查看: 3082|回復(fù): 0
912 The computer has been removed , The machine dover has been
ID:104287 發(fā)表于 2016-1-29 19:08 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
    開機后出現(xiàn)報警聲并且提示912錯誤,屏幕顯示:“912 The computer has been removed , The machine dover has been --------”,經(jīng)上網(wǎng)一查,原來是HP臺式機特有的開箱報警,處理方法可以進入BIOS 設(shè)置,將Reset case open status 的設(shè)置改為Enabled。
