- /*函數(shù)功能:將lcd進行初始化處理
- 參數(shù):無
- 返回類型:無
- void lcd_init(void)
- {lcd_write(cmd,0x38); //設置16X2顯示,5X7點陣,8位數(shù)據(jù)接口
- lcd_write(cmd,0x0c); //開顯示,不顯示光標,無光標閃爍
- lcd_write(cmd,0x06); //AC累加,屏幕不移動
- lcd_write(cmd,0x01); //清屏
- /***lcd_XY****/
- /***函數(shù)功能:實現(xiàn)位置定位
- 參數(shù):X Y的值
- 返回類型:無
- void lcd_xy(uchar x,uchar y)
- if(y==0) //表示在第一行顯示
- lcd_write(cmd,0x80|x);
- if(y==1) //表示在第二行顯示
- lcd_write(cmd,0x80|0x40|x);
- /**lcd_print***/
- /*****函數(shù)功能:顯示LCD數(shù)據(jù)
- 參數(shù):*string
- 返回類型:無
- void lcd_print(uchar *string) //string 表示要顯示的數(shù)據(jù)
- while(*string!='\0')
- {lcd_write(dat,*string);
- string++;
- /***lcd_display()***/
- /*函數(shù)功能:顯示
- 參數(shù):無
- 返回類型:無
- void lcd_display()
- {lcd_xy(3,0);
- lcd_print(string1);
- lcd_xy(4,1);
- lcd_print(string2);
- /****主函數(shù)****/
- void main()
- while(lcd_busy());
- lcd_init();
- while(1)
- lcd_display();
復制代碼
